Hello,
I will be happy to answer any questions you may have concerning airbrushing, masking, paints etc.
I would like to thank all of you for your support over all these years.
Bob Hughes
Kool Bodies
Posted 22 January 2017 - 05:47 PM
Posted 22 January 2017 - 07:34 PM
Hi Bob! Good to see you on here.
Posted 22 January 2017 - 09:54 PM
Posted 23 January 2017 - 08:52 AM
Thanks Bob, Would you have any experience or advice about using Tamiya's masking tape for curves ?
Mikey
Posted 23 January 2017 - 08:56 AM
I use Mirror Chrome Spaz Stix, let it dry for 24 hrs then apply the Black Backer ThanksI think you painted this body, Bob. What type of chrome paint did you use? Thanks
Posted 23 January 2017 - 09:28 AM
Beautiful body, Bob. What do you use to outline the patterns and detail work? Thanks.....
Don Weaver
L.H. Lapham
it will starve to death...
Posted 23 January 2017 - 05:34 PM
Hi Don I use Stabilo OHPen S pen
Posted 24 January 2017 - 11:24 AM
Thanks for the tip on the pen Bob. Nice to see you here.
You always pick me up (inside joke)
Cheers
Faster then, wiser now.
Posted 24 January 2017 - 03:14 PM
I have a couple bodies I would like to paint, but I'm hesitant due to the lack of masking for the windows. What process do you use to make masks for windows when needed?
Posted 24 January 2017 - 03:17 PM
Welcome to Slotblog Bob!
Becoming a fan.
Posted 24 January 2017 - 05:06 PM
Hi Jairus I use windshield retention tape , you can buy at a glass shop that installs windshields made by CRL co. It is 1 1/2 wide. Lay it inside the body windshield and trim around the patten of the windshield and side and rear windows, be steady and also I use X-Life #11 blades extra Sharp they are the best. I hope I was if help. Good luck! BobWelcome to Slotblog Bob!
Becoming a fan.
Posted 24 January 2017 - 06:36 PM
Bob, do you use the windshield retention tape just for window masking, or do you also use it for masking numerals & other large body areas? Did you settle on one paint manufacturer's brand when the Pactra became difficult to obtain? Any truth to last fall's rumor.that you & a partner might open another Londonderry raceway?
Posted 24 January 2017 - 07:10 PM
Hi Bill you can use it for any masking also Bob Lively liquid mask is great to use. What ever works. Spaz Stix paint is by far the best paint for lexan , I also use it on my wood carvings I believe you saw at the raceway. It is pre mixed ready to shoot, needs good venting and to wear a good mask. Light and Bright!!. As far as a raceway goes, there is no loyality from racers that buy on line. Your working on 40% out of that all the bills and what's left. So no Raceway. No partners
Posted 24 January 2017 - 07:30 PM
Thanks Bob!
Posted 25 January 2017 - 03:02 PM
Posted 25 January 2017 - 04:20 PM
Yeah, I was just saying hi.
I have my own tricks for masking and some experience painting.
Posted 25 January 2017 - 05:27 PM
Thanks Kevin my email is witchcarver@comcast.net
You do really nice work. What is your contact info?
Posted 25 January 2017 - 05:31 PM
Hi Jairus send me some pics of your cars thanks Bob
Posted 25 January 2017 - 05:51 PM
I have a section on this forum.
http://slotblog.net/...s-in-the-attic/
We also have other painters here.
Not saying the block is full as I think the work you do is beautiful the block has plenty room for another.
Posted 26 January 2017 - 11:13 AM
Hi Jairus I know Peter Lentros I saw your work, Very Trick! Nice
Posted 26 January 2017 - 09:37 PM
@Jarius, can you either describe your method of window masking, or direct me to your forum topic describing it? I thank you in advance.
Posted 26 January 2017 - 10:39 PM
John, I use 3m #2080EL masking tape and cut it with a very sharp blade.
Super simple and the material doesn't bleed or shrink when the paint hits it.
It's a tape artists use for airbrushing. And the only place in Salem I can buy it is at an art supply store.
Low tack and leaves no adhesive behind.
Posted 30 January 2017 - 07:02 PM
I use frogtape delicate surface yellow tape....low tack. You can find it at home depot or lowes
my technique is to place a piece of tape on the inside of the body, and the use a crayon and rub it sideways across the inside of the window. it makes a fine line you can use to cut the tape after you remove it from the body...
Hey Bob- missed seeing you at the Hillbilly Nats this month...
Jeff Bigelow
"It's not about winning or losing the race,
it's about how good you look for the concours judge"
