Time for a new power supply
45 replies to this topic
#1 Mr. M
Mr. M
  • 585 posts
Posted 14 February 2017 - 09:31 PM
My 1981 vintage power supply is fast fading and although it has been very loyal, it is time for a new one. I built the last one and am in the process of building the new one. If there is interest in seeing this, I will post pictures of the build. This is a bit different than the typical build here, so I am gauging if the forum would like to see this.
Chris McCarty
  • Samiam, Mark Crowley, Mach9 and 5 others like this
Chris McCarty
#2 Mach9
Mach9
  • 164 posts
Posted 14 February 2017 - 09:48 PM
Absolutely !
Mack Johnson
'86 Mustang footbraker
6.435 @ 104 MPH
NC Slot Car Tracks - Past and Present
#3 Bill from NH
  • 14,760 posts
Posted 14 February 2017 - 09:49 PM
I'm not currently in the market for another PS, but yes, I'd like to see what you're building.
#4 old & gray
old & gray
  • 1,208 posts
Posted 14 February 2017 - 09:57 PM
Yes I would like to see this. There is room and desire on this board for discussions of the electric part of our hobby.
Bob Schlain
#5 gotboostedvr6
  • 2,321 posts
Posted 14 February 2017 - 10:13 PM
Better post very detailed pictures and step by step instructions or else!
  • Les Boyd and grooverunner like this
David Parrotta
#6 SlowBeas
SlowBeas
    Troublesome De-slotter
  • 1,010 posts
Posted 15 February 2017 - 10:51 AM
I'd also love to see your construction. Are you planning to build one that's reasonably small, or something that will power several demanding motors at once?
Jim Beasley
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
#7 Dushkwoneshe
Dushkwoneshe
  • 185 posts
Posted 15 February 2017 - 11:01 AM
Would be very interested to follow along
with your build...
John Wheeler
Certified Trigger-Finger Fitness Trainer
#8 Samiam
  • 4,772 posts
Posted 15 February 2017 - 07:14 PM
Scratch building a power supply fits right in along with the chassis, motor, and body scratch building  threads.
Please go right ahead and thanks in advance for doing it.
#9 Mr. Hollywood
Mr. Hollywood
  • 35 posts
Posted 15 February 2017 - 07:58 PM
yes please
Joseph Gerencser
#10 Mr. M
Mr. M
  • 585 posts
Posted 15 February 2017 - 11:12 PM
Yes, this is reasonably small, but not compact form factor.
No, this is only a single motor supply.
Yes, this is what I would call a high power supply, around 10A max.
I plan to show the current supply that will be retired, it will provide some humor I think!
After all, it was 1981 when built.
  • garyvmachines likes this
Chris McCarty
#11 Mr. M
Mr. M
  • 585 posts
Posted 25 February 2017 - 12:38 AM
This is the incumbent nearing retirement. It has done time in Centerville, Houston, Chicago, Cincinatti, Orlando, Kansas City, Detroit, and Clovis where it was drop kicked by the airlines and took 2 days to repair. The design is pretty simple, a variac in front of a transformer driving a 4 diode bridge with a hefty cap on the output of the bridge. There are AC plugs on the back for Dremel, soldering iron, and light. The case came from Radio Shack and everything else is surplus from Skycraft in Orlando. The whole supply probably cost $75. It would put out over 10A @ 15V all day. Now the connections are quite unreliable and the variac and transformer have internal shorts from airline abuse.image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
  • mdiv and Clyde Romero like this
Chris McCarty
#12 Mr. M
Mr. M
  • 585 posts
Posted 25 February 2017 - 08:49 AM
I built several of these for local racers, much cleaner looking fabrication than this one. Only known survivor is one with Terry Tawny who tells me it is still in use. They worked for everything from open, or Group 7 back in the day, motors to today's retro Hawks.
