Createx "Wicked Color" paint
37 replies to this topic
#1 Mike Patterson
  • 2,578 posts
Posted 11 September 2012 - 08:29 PM
Has anyone tried this stuff on Lexan?
#2 John Miller
John Miller
    This space for rent
  • 1,150 posts
Posted 11 September 2012 - 08:38 PM
Works great.
#3 Bill from NH
  • 14,800 posts
Posted 11 September 2012 - 08:51 PM
As do the other Createx paints. :)
#4 Race O' Rama
Race O' Rama
  • 1,107 posts
Posted 11 September 2012 - 09:29 PM
I've been using Createx for about 7 years now it works great, but sometimes I use other ones to get some cool custom colors.
Karl Hoffheins
4/8/65-8/16/22
#5 Mad Mexican
Mad Mexican
    Safer Barrier Tester!
  • 1,274 posts
Posted 11 September 2012 - 10:05 PM
I have been using the Createx water base paint for the last two years and made a a real cool orange for my cars to run this year tequilla sunrise orange I call it! And it mixes well with Parma Faskolors also!
Adios Amigos
Javier Zavala
In loving memory of my mother Francisca Escalante Zavala
March 24, 1927 - April 5, 2011
Vaya Con Dios
#6 Zippity
Zippity
  • 5,278 posts
Posted 11 September 2012 - 10:54 PM
How are you guys applying this paint - by brush or air?
  • hammerdown3426 likes this
Ron Thornton
#7 Old pink can guy
Old pink can guy
  • 1,529 posts
Posted 11 September 2012 - 11:40 PM
Come on Zip. The just open the bottle and Blow it on.
Ken Botts
#8 Zippity
Zippity
  • 5,278 posts
Posted 11 September 2012 - 11:45 PM
Are you aware that the same product is available under a different label in many craft shops at a much cheaper cost? :)
Ron Thornton
#9 Old pink can guy
Old pink can guy
  • 1,529 posts
Posted 11 September 2012 - 11:58 PM
Names of the supects please Zip?
Ken Botts
#10 Greg VanPeenen
Greg VanPeenen
  • 1,200 posts
Posted 11 September 2012 - 11:59 PM
What would that be, always looking to save a buck
Greg VanPeenen
12/4/49-4/17/24
#11 Zippity
Zippity
  • 5,278 posts
Posted 12 September 2012 - 01:52 AM
SEMCO - although it appears it may now be a discontinued line :(
see http://www.needlegra...nt/prod3877.htm
Thankfully I have quite a selection of their colours.
Maybe I had better check out a couple of the "Spotlight" stores here in New Zealand and stock up :)
Ron Thornton
#12 One_Track_Mind
One_Track_Mind
  • 2,966 posts
Posted 12 September 2012 - 05:00 AM
Has anyone tried this stuff on lexan?
Hi Mike,
speaking only for myself I never tried the 'wicked color' line of paints ,just the plain createx. They have opaque,irredescent,transparent,flourescent and they all work just fine with lexan. I use 45-50 psi with an airbrush only. same as IF I were using the Faskolor from Parma.
I have never actually mixed the two paints together,but have used both brands on one body.
Slots-4-Ever
Brian McPherson
REM Raceway
#13 Chris Barnes
Chris Barnes
  • 556 posts
Posted 12 September 2012 - 07:13 AM
Wicked Color is thicker than the standard Createx. You will have to thin it down for easier application.
#14 Les Boyd
Les Boyd
  • 465 posts
Posted 12 September 2012 - 08:14 AM
I have used the Wicked paint and had not seen any differance. It may seem to be thicker but so do some of the pearl colors, but they go through the air brush with no trouble. They can be put on very light coats with out having to thin them. But as always test them with your air brush and see if you need to thin then before you add any thiner.
#15 Gary Adams
Gary Adams
    Old 'N Slow
  • 416 posts
Posted 12 September 2012 - 09:30 AM
The Wicked Colors do work great, but I would caution you that they are solvent-based paints, unlike the regular Createx and Parma Faskolor paints which are water-based. I have had no problem using them with my airbrush, just the cleanup and maintenance is different,
Gary Adams
11/17/49-1/30/24
#16 One_Track_Mind
One_Track_Mind
  • 2,966 posts
Posted 12 September 2012 - 09:48 AM
That is a great tip Gary!
