Tire cleaning station potentiometer?
13 replies to this topic
#1 iceracer
iceracer
  • 100 posts
Posted 15 June 2016 - 04:37 PM
Looking for a little advice.
I plan to construct a tire cleaning station/stand for our new club track. It will be powered by a 10a 30v PS.
I'd like to utilize a potentiometer so the guys can control the voltage to the station instead of the dial on the PS.
Problem is I have no idea what type or size to get.  We run a variety of motors from cheetahs to group 12's
On one of our other tracks we use an old controller but it's not as convenient as it was when it had a potentiometer on it, which has long been misplaced.
Thanks, Terry
Terry Dalton
#2 John Miller
John Miller
    This space for rent
  • 1,150 posts
Posted 16 June 2016 - 07:43 PM
I would like to know the answer to this one as well.
#3 idare2bdul
idare2bdul
  • 5,799 posts
Posted 16 June 2016 - 08:12 PM
Was this originally posted on April 1?
Mike Boemker
#4 iceracer
iceracer
  • 100 posts
Posted 17 June 2016 - 04:38 AM
I don't recall asking this on April 1. If it was please post a link to it and apologies in advance.
Terry Dalton
#5 Samiam
  • 4,774 posts
Posted 17 June 2016 - 06:13 AM
What is a tire cleaning station/stand?
I use a shop rag.
#6 Overdrive
Overdrive
  • 70 posts
Posted 17 June 2016 - 11:12 AM
Iceracer, To use a potentiometer to vary the voltage to a tire cleaning fixture will be fairly cost prohibitive.
You see the resistor will have to absorb the power difference from the P/S and the fixture. A G12 wimpy motor will draw 3+ amps no load. Put a load on the motor and it will climb to 10+ amps pretty easily. 10 amps times 12 volts = 120 watts. Look up the price of 150+ watt pots and get ready for some sticker shock.
Plus you will want to protect your customers from the heat generated. Is will get hotter than a parma turbo running at half throttle for 10 laps.
One thing you could explore is maybe a adjustable tubular power resistor in the 4-10 ohm range. Digikey sells a 225w 10 ohm for about $15. But you will still have to solve the heat dissipation issue.  Think turbo type heatsink but much longer and maybe a small fan blowing on it.
Hope this Helps
OverDrive
Dave Ronsky
#7 MSwiss
  • 25,949 posts
Posted 17 June 2016 - 12:03 PM
I'm still trying to figure out what a tire cleaning machine is.
And why a separate speed control would be necessary / more convenient, than the one on the power supply?
  • Half Fast and Les Boyd like this
#8 iceracer
iceracer
  • 100 posts
Posted 17 June 2016 - 03:19 PM
The tire cleaning area is just a spot to put lighter fluid on the tires and run them against what is basically a board similar to the track surface to clean them. We used to do that on the track but it got congested and messy.
Im wondering if I was using an incorrect term. Perhaps a rheostat is what I need?
Terry Dalton
#9 MSwiss
  • 25,949 posts
Posted 17 June 2016 - 04:16 PM
Again, why not use the power ajustment on the power supply or a controller?
Unless the power supply has to be located away from the block, why not use it?
Also it seems like a controller would also work well because the spring automatically shuts down the power after use.
IOW, no worrying the guy with a "slow" motor left the power level on too high for a guy with a "fast" motor.
#10 iceracer
iceracer
  • 100 posts
Posted 17 June 2016 - 05:15 PM
Good point with using a controller. I was thinking some that use it may be a little heavy handed and the rheostat would be easier to replace than the adjuster on the PS. A sacrificial element if you will. But I do like the idea of power off with the controller...
Terry Dalton
#11 MSwiss
  • 25,949 posts
Posted 17 June 2016 - 05:23 PM
What kind of rubber do you guys use that it needs cleaning with naptha that often?
Are you cleaning glue from out of the pores, or debris off the surface?
#12 Mark Crowley
Mark Crowley
  • 226 posts
Posted 17 June 2016 - 08:45 PM
Like the OP tire cleaning came up at RIR for the Oval track.  Glue is not permitted and cleaning the tires with naphtha apparently helps.  I was asked to build a cleaning station since I built a drag glue station.  The thinking was that putting naphtha on the rough surface and rolling the tires would break up a "glazed" tire surface.
Not really sure what I should build so this tread is interesting?
Mrk
Pics are of the drag glue station I built
#13 Samiam
  • 4,774 posts
Posted 17 June 2016 - 09:15 PM
The blue shop towels pictured are all you need to clean your tires.
Running your  dirty tires soaked with naptha on a test block will only wipe some superficial dirt off the surface.
#14 drrufo
drrufo
    DR Racing Products
  • 359 posts
Posted 18 June 2016 - 09:39 AM
I have a test rig that I use to check the function of the controllers that I build or repair. I have used a potentiometer as well and it worked like a controller. Both pots that I use for sense and braking are 5 watts wire wound and they worked no different than a controller. I would use a potentiometer instead of a controller, it is cheaper to replace.
A pot with 1 meg should work , this is  strictly a educated guess
John Andersen
John Andersen
DR Racing Products
