Legal chassis?
26 replies to this topic
#1 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 11:04 AM
Rails attached per rules, close-up shows attachment to motor bracket.
  • Tater likes this
Bill Fulmer
#2 Noose
Noose
  • 23,333 posts
Posted 06 March 2017 - 11:13 AM
IMO no since if all else was removed that structure would not support the car.
  • JerseyJohn likes this
#3 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 11:18 AM
Bill,
What thickness is that rail?
#4 mppicione
mppicione
  • 167 posts
Posted 06 March 2017 - 11:20 AM
Looks nice!!!! Good luck.
Marc Picione
#5 Cap Henry
Cap Henry
    CHR Cars
  • 3,406 posts
Posted 06 March 2017 - 11:32 AM
What rule doesn't it meet? There's no rule saying if you picture it without everything else it has to support itself. That's not a partial rail on top of brass plate, so it doesn't have to meet the .047 minimum. So unless there's a rule I missed it's legal.
Definitely creative and knew that was going to happen at some point LOL
  • brnursebmt, JHMerriman and The Number of like this
#6 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 11:34 AM
.023". But that makes no difference if I read the rules correctly.
Bill Fulmer
#7 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 11:51 AM
I like my cars flexible. :)
  • Jason Holmes likes this
Bill Fulmer
#8 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 12:01 PM
"An additional restriction being imposed is that bracing or partial rails soldered atop brass plate to "complete" a main rail structure can be no smaller than .047" diameter."
Since there are no other legal main rails, effectively, that .023" wire qualifies as the bracing, that makes the chassis illegal, and falls under the .047" minimum rule.
IOW it's the only thing that completes a main rail structure, so it has to be .047" minimum.
#9 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,628 posts
Posted 06 March 2017 - 12:09 PM
Mike don't you mean illegal, not legal?
  • The Number of likes this
Faster then, wiser now.
#10 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 12:11 PM
The .023" rail is solid from motor bracket to nosepiece so it meets the requirements of the rules as a main rail not bracing?
Bill Fulmer
#11 Eddie Fleming
  • 2,956 posts
Posted 06 March 2017 - 12:12 PM
This is becoming a game of beating the rule rather than good building practices.
  • MSwiss likes this
#12 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 12:16 PM
That .023" wire is the main rail structure.
Where does it say the structure has to be multiple pieces?
#13 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 12:20 PM
Being involved in the tech inspection end of many races all I am attempting to do is close a loophole. Not trying to circumvent the rules but clarify.
  • Danny Zona likes this
Bill Fulmer
#14 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 12:21 PM
Correct.
Adding 2 short pieces of .047" wire to the pictured chassis, to the outer rails, doesn't create any "hardship" to the racer, and they can still leave on that .023" wire if the feel it is a handling benefit.
#15 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 12:23 PM
Sorry, Mike, I am not getting your point here, a lifttke confused.
Bill
Bill Fulmer
#16 Half Fast
Half Fast
  • 2,628 posts
Posted 06 March 2017 - 12:26 PM
So the chassis as pictured in post#1 is:
1- Legal
2-Illlegal
Which one? :unknw:
#17 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 12:28 PM
Bill F,
What else is the legal main rail structure?
There are no other ones.
It sounds like you just want us to reword the rule.
#18 The Number of
The Number of
  • Guest
  • 1,692 posts
Posted 06 March 2017 - 12:31 PM
Again just looking to close what I see as a loophole in the rules. Nothing personal or anti-IRRA®.
Bill Fulmer
#19 Cap Henry
Cap Henry
    CHR Cars
  • 3,406 posts
Posted 06 March 2017 - 12:42 PM
I understand Bill's point.
The way the rules are written now, there is only a minimum rail size if the wire is multiple pieces and it's a brace on top of brass sheet. That is not multiple pieces or on top of brass sheet, it's sole purpose is connecting the front and back.
Would that rail support the car on its own? No. But that's not a rule that it has to. Bill is pointing out a very obvious loophole that I tried pointing out too.
#20 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 12:45 PM
Bill, Cap,
So it sounds like you want us to add "or the main rail itself" to the the above passage, because you don't consider your single .023" rails as the main rail structure, in our wording.
I do, as there are no other legal main rails.
You might want to straighten out THIS seller on eBay while you are at it. LOL.
#21 Eddie Fleming
  • 2,956 posts
Posted 06 March 2017 - 12:52 PM
To me the very name main rail states that it is the primary connecting and strength structure of the chassis. In this case that is certainly not the case. That makes the small wire bracing and not main rails.
#22 Phil Hackett
  • 5,720 posts
Posted 06 March 2017 - 12:53 PM
Roger Penske says he's proud of all of you...  :shok:  :laugh2:
  • S.O. Watt, Half Fast, The Number of and 1 other like this
#23 Cheater
  • 25,737 posts
Posted 06 March 2017 - 01:00 PM
I believe what Bill wants us to do is to specify a minimum main rail diameter, which I feel we cannot do as there are too many building multi-piece mail rails out of fairly small diameter wire.
  • 911GT3 likes this
#24 Cap Henry
Cap Henry
    CHR Cars
  • 3,406 posts
Posted 06 March 2017 - 01:02 PM
Why the need to make this personal? No one is attacking the IRRA® or any of the BoD.
You could just as easily put a piece of .023" flat, not on top of any brass sheet, and have it go into notches in the nose piece, and then still have the other rails and it is technically a legal car. Is it nit-picking? Yes. But it's still a possibility that can be done and currently legal. Then it becomes up to the tech guy as to what is perceived as legal. Bill simply wants to eliminate the perception issue.
If a main rule minimum diameter is the answer, IMO it needs to read more like the rails combined diameter/width needs to exceed .062" or maybe more. Saying minimum of .047" eliminates all the .039/.032" wire cars.
  • Cheater and Tom Thumb Hobbies like this
#25 MSwiss
  • 25,953 posts
Posted 06 March 2017 - 01:07 PM
Go to the first sentence of the fourth paragraph, in the below thread, where we address legality issues with this new chassis.
IRRA® chassis main rail construction clarification
