Iso Design Chassis
#26
Posted 28 April 2008 - 07:26 PM
11/6/54-2/13/18
Posted 29 April 2008 - 07:17 AM
Posted 29 April 2008 - 07:29 AM
When limited glue came into being it was right at the same time as PdL's "Diamond" style chassis was born and that was the better design. It was the next step in the evolution to no wheels at all. We still ran Isos on certain tracks for some time after that, especially at our two Engleman tracks, Clementon and Elmsford.
Posted 29 April 2008 - 07:48 AM
Sir, when did the drop arm cease being dropped?? In other words when did it become soldered solid as a center section? (Say that ten times fast!)
As always,
Thanks!!
GTP Joe Connolly
In theory there is no difference between theory and practice.
In practice there is.
#30
Posted 29 April 2008 - 08:36 AM
Posted 29 April 2008 - 10:59 AM
The Midwestern guys commonly didn't use drop arms. I did both Midwest stuff and more SoCal stuff. In '66 at a race on an American black using a SoCal type piano wire car, the '66 Ferrari that Keith photographed at the convention, I broke the hinge at the end of a heat in a crash, ran over to the bench to hurridly solder it up, got solder in the hinge. And it went faster. Did a few tests and didn't use a drop arm again.
P is the first pro to openly mention in the press that he didn't do drop arms.
Fate
3/6/48-1/1/12
Posted 29 April 2008 - 11:35 AM
In D3 there is a different rule for tech in that the guide can't be used that way. There is a hole for the guide to go through and the front wheels must support the weight of the chassis. I can't remember any other tech ever doing this but we have had few complaints.It makes more work for the tech crew. The chassis will have to be teched on a block with a recess equal to that of the track so the guide is against the "braid" supporting the weight of the center section, clears .015" in the front and the front wheels are touching.
Mike Boemker
#33
Posted 29 April 2008 - 11:37 AM
While PdL raced in our recent Legends of the 1960s Race I think his fame(infamy?P is the first pro to openly mention in the press that he didn't do drop arms.
Mike Boemker
#34
Posted 29 April 2008 - 11:41 AM
Mike,In D3 there is a different rule for tech in that the guide can't be used that way. There is a hole for the guide to go through and the front wheels must support the weight of the chassis. I can't remember any other tech ever doing this but we have had few complaints.
SERRA techs cars the same way: only the front wheels support the front of the chassis during the checking of the front chassis clearance. I believe this is identical to what IRRA does as well.
#35
Posted 29 April 2008 - 11:48 AM
#36
Posted 29 April 2008 - 12:36 PM
Posted 29 April 2008 - 12:42 PM
Mike Boemker
#38
Posted 29 April 2008 - 12:45 PM
Basically yours and the Foamster's drop arm cars technically can run illegal on the track. LOL.
