Comm truing problem
Posted 09 January 2017 - 06:58 AM
I have to manually tidy these up with a scalpel, then burnish with a fine ballpoint.
Is it my cutting speed, or depth (about 1thou) or is it just a common issue for everyone?
Starting to irk me...
Steve Meadows
Posted 09 January 2017 - 07:45 AM
I got the same result when truing up cheap Chinese crap (CCC).
Posted 09 January 2017 - 07:46 AM
Hi Steve,
The finish does look fine, and the issue you have is really not an issue at all.
The comm metal's (copper) hardness can and does vary, which will affect the way it cuts/machines. The width of the slots can also vary which can have an effect on all this... as well as your tooling.
When you're done making your cut, just drag (don't push) the back (not the cutting edge) of a #11 X-Acto blade down each slot starting at the bottom (near the tabs) and finishing at the top. The blade's thickness is generally a good fit for the comm slots and will do a nice job cleaning out whatever gets in there.
- Rob Voska likes this
Posted 09 January 2017 - 07:52 AM
When I used to cut arms I would use a US government ball point pen and smooth out all three comm breaks. It was something about the size of the ball in the pen that was perfect.
Jeff Strause
Posted 09 January 2017 - 09:25 AM
I've cut 1000's, and sometimes, they will cut, leaving zero debris in the slot.
John's technique of cleaning out the slots is the typical production method. You're sort of shoveling out the debris, not cutting or picking it out. No reason to put anything sharp in there, unless some epoxy has wandered in during production.
On my own arms, I typically used a piece of .014" thick mylar, cut from wing car diaplane material. I never did any ball point burnishing, production or for personal use.
That burr should arc away, quickly, in break-in.
Posted 09 January 2017 - 12:02 PM
Clean it out with 8.5 x 11 printer paper cut in a strip.
Never use anything hard to clean the slot. Ball point pen tips are hard and remove the sharp comm slot line which is counter productive to preserving the life of the comm.