Chris McCarty
#13 Zippity
Zippity
  • 5,278 posts
Posted 25 February 2017 - 03:26 PM
I want to know how you get it to stick to the ceiling and why would you do that?  :)
#14 anarot
anarot
  • 106 posts
Posted 25 February 2017 - 04:36 PM
Because they are on the opposite side of the world so therefore everything is upside down lol. The pictures are upside down. TM dose the same thing when I post pictures  using my new phone as well for some reason.
Trevor Neilson
#15 Zippity
Zippity
  • 5,278 posts
Posted 25 February 2017 - 06:17 PM
Ever thought that maybe you are holding your cell phone upside down when you are taking your photographs? :)
#16 Mr. M
Mr. M
  • 585 posts
Posted 25 February 2017 - 08:56 PM
Nope, all is good, they are right side up. Greg?
Chris McCarty
#17 Zippity
Zippity
  • 5,278 posts
Posted 25 February 2017 - 09:06 PM
Chris,
I was just pulling your chain :)
#18 Mr. M
Mr. M
  • 585 posts
Posted 25 February 2017 - 09:07 PM
I know, pulling it back...
Chris McCarty
#19 anarot
anarot
  • 106 posts
Posted 26 February 2017 - 03:32 AM
Ummm. arn't you suppose to stand on your head when taking photo's lol. tried turning it around but TM still rotates them.
Trevor Neilson
#20 Zippity
Zippity
  • 5,278 posts
Posted 26 February 2017 - 04:53 AM
Don't blame TM for your inability to use a camera correctly :)
#21 Mr. M
Mr. M
  • 585 posts
Posted 26 February 2017 - 07:35 AM
This is the new one. The front panel has analog volt and amp meters. I like analog because you can see variations for both at the same time and is more responsive than digital. To the right is the power switch, power on light, and fuse. Voltage control is the knob above the banana plugs. I like these plugs because you can either use a plug or tighten down on a wire.
The handles are mainly to protect the front panel along with providing a convenient carry.
The back has 120V AC plugs, power switch, AC fuse, and overall box fan. Eventually there will be a plug power on light on top of the case.
Most of the box and hardware are surplus from Skyscraft in Orlando or Frys Electronics. Wherever possible, I use industrial grade fixtures and hardware. The box is structural aluminum and was repurposed from a toll road controller.
  • MSwiss, boxerdog and grooverunner like this
Chris McCarty
#22 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,628 posts
Posted 26 February 2017 - 09:22 AM
Chris you said the whole original unit cost around $75, but variacs weren't cheap then and are not cheap now. How did you do it?
Cheers
Faster then, wiser now.
#23 Mr. M
Mr. M
  • 585 posts
Posted 26 February 2017 - 02:13 PM
The answer is a good surplus place where they are used or new old stock. You can find them for about $20-25! Skycraft in Orlando, FL is amazing for stuff like this. Alternativly you can use a 100 W variable power resistor on the DC side, if you can find one. I have built them this way too.
Chris McCarty
#24 Mr. M
Mr. M
  • 585 posts
Posted 26 February 2017 - 05:40 PM
If you want a new old stock variac, I have one left for $25 plus shipping that I would be glad to share.
Chris McCarty
#25 Mr. M
Mr. M
  • 585 posts
Posted 26 February 2017 - 08:59 PM
The top view shows all the major components with the lid off. The front panel has the volt and amp meter on the left, filter cap behind it and the power switch, light, banana plugs on the right. The variable resistor is just above the banana plugs.
The big brick is a AC to DC regulated power supply,120V AC in, 12V DC @ 10A out. This is way overkill for this application, but again it was $20 at Skycraft in Orlando, FL. This is probably $150-200 new off the shelf. In the back you can see the AC plugs, fan on the left, and on the right the AC switch, fuse, and power on light.
The total cost is about $100. You can buy an off the shelf supply for not much more than this, but by building this I can have it the way I want it.
  • C. J. Bupgoo likes this
Chris McCarty
