Lotus Eleven, with Merit body and Midori chassis
40 replies to this topic
#1 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 06:28 AM
Hello All.
This is the first time I post something in this section of the forum.
As some of you might know, I love Colin Chapman's creations. So here is the way I build a Lotus Eleven, from a NOS kit and a chassis found in a slot car swap meeting in the south of France (near Toulouse).
And all this, in more pictures than words (or more likely so).
I might only comment few steps.
Let's start!
Now I just put the chassis in the lower part of the body, to be able to draw with a pencil where plastic will have to be cut off.
To be continued...
  • MarcusPHagen, MSwiss and Peter Horvath like this
(Bud)light is right!
#2 SlotStox#53
  • 4,084 posts
Posted 09 August 2013 - 07:59 AM
The Lotus Eleven is a beautiful design/shape, share the love of Colins creations :)
Great start ! :D
#3 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 08:04 AM
The rear corner of the rear wheel arch has to be modified. From square in the kit, it has to become round (here with Tamiya epoxy 2 components mastic):
Underneath, at the rear end, a U line has to be engraved. Inside the line, the area will be covered with bare metal. On the real car the rear bonnet is articulated on this part that we delimitated:
I then reinforced the lower part of the body:
On this picture of the left side, I marked up the lower genuine separation line of the front bonnet with a slim band of masking tape. This line goes down too far and the line of the wheel arch is wrong.
We can see that it is wrong with this picture taken from a book:
Here is now the other side of the body, after modification:
It is now time to modify the left side, from bellow, where the exhaust should be:
Here is a real car, for reference:
To be continued...
  • MarcusPHagen, Joe Mig and Peter Horvath like this
#4 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 08:31 AM
The way the driver's door is cut for the windscreen is totally wrong. It just cannot remain as it is.
The windscreen also has to be cut, one should be able to place it on a plane surface.
For engraving the lines that are embossed on the kit, we have to file down the embossment and then use a dry point guided with Dymo tapes.
Now the headlight housing:
The lenses themselves are turned into the clear parts tree:
To be continued...
  • MarcusPHagen and Peter Horvath like this
#5 Hworth08
Hworth08
  • 3,563 posts
Posted 09 August 2013 - 08:54 AM
Really nice!
The gussets on the body mounts rival the ones Bobby Allison used to sell. No telling how many thousand he sold. About everyone in NASCAR used his various extremely well designed and cut plates.
Don Hollingsworth
11/6/54-2/13/18
#6 Cheater
  • 25,683 posts
Posted 09 August 2013 - 09:03 AM
Great stuff!
#7 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 09:18 AM
At the rear of the lenses, I apply some bare metal foil:
Provisional assembly of the pilot (found in a lot on ebay, should some-one recognize the origin, any information will be welcome.)
As for the rivets on the dashboard, we will see later on how I do that with a hot needle:
To be continued...
#8 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 09:37 AM
This now how to make a resin copy of the front, with headlight housings filed up with epoxy mastic, which copy will be useful for creating transparent covers (thermo formed).
The windscreen also has to be engraved:
To be continued...
#9 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 09:51 AM
Now, the way I create rivets, with a woodburning apparel on which I added a needle.
An Eleven without rivets is not an eleven... (juste like a D type Jaguar by the way).
We will also see the inside of the genuine body, to understand why and where there are rivets.
When the system is at the right temperature, the entry of the needle creates a little plastic mushroom. And there you are!
A picture I took myself, this year at the Lotus Show at Donington Park in the Middlands (UK).
#10 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 10:02 AM
Taken at the same place:
The lens covers, just put in place...
Now, it's time to paint, with a mix of colors as I did not find the exact green I wanted in the spray cans.
#11 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 10:13 AM
For the tank cap, I used a Cox part, the one that can be found in the Lotus 30/Lotus 40 kit:
To be continued...
#12 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 09 August 2013 - 10:53 AM
How to create the instruments?
1. Drill holes in the dashboard,
2. create a circle in metallic thread and glue it,
3. paint the inside in black;
4. glue the pictures of the instruments on the rear side (here, decals on their paper support),
5. Fill in with 2 components epoxy glue, like araldite, to simulate the glass.
You will have beautiful instruments in depth and not only some flat representation...
Et voilà !  :hi:
Now the model is almost completed.
I just have to create the lateral fastening buckles.
I will do this when I will be back home. I'm outside now, enjoying holidays in my 1:1 Lotus Elan M100 SE.  :dance4:
But meanwhile, if you have questions... I will be happy to answer, my friends.
  • Lowrider, MarcusPHagen, miko and 2 others like this
#13 Tex
  • 9,243 posts
Posted 09 August 2013 - 11:25 AM
Absolutely fantastic, Jean-Michel!
#14 Tim Neja
  • 6,840 posts
Posted 09 August 2013 - 11:38 AM
Your INSANE!!!  And I mean that in the nicest way!!! That model is SIC!! :) :)
#15 Dennis David
Dennis David
  • 3,424 posts
Posted 09 August 2013 - 11:53 AM
We are not worthy ...
Dennis David
#16 mdiv
mdiv
  • 2,360 posts
Posted 09 August 2013 - 11:56 AM
:clapping:
Totally awesome!
Mike DiVuolo
#17 Noose
Noose
  • 23,298 posts
Posted 09 August 2013 - 01:44 PM
That is gorgeous. Thanks for sharing!
#18 SlotStox#53
  • 4,084 posts
Posted 09 August 2013 - 02:01 PM
Totally amazing and beautiful Lotus , thanks for showing us your handy work and the wickedly cool outcome!!
Just WOW! :D
#19 Duffy
Duffy
  • 3,791 posts
Posted 09 August 2013 - 02:20 PM
Just fantastic.
Michael J. Heinrich
1950-2016
And I am awaiting
perpetually and forever
a renaissance of wonder
#20 Gator Bob
  • 13,391 posts
Posted 09 August 2013 - 02:54 PM
Absolument parfait !
:clapping: Bravo, Je lève mon chapeau. :hi:
#21 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 09 August 2013 - 04:33 PM
What a little jewel of a model. :wub:
Excellent 'how to' as well.
Thank you for sharing your magic with us.
:clapping:
Steve King
#22 Samiam
  • 4,771 posts
Posted 09 August 2013 - 05:21 PM
Beautiful job.
 Your attention to detail is amazing.
 Thanks for sharing this build with us.
 Did you salvage those body mount posts off a junker?
#23 Gary Bluestone
Gary Bluestone
  • 764 posts
Posted 09 August 2013 - 06:57 PM
Wrong Forum, can't be amateur ! Must be professional or work of ART forum !
#24 Mark Johnson
Mark Johnson
  • 499 posts
Posted 09 August 2013 - 10:19 PM
SUPERB
#25 Jean-Michel Piot
Jean-Michel Piot
    Plastic surgeon
  • 654 posts
Posted 10 August 2013 - 12:33 AM
All those nice comments, and on my birthday in addition to this! Many thanks to all.
A special thank to Bob, for his perfect French and kind attention. Merci mon ami, cela me fait très plaisir.
To answer Samiam: yes the body mount posts come from a junker; a Dino Cox. I don't care about the red color as all the interior of the body has been sprayed with primer and then painted flat black, just as I do on my other cars and just as my friend Chris Clark does as well (he inspired me in fact).
