Unknown mystery chassis?
Posted 23 July 2012 - 04:31 PM
Some thought it was scratchbuilt but now that a second exact copy has been found, it is probably a production item. The blob of solder on the drop arm is for a down stop, as seen on the second copy. It is similar to the Sandy Gross chassis shown on Slotblog but not exactly. I'm guessing 1968?
I stripped it down so it wouldn't show the threaded axles and wheels and wrong motor so I'm assuming plain axles. Can anyone ID this one? The tubes are too big for pin mounts; does this mean screws were used? Any suggestions for bodies, motor, wheels, guide?
Posted 23 July 2012 - 04:50 PM
Cox quick change guide, Marklin lead wire. Wheels? Riggen, early Associated or Champion 7/8" X 5/8" rears and 3/4" X 3/16" taper ground fronts...and NO spacers on the front axle...there is supposed to be 1/8" side to side slop. Short nose Lola T70, Lotus 40, Russkit Elfin...
8/19/54-8/?/21
Posted 23 July 2012 - 05:28 PM
Posted 23 July 2012 - 07:20 PM
Is the motor bracket for a 26D or a 36D?
Posted 23 July 2012 - 08:39 PM
That's definitely a production chassis as I have the same chassis except mine is the open wheel version.
Eddie, can you post a photo of your open wheel chassis? I'd like to see how it compares to the Lancer open wheel chassis I've seen in the past. I think I still have paper photos of one of those.
Pablo, I think that's a 16D bracket. Gary, didn't I see a Trinity Midnite motor in that chassis before?
Posted 23 July 2012 - 09:33 PM
They look sort of familiar. I vaguely remember the ad where both were pictured.
Wild stab: early Cobra, Phaze III, or Ferret.
Posted 23 July 2012 - 10:52 PM
Thanks for the photos, Eddie.
Posted 24 July 2012 - 08:26 AM
Can anyone tell me what the motor is in mine? It has a drill balanced motor. Doesn't look like Mura balancing.
Regards,
Steve C
Stephen Corneille
Posted 24 July 2012 - 08:37 AM
Then the same frame can be converted to a sports or stock car (wheelbase) by building a pair of wide mounts from 1/16" tubing placed inside the 3/32" and held in place with a rubber band that's placed over hooks welded to the mounts.
The frame shown isn't intended for that though.
11/6/54-2/13/18
Posted 24 July 2012 - 10:26 AM
Steve,
I don't know exactly but think it's a Tradeship motor. We discussed this back in '06 or '07 when I built up a motor with that endbell for my proxy car "Firefly". I have one of those motors here NOS and the arm looks un-balanced with same green wire.
Posted 24 July 2012 - 10:34 AM
Re: post #9, Steve, I think your motor is a Testors Mk 111. In Australia , that motor turned up right at the end of 1967.
It has a cast metal endbell and was quite a good performer due to the arm winding and open brush setup.
Looks like the chassis has taken a lot of front end hits; blobby solder over axle tube.
- mickey thumbs likes this
Posted 24 July 2012 - 10:44 AM
And mine is indeed balanced just like Steve's.
Never been mounted but I did hook up some lead wires and run the brushes in some to test. Might make a neat project motor someday.
#15
Posted 24 July 2012 - 11:29 AM
The motor you have would make a great vintage racing car if combined with a suitable period chassis. I think that in America, if you used a Testors Chassis, you would be limited to their pressed aluminium production car units, but luckily here in Australia, Testors had a full-fledged race team, and part of that business was the sale of Team Testors custom (series) built brass inline frames. Oh, yes, some do survive, mint in their packaging from 1968!
#16
Posted 24 July 2012 - 12:08 PM
And do you happen to have one of those Testor's chassis to show us? Very interesting they had a team in Australia, but not in the States...
The Testor Turbo is an excellent little motor, roughly in the 26D class; I believe it's static balanced. The one I've run didn't have too much brakes, but don't know if that's a general characteristic... My impression was that it would do better on a longer track...
Back to the chassis in this thread, can't say I've ever seen one, or recognize it...
Posted 24 July 2012 - 12:10 PM
#18
Posted 24 July 2012 - 12:34 PM
If you care to get out your copy of "Australian Slot Car Review" magazine, the December 2000 (last) issue, go to page 50 and you will see a Testors story.
On page 54 is a picture of a 'Testor Team Hutchesson' body, chassis, package grouping. The motor is a brown
endbell 26D. The chassis is all brass. The body is 1/24 Lotus 40. This car dates from late 1967; we here were a bit behind in equipment compared to the USA.
I think that I might be able to rustle up a chassis mint in a bag with header card still attached. It comes without the bits you need to make it a runner (guide, wheels, motor, etc.) Best I have a dig for you.
#19
Posted 24 July 2012 - 02:44 PM
8/19/54-8/?/21
Posted 24 July 2012 - 03:49 PM
OK now I have seen five of these chassis!
Looking at the 1970 Auto World catalogue, I'd have to rule out Phaze III, which was similar, but had a round brace behind the gear, different bend in the drop arm and different bearing holders. Earlier '68-1/2 Auto World catalogue shows a similar chassis, like Sandy Gross designed but with a three-rail drop arm.
#21
Posted 24 July 2012 - 04:04 PM
Posted 24 July 2012 - 04:08 PM
Wonder if you might be kin to Jerry Lawley. He was one of the better Sportsman and Nation Sportsman drivers in the '70s. He won the points championship at Nashville in 1975 I believe.
He lived not far from Birmingham and traveled some with Neil Bonnett in '75.
11/6/54-2/13/18
Posted 24 July 2012 - 04:49 PM
PM sent.
#24
Posted 25 July 2012 - 01:25 AM
Would you care to share that Testor story and scan it for us all to see?
Besides, also a little personal interest, as the company founder Nils Testor, like Johan Fredrik Strömbäck (Strombecker), was from my home turf...
Overseas Observer
#25
Posted 25 July 2012 - 04:26 AM
The Swedish Connection, eh? So that's where Mr. Strombeck comes from!
