Slot car voltage and amperage
Posted 05 January 2012 - 01:20 PM
Can anyone give me an estimate for the voltage and amperage (I guess the running amperage) for a 1/24 and 1/32 car?
I'm trying to find a solar panel that could handle the power draw of a 1/24 (or 1/32) track with at least 4 cars. This is in reference to my previous post about a solar powered slot car exhibit. We are currently trying to order the parts to build a prototype.
I was thinking about using the Carrera track, since it can handle both scales.
Thank you,
Dan
I'm not very good with electricity terminology, so if I made a mistake please feel free to correct me.
Posted 05 January 2012 - 01:59 PM
Otherwise a slot car (each) needs 12 to 18 volts and one amp for the lowest-powered home cars. Commercial track cars vary around 14 volts and five to 20 amps each.
11/6/54-2/13/18
Posted 05 January 2012 - 03:16 PM
If anyone has some experience trying to run a track off a solar panel (indoors or outdoors) I would appreciate your thoughts.
Thank you,
Dan
Posted 05 January 2012 - 04:11 PM
Posted 05 January 2012 - 10:24 PM
Maybe you should plan on some indoor wind generators for backup power.
Posted 06 January 2012 - 08:44 AM
James, it's been done before. The Museum of Science and Industry in Chicago has a small setup running indoors off of a solar panel. As long as you have the right lights with the proper focal points you can generate a good amount of energy. If we need to double up on panels then we will.
The main goal is the interactive component of seeing how these panels can run something fun and exciting.
Posted 06 January 2012 - 09:48 AM
Who would have believed corn would be supplying almost 10 percent of our gasoline today a few years ago? An acre of corn produces about 450 gallons of alcohol or the energy of 225 gallons of BTU dense gasoline. An acre of corn when used as fuel is actually a solar collector that only "catches" about three percent of the sun's energy.
11/6/54-2/13/18
Posted 06 January 2012 - 08:17 PM
An alternative to the plastic cars is the Falcon class motor commercial car which draws about the same as the Carrera and significantly out-performs them and are totally rebuildable from components.
racing around Chicago-land
Posted 07 January 2012 - 02:51 AM
But if solar is ever to be used as a power source it must be researched.
IF???
The future is now. Wake up and smell the photons.
Solar power plants in the Mojave Desert
Dan:
Sorry about poking fun at indoor solar panels. It just seems inherently silly, like pumping water into a tower so that you can generate power when you release it... or like using petroleum products to plow, plant, fertilize, harvest, transport, and distill corn into ethanol... to use as a petroleum substitute. Silly
(Oops, I left out herbicides and insecticides.)
Posted 07 January 2012 - 10:54 AM
I've got hand-held calculators I bought in the '70s, that's about all that sunlight can power in Tennessee, though some ten acre solar farms are being tried.
And what fertilizer is produced from petroleum? Nitrogen from natural gas, yes, but natural gas is not a petroleum product.
11/6/54-2/13/18
Posted 07 January 2012 - 03:18 PM
Okay, you got me. I should have said "fossil fuels" rather than "petroleum', but my point is still valid.
Posted 07 January 2012 - 04:40 PM
???-2/31/23
Posted 11 January 2012 - 01:26 AM
Just Google on "how to wire a slot car track" if you want to know the amperage and voltage on tracks.
My track is set at 3 amps per lane, 13.8v power supply.
Cost? $56.00.
Posted 11 January 2012 - 10:53 AM
#15
Posted 11 January 2012 - 07:16 PM
Hopefully not, but at $56 a good portion of the current being delivered to your track might be AC.
11/6/54-2/13/18
