After digging in my vintage "box of horrors" for a Mura D endbell for Charlie, I was shocked - a dry well. Not a single one left in there Thanks to my mentor, Bill from NH, for reminding us that modern "D" size Pro Slot, Trinity, and Parma endbells will fit vintage D cans. Folks, until "Charlie the Tuna" (he has a great sense of humor so I can mess with him ) finds an elusive Mura endbell for his Certus can and arm, I have volunteered to build and blueprint him a custom Parma 501 Deathstar endbell. My plan is, the basic 501 black EB with a new Parma bushing JB Welded/press fit into place, combined with Mura hardware, ProSlot springs and brushes, etc. It's going to be a unique item and require some fiddling of course.....the world's first Parma/Mura hybrid endbell In the end, who knows, he may like it so much he just leaves it. We shall see.....
Charlie, you ask a lot of good questions (must be a doggone fisherman)
"What kind/size springs will I need that fit over post protectors?"
"Light, medium, heavy - spring selection depends on arm/mags?"
"When do you opt for shunted brushes?"
"Why would you put bearings in the endbell? can?"
Charlie, this is really easy for me - I 100% concur with everything John H said.
I don't disagree with what Gator Bob said, but without having the motor parts in front of him it's tough to say, use exactly this or that springs n parts. He suggests breaking it in with a certain spring, then using a heavier spring to run it ? Sounds counterproductive to me. I don't always agree with John or Gator Bob or anybody else. Heck, look at FK motors, the directions on the package clearly state "DO NOT RUN THIS MOTOR IN UNDERWATER" At the end of the day, it's your motor and you make the decisions.
-The springs I'm planning to provide to you along with the 501 EB and Gold Dust brushes are modern Pro Slot Speed FX springs, big enough to fit over post protectors, medium strength 90 degree. They will work on this motor. I'm not a "textbook smart" motor guy - I can't even work a meter - but I just know from experience they will be right. Like the man said, when they are pre-radiused, it doesn't take strong springs to get that perfectly eliptical brush face to kiss that comm.
-With a double 60T 27/28 arm you are right on the borderline of traditional thinking on shunts needed or not needed. How high is the timing ? I'm guessing here, but if it's about 35 or less you may be able to skip shunts. If 35 or more, like really twisted, you would probably benefit from shunts. In the end, it would all boil down to putting it in a car and running a few laps then feel the temp. If she is hot, shunts may help, assuming the heat is not caused by other problems. If she runs just warm only, and can maintain that for 30 laps or so, I'd forget shunts. If it was my motor, I'd try no shunts first. Those 26D brushes with integral shunts you showed on page one are way too small for the man sized hoods I'm going to install on this EB .........if you are to install shunts it will be a custom deal with tweaked slots on the brushes and notches cut in the hoods....today would be a good time for you to get other people's opinions and make a decision here....if it's going to be a shunt job, just let me know, I'll do what needs to be done.
-The 501 EB has a fresh new bushing in it and it's aligned absolutely perfect. I could have put a BB in it, but the design with bushing is so perfect as is, why mess with it ? Again, I concur with all John said. "Nature of the beast" in this case, the motor will HAVE to be a can drive with the 501 EB, therefore, in theory, a BB would be preferable in the can because that is the load stressed end nearest the gears. BUT, it probably already has a new, well aligned, stock bushing in it, right ? If so, I'd just leave it. If the Certus can currently has no bushing, I would absolutely install a BB. This is exactly what John said.
Now, where did I put that box of doggone Mura hardware ?