I was NOT aware of this, nothing beats water clean-up! :)
Slots-4-Ever
Brian McPherson
REM Raceway
#17 Les Boyd
Les Boyd
  • 465 posts
Posted 12 September 2012 - 10:00 AM
Hmmm you made me go look but my wicked red is water base.
#18 Tom Thumb Hobbies
Tom Thumb Hobbies
  • 3,620 posts
Posted 12 September 2012 - 12:46 PM
Taken from Createx website:
" Wicked contains mild amounts of solvent inter-mixed with a durable, exterior-grade resign and automotive pigments for an extremely durable paint....."
Mike McMasters
Former home of the ORIGINAL American blue King
#19 Ron Hershman
Ron Hershman
  • 22,051 posts
Posted 12 September 2012 - 01:00 PM
So what does one thin it with and clean up the air brush with afterwards?
#20 Noose
Noose
  • 23,320 posts
Posted 12 September 2012 - 02:00 PM
They have a thinner they recommend you use and then it appears they have a thickener in case you scew up. Nothing mentioned about what to use for clean up. I would use acetone anyway to make sure it was clean.
#21 GearBear
GearBear
  • 363 posts
Posted 12 September 2012 - 02:58 PM
The reducer they recommend is the same used for other Createx paints.
Wicked Colors may be reduced with W100 Reducer or Auto Air 4011 Flash Reducer in any ratio for improved flow, atomization and customizing viscosity preferences.
I use the W100 a lot. It works great with Createx, Parma Fascolor, and Auto Air paints. I haven't tried the Wicked Colors paint yet. I use the W100 the most. I used to use Formula 409 to reduce the Parma Fascolor (before I knew about Createx and Auto Air), but since I started using the W100 I have had less problems with Fish Eye.
Also note this...
The use of heat to cure colors is one of the main differences between Createx Airbrush Colors and Wicked & Auto Air Colors which cure to a much stronger film with air drying alone (referred to as self-cross linking).
I still heat set all my water based paint.
Gary Johnson
#22 GearBear
GearBear
  • 363 posts
Posted 12 September 2012 - 03:16 PM
I also found this on the Createx site...
http://www.createxco...rface_guide.pdf
Clean all spray guns and airbrushes immediately after use. Auto Air 4008 Restorer works excellent to clean all parts and partially dissolve any dried or cured paint, making clean up with water and a brush effective and easy. Flush with water after using Restorer. Final rinse with Auto Air 4011 Flash Reducer or Wicked W100 Reducer.
Gary Johnson
#23 Gary Adams
Gary Adams
    Old 'N Slow
  • 416 posts
Posted 12 September 2012 - 04:02 PM
I use the W100 Reducer to clean my airbrush after using the Wicked Colors, works great for me.
Gary Adams
11/17/49-1/30/24
#24 Ron Hershman
Ron Hershman
  • 22,051 posts
Posted 12 September 2012 - 05:50 PM
1.The reducer they recommend is the same used for other Createx paints.
Also note this...
2. I still heat set all my water based paint.
1. So you use the "reducer" with the water based paints as well with no problems?
2. Is there any advantage of heat dry versus air drying other than heat taking less time for the paint to dry?
Has anyone "mixed" together the Wicked colors and the waterbased Createx paint trying to come up with some different color by mixing the two?
If so...how did that work? Did you think that mixture with water or the recommended reducer?
#25 Johnny
Johnny
  • 258 posts
Posted 12 September 2012 - 06:00 PM
I'm using the "Createx" (Parma), "Wicked Colors" and the "Auto-Air" on the same bodies without any problems.
I have also used the Auto-Air 4011 and Wicked 0100 reducer on the Parma paint without problems.
The paint and reducer tends to split when stored over time, but shaking it up makes it ok.
I have not mixed the different brands to make any new shades of colors.
Here's a picture of a body painted with a mix of Createx (Parma) and Auto-Air colors.
Best Regards,
Johnny Andersen
Oslo - Norway
Asker Mini Racing Club
