The ProTrack 4 ½" Chassis is popular in this area. Team it with a 25K minican motor and you have a formula for a good time.
Is anything more than a little screwdriver and wrench needed to put the Pro Track chassis together?
Posted 08 February 2022 - 11:49 AM
Posted 09 February 2022 - 04:08 PM
No, but Loctite is advisable to keep it that way. And you should use a measuring device to make sure the front and rear axles are parallel.
A brace across the front axle uprights is a good idea to avoid front axle misalignment, though a heavy wall shot will bend the entire chassis.
Inverting the guide tongue used to be a good fix but the newer chassis now seem to have integral tongues.
It's at least 60 year-old technology... so don't expect much. And if you maintain an "absolutely stock" rule and everyone is stuck with the same piece, what's the difference?
Pete Varlan
60 years a slot racer
Posted 09 February 2022 - 06:04 PM
No difference. If everybody has the same equipment, that should make for super comptitive racing which translates to a good time.
Posted 10 February 2022 - 11:11 AM
There it is!
Pete Varlan
Posted 10 February 2022 - 02:18 PM
I tend to use metal filled epoxy to strengthen the joint between the chassis and the axle mounting/motor uprights. I don't know if it helps anything but it makes me feel better.
