Pro Slot 4002FK motor question
Posted 28 December 2014 - 10:14 PM
But has anyone else seen them, occasionally needing to be push started?
I think the situation is unique to our hardbody class, running on the (very) low amp power supplies on my flat track, but I'm still curious if anyone else has had the same problem.
Posted 28 December 2014 - 10:39 PM
Posted 28 December 2014 - 10:50 PM
I did have one of these I was playing around with just to see what it would do and after about three fifty-lap runs it did exactly this. I had it in a Cheetah 11 chassis geared 11/36. Cleaning the comm with an old fashioned comm stick and replacing brushes after a good clean-out made no difference. Tore the motor down and though I saw nothing visible, but one of the pole ohm readings was open. I suspect there was a broken wire somewhere in the stack windings somewhere that wasn't visible, just like we used to get on Falcon 7 motors after the motor gets really hot.
Since it was just an experiment I tossed it in the garbage. We really don't run them down here in anything since the Retro Hawk is so reliable
Posted 28 December 2014 - 11:10 PM
As Mike R said a "dead pole" is what usually causes the need for a push start. It happened to me with Group 12 motor.
Cheers
Faster then, wiser now.
Posted 28 December 2014 - 11:26 PM
I suspect it could be magnet lock, a poor solder joint at the comm, or an 'open' pole would do it but it wouldn't 'run right' even after the push.
The motors run fine once push started.
Noticed it two times with different cars and drivers with the wing cars we race on sundays at MMW.
Bill, glad I'm not losing my mind.
How did the motors run once push started?
Coincidentally, I use to see a fair amount of the "original make-believe FK motor", the JK Hawk 6 eventually needing to be push started.
What seems to be unique to the 4002FK is that they appear to sort of want to run (the arm rocks).
In the process, they draw a zillion amps and in the case of on my flat track, all the running cars severely slow down.
Posted 28 December 2014 - 11:52 PM
Most likely where it makes the sharpest wrap on the first level... could have zapped a joint, give it one shot at re-soldering the comm tabs if there is an open pole... nothing to lose... I've saved a couple over the years in non-sealed racing.
Also, too much timing and overlap can cause 'rock'.
Posted 29 December 2014 - 12:43 AM
Not sure why that would promote the problem, but I don't recall ever seeing a low cog, real FK motor, exhibited this problem / needing a push start.
Posted 29 December 2014 - 01:25 AM
It might be cumulative with the big cog, small comm, big brush, and whatever static timing is built in.
Those cut brushes (center cut) like you did for the Hawk 6 might solve the issue.
Posted 29 December 2014 - 01:42 AM
Matt Sheldon
Posted 29 December 2014 - 03:08 AM
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg 5618
Posted 29 December 2014 - 05:37 AM
Posted 30 December 2014 - 08:29 AM
The brush is 3.15 mm tall. What is the diameter of the comm on these motors? Less than 5mm?? Less than 4.6mm??
I suspect that there is a lot of overlap (degrees of rotation) where one of the poles is a dead short (combination of big brush and small comm diameter). If the motor stops while in this dead short position then the vast majority of the current flowing though the motor is basically a dead short.
For tracks with "unlimited amps" the track can supply enough amps so that some flows through the other pole and that is enough to kick start the motor.
For low amp tracks as Mike has suggested there isnt enough spare amps for this to happen and the motor sits there until you push start it or the pole burns out.
- SteveDee likes this
Rick Smith
Posted 30 December 2014 - 08:35 AM
The Pro Slot motor comes with Pro Slot's own Goldust brushes, I'm sure.
#15
Posted 30 December 2014 - 08:42 AM
So what is the diameter of the comm on these motors?
Rick Smith
#16
Posted 30 December 2014 - 08:44 AM
Am unable to answer the comm diameter question.
#17
Posted 30 December 2014 - 09:15 AM
I'm assuming the motor uses a SBFII brushes?
I don't think Pro Slot would install Koford brushes in their motors.
Rick, I'm not at home to measure, but the comms are not small, like unserviceable brush FK motors - they are in the vicinity of .200" OD
The intel I gathered (from unofficial sources) tells me the stock brushes are not Goldusts, but in testing the installation of Goldusts doesn't increase performance. They do, however, last longer than the stock brushes. The BFIIs probably would live longer as well.
Posted 30 December 2014 - 09:38 AM
These brushes are a different color than Gold Dusts, but I forget if it's darker or lighter. Pull one out and compare it to a known Goldust. These production brushes, in a 16D, would only last a race or two, so they were quickly removed and replaced.
- John C Martin likes this
#19
Posted 30 December 2014 - 10:34 AM
Used the stock length BFB to attempt break in and got excessive heat; they're too long! Too much spring tension. So the shortening cured this..
Great little motors, much more drivable than the 4002 used in the Retro Stock Car... great with a 8/27 and.812" tire.
Comparable to a Retro Hawk, maybe a little better brake and torque, because better springs, more brush contact. Gear ratio 8/27 versus 9/27 for Retro Hawks).
Tested four in the same chassis at 8/26, took the slowest two changed to 8/27 and they all are in the 4.51 to 4.56 range. The two slowest were now the fastest. But I'm not racing them on this track or power so I'll have a choice on different track and power (Peachtree City). Da Race.
Like to see them IRRA® legal.
#20
Posted 30 December 2014 - 11:03 AM
They are John for Can-Am Plus.
#21
Posted 30 December 2014 - 11:07 AM
Awesome ..good choice..twiking springs and brush choice would add some fun..good move IRRA..
#22
Posted 30 December 2014 - 11:46 AM
I'm pretty sure you're in the minority..twiking springs and brush choice would add some fun
Isn't twiking what Miley Cyrus does on stage?
#23
Posted 30 December 2014 - 01:54 PM
JC does it back at the hotel after a big race
- MSwiss and Danny Zona like this
Posted 30 December 2014 - 03:11 PM
That's twerking....
if you want some entertainment, google "twerking to Beethoven" LOL
#25
Posted 30 December 2014 - 05:36 PM
- Gator Bob and Danny Zona like this
