The "no-brainer" chassis meets "short-light"
10 replies to this topic
#1 JimF
JimF
  • 2,220 posts
Posted 08 August 2016 - 04:19 PM
As mentioned in the previous thread, the No Brainer, the Hybrid and the first two Short-Lights have been very good. The short Hybrid is one attempt to combine the qualities of two different chassis. This is another. All the NB series to date have been built with flat tracks and shorter Hillclimbs, Kinglemans and flattish King tracks in mind. They have all been dependably good, easy to drive and easy to tune. The Short Lights have been very fast but a little harder to find the exact sweet spot with the tires, motor, gearing, and even body choice. So, the Short Hybrid mentioned before was one path to hopefully combine the attributes of two chassis types. This one will hopefully combine the attributes of another two types.
Basic structure:
  • R-Geo shallow, angled face bracket hacked up for weight reduction.
  • R-Geo .040 "GVP" nosepiece.
  • 3 7/8 wb X .875 gl and 49 gr bare. About 89 gr. all up/no body.
  • Single main rail of .078 wire. Pan framework also .078 wire.
  • Initial plan was for single wire for pan frame but I was afraid it would be too light.
Rear Detail:
  • Chopped and channeled bracket.
  • 1/16" brass for the outrigger.
  • Outrigger bracketed fore and aft with .078 wire and "top locked" with .047.
  • Rear stops are 3/32 box tube w/.047 wire stop rod.
Front detail:
  • Tuning fork cutout is filled w/040 brass to match the rest of the nosepiece.
  • S-7 guide tongue on top of stock brass.
  • Hinge rods are .055 in 3/32 round tubes.
  • Front wing stops are 3/32" box tube w/.047 wire. Movement is minimal.
Bottom View:
  • Rick, Jencar17, Mike Jr and 4 others like this
Jim Fowler
#2 Dallas Jackson
Dallas Jackson
  • 323 posts
Posted 08 August 2016 - 05:07 PM
Nice Chassis  !!!!!!!!!!!!!
???-1/29/202
#3 Tom Eatherly
Tom Eatherly
  • 2,169 posts
Posted 08 August 2016 - 10:18 PM
Hmmm, looks good Jim. But, it's got some big shoes to fill with the NB. The NB is just SO EASY to run! Might take a while,but, Fiddler ain't done. :sun_bespectacled:
Tom Eatherly
#4 JimF
JimF
  • 2,220 posts
Posted 09 August 2016 - 12:20 AM
Thanks Tom. Not really meant to fill the shoes (ie; replace) the current NB. This is another test of the shorter car concept and an effort to keep the speed of the shortie while getting at least some of the ease of the NB. Besides.......just another arrow in the quiver while I'm playing with all these variations.
  • Tim Neja and Lee Palmer like this
Jim Fowler
#5 Joexemm
Joexemm
  • 156 posts
Posted 07 September 2016 - 08:01 AM
so when you say chopped and channeled the bracket you mean cut down on the material behind the axle and the two little cut outs where tuning forks would go under the bracket?
and yes im sitting here studying your builds Jim! I will build an A-main car one day!
Joseph Emm
"Success is the best Revenge".... - someone smart.
C.O.W. retro chassis Everyone that runs one knows Checkers or Wreckers
#6 JimF
JimF
  • 2,220 posts
Posted 07 September 2016 - 10:45 AM
Joe:
First, this is a very shallow bracket meaning the axle holes are much closer to the bracket face than standard. So much so that a 27t crown is the biggest that fits. Aside from that, yes. Cut down the material behind the axle and surrounding the bearing holes. Also cut out the top part of the bracket above the motor bushing hole. Honestly, all these gyrations didn't produce very much in the way of net weight savings. I probably wouldn't bother with it again.
Jim Fowler
#7 James Grandi
James Grandi
  • 473 posts
Posted 07 September 2016 - 05:31 PM
You'll get there, you're not that far off. Your cars have a lot of good ideas in them, just needs a little refining. I'd be happy to work with you on setting something up at the track, test & tune it so to speak
  • Tim Neja and Samiam like this
James Grandi
obSCEne Chassis
HVR BB Fronts
Bodies by Weaver
#8 Joexemm
Joexemm
  • 156 posts
Posted 08 September 2016 - 12:18 PM
Thanks James! i think this time around ill be much better prepared. I was building cars like crazy to get them to the guys that wanted to come with me.  Now everyone has one and we can move forward on improving.
Jim i guess you answered my next question too.  Is it worth the extra time. If the net gain is not much and i still have a min weight to reach then there really is no reason to do it.
side note is anyone else having issues using this forum on tapatalk app for the phone?
Joseph Emm
#9 Tim Neja
  • 6,848 posts
Posted 11 September 2016 - 12:06 AM
Tom E used Jim's No Brainer chassis  to knock me out of the A main today in qualifying!!! Nice run Tom--- I got him back in the main with the move up out of the B!! But that No Brainer is FAST!!
  • JimF and Tom Eatherly like this
#10 JimF
JimF
  • 2,220 posts
Posted 11 September 2016 - 12:26 AM
WTG Tom and nice comeback Timmy.
Jim Fowler
#11 Tom Eatherly
Tom Eatherly
  • 2,169 posts
Posted 11 September 2016 - 06:34 PM
Jim,
 Between your chassis and the motor Mill put in there, Gadzooks, I had me a car! It handled so good, I came off once in the eight heats. And that was my fault, certainly not the car. Thanks Jim.
  • Joexemm likes this
Tom Eatherly
