HELP... A friend of mine has a Micek-Kopriwa top of line Pro 3 controller. It was hooked up wrong. It now only partially works. After looking it over, here is what I know. When hooked up the digital display, choke display, and fans work.
When triggered, all of the controller bingo lights work. Including the blast relay. Yet nothing comes out of the black wire to the motor. I don't see any breakers or fuses. Nothing looks apparently burned or overheated.
Kopriwa is MIA so I am winging it....
I changed out the transistors with no change... ANY IDEAS?
Thank you...
JJ
