My observations on the H&R.
The front tires are too tall for the axle placement in the chassis.
The guide tongue height was designed by someone who doesn't understand how a slot car works, or thinks walking around the track to put your car back in the slot, is some sort of health benefit.
It's geared for the beginner, but yet needs an experienced racer to modify it and that someone has access to a tire truer.
the H&R Racing chassis is a great platform for Hardbody racing. It is adjustable and can easily be made to handle quite well, just check out the many topics in this blog regarding Hardbody racing in the 1/24 scale forums. B&E Slotsport is good for faster/higher rpm motors, but the faster you go with a plastic model kit body, the worse the damage in a crash.
Glenn,
We seem to have widely different opinions on the H&R.
I'm guessing you immediately add at least another 1/16" nylon guide washer, but from my below picture, I can't figure out why it isn't there to begin with.
What kind of track could the stock height work for?
Braid, .070" over flush, that effectively creates an above track, slot ?
And once you get the guide height right, do you grind the front tires down from 1.090" to .900"(?), or do you just run the stock, astronomical, 5/32"/.157" ground clearance in the front?
I really want to like this car.
The price is right, and the availability from a normal 1/24 commercial track distributor is, of course, a plus for me.
If "Charlie H&R" is seeing this post, please charge $10 more retail and get the car usable out of the package.
Grind the rears a little smaller, grind the fronts a lot smaller, and add that guide washer, making sure the guide nut still holds it's adjustment, sitting that high on the post.
