I recently used a rattle can of lacquer on some lexan bodies(just 'cause I had it and liked the color). I then backed up the lacquer with some acrylic silver and then acrylic white. I'm a sloppy painter, so there's overspray on the outside of the body. I'd made my usual attempt at getting the overspray off with lighter fluid(naphtha) with the usual results... it kinda works but takes a LOT of elbow grease. So, I decided I'd see if acetone(fingernail polish remover) would work better. It instantly worked better BUT....... the body split just as instantly, about 1 - 1/2" long at the seam above the rear fender! Did I use too much lacquer? Was it the acetone? Thanks in advance.
Question for Noose and other paint experts
Posted 23 November 2015 - 10:13 AM
Posted 23 November 2015 - 10:47 AM
The acetone in it's pure form did it. Ok when mixed with lacquers to spray but not straight. The lighter fluid and elbow grease were the better choice for the acrylic over spray.
- Tex, Tim Neja and garyvmachines like this
Posted 23 November 2015 - 03:44 PM
Tex,
"Parma Body Wash" is the best stuff I've found to clean overspray.
- Tex likes this
Jim "Butch" Dunaway
2000 Jackasses
Posted 23 November 2015 - 06:02 PM
rubbing alcohol 91% works faster than the 70% stuff. one wipe, gone.
- Tex likes this
Charlie McCullough
Charlie's Speed Shop
Kelly Racing Wanna Be
Posted 23 November 2015 - 11:35 PM
I've got the 70%. Is the 91% generally available at the grocery store like the 70%?
Posted 24 November 2015 - 11:24 AM
Now don't go drinking that stuff Rich..............unless you mix it with orange Juice
Posted 24 November 2015 - 11:48 AM
Tex, you might not find it in a grocery store, I don't around here. You might have to try one of the drugstore chains, such as Walgreens, Rite Aid, or CVS.
- Tex likes this
Posted 24 November 2015 - 01:06 PM
I actually have found PURE motor spray works well
- Tex likes this
Posted 24 November 2015 - 01:11 PM
I clean the exterior with Testors Universal Enamel Thinner. It's the red can on the top of the Testors paint rack at your hobby shop.
It cleans lacquer paints as well as cleans and thins any enamel paint they produce.
Won't hurt the plastic body.
I guarantee it!
- Tex and Tim Neja like this
Posted 26 January 2017 - 11:53 PM
Posted 26 January 2017 - 11:58 PM
Safeway sells 99%.
Well, at least here in Oregon.
Posted 30 January 2017 - 06:50 PM
I like to use denatured alcohol or enamel thinner. neither hurt lexan, and work fairly well...
Jeff Bigelow
"It's not about winning or losing the race,
it's about how good you look for the concours judge"
Posted 30 January 2017 - 09:11 PM
Not an expert, but Naptha
Mike Kravitz
