Building a dyno question
40 replies to this topic
#1 Tampabay racer
Tampabay racer
  • 740 posts
Posted 31 May 2017 - 02:52 PM
Would a four-blade fan blade that s about 2 inches tall, be enough drag on the motor to be useful if I was using a photo tach on the fan blade?
I'm looking to build some sort of a dyno, so I don't have to have the motor in a chassis.
Brian Ambrose
#2 gotboostedvr6
  • 2,321 posts
Posted 31 May 2017 - 02:58 PM
4" x 2.5" is the best prop to start with
David Parrotta
#3 swodem
swodem
  • 1,176 posts
Posted 31 May 2017 - 05:56 PM
Personally I wouldn't use a prop screw. It loads up the bearings/bushings with a high level of thrust not designed for.
I would use a weight.
Steve Meadows
#4 Tampabay racer
Tampabay racer
  • 740 posts
Posted 31 May 2017 - 07:06 PM
That makes since, however wouldn't an angled gear do the same thing... making thrust?
Brian Ambrose
#5 gotboostedvr6
  • 2,321 posts
Posted 31 May 2017 - 07:46 PM
Never gave me trouble. Gotta oil liberally.
David Parrotta
#6 swodem
swodem
  • 1,176 posts
Posted 30 July 2017 - 08:25 PM
No, it just improves mesh.
Steve Meadows
#7 Bazzie
Bazzie
  • 140 posts
Posted 02 August 2017 - 07:06 PM
Drive a larger prop/fan through gears, that way you can avoid the thrust and change motor loading as required.
Eben Brand
#8 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,299 posts
Posted 02 August 2017 - 07:11 PM
Does someone have a slot car motor dyno that can post a picture? Video?
Charlie McCullough
Charlie's Speed Shop
Kelly Racing Wanna Be
#9 bbr
bbr
  • 2,434 posts
Posted 02 August 2017 - 08:03 PM
i think a dyno is good info if the motor tested was a precision-made motor.
With Retro motors, the on-track heat cycling determines the quality of a motor. Until it is run on track you don't know what you have.
  • CoastalAngler1 likes this
Mike Low
#10 crazyphysicsteacher
crazyphysicsteacher
  • 369 posts
Posted 03 August 2017 - 07:37 AM
Try the Simple Dyno website.
The site has a program that can be used to build a dyno from.  ry using a 2 mm shaft gear to mount the small magnet the program requires.
Any dyno really lets you make comparisons on it. So your system will work for you but will be really hard to compare to other results. I say keep going, there is merit to having a way to compare motors.
I suggest using a system that lets you screw in the motor like you do in a chassis.
Then use a belt drive system, like Pro Track or Parma make for rentals, to load a second wheel that spins to read the data. It will be more complex but will allow you to load the motor bushings how they will be used.
The important part of this is to be able to program in a voltage increase and rate of increase to measure voltage versus RPM change to compare how each test motor accelerates.
Let us know how it turns out.
Chris Wendel
Silver Side Down Racing
Silver Side Down Graphics
#11 Tampabay racer
Tampabay racer
  • 740 posts
Posted 03 August 2017 - 07:56 AM
Not looking to build a dyno any longer.
Brian Ambrose
#12 MSwiss
  • 25,945 posts
Posted 03 August 2017 - 08:29 AM
Have you had success with it?
IOW, has it identified the motor that is fastest on the track?
#13 Tampabay racer
Tampabay racer
  • 740 posts
Posted 03 August 2017 - 08:51 AM
I last night was the first time I've used it. Also going to be getting/building a chassis dyno.
Brian Ambrose
#14 tonyp
  • 15,325 posts
Posted 03 August 2017 - 09:04 AM
I've never had a 'bad on the dyno' motor run good on the track. Same with my chassis dyno, if it's good, it's good on the track. Saves a lot of thrashing on race morning.
  • MSwiss likes this
#15 Noose
Noose
  • 23,330 posts
Posted 03 August 2017 - 09:33 AM
Once you have readings from the Trinity dyno and if you have a rolling dyno, you can correlate the readings to performance on the various tracks for sure. With the five tracks we have here in our series, I know the hi amp ones run better at certain tracks than do the low amp ones.
The rolling dyno results have proven very reliable for a given motor in a given car.
#16 Shooter7mustang
Shooter7mustang
  • 215 posts
Posted 03 August 2017 - 10:51 AM
Is the Trinity still available ?
Kevin Myhaver
Bad Dog Racing
Color Me Gone
#17 tonyp
  • 15,325 posts
Posted 03 August 2017 - 04:07 PM
No, haven't been for years, but we sold a ton for brushed RC motors. Since RC went brushless they are no longer usable, so there has to be a couple of thousand out there.
#18 bbr
bbr
  • 2,434 posts
Posted 03 August 2017 - 07:35 PM
http://www.ebay.com/...F6KRmb-o5DQmMjQ
I made this work with slot car motors
Mike Low
#19 bbr
bbr
  • 2,434 posts
Posted 03 August 2017 - 08:55 PM
made an adapter to position the slot motor, will post a picture when I get home tonight.
what I really want is a fantom like dyno.
this company make this, I think it can be modified to work with slot motors
Mike Low
#20 dalek
dalek
  • 892 posts
Posted 06 August 2017 - 01:57 PM
Even though Brian went a different route, I'm posting what I built.  The rig lets me compare motors to each other.
It's still a work in progress, but it looks like I'll eventually test each motor with two props.  A prop that causes about a 3.5 amp draw at 6 volts and a smaller prop that causes about a 3.5 amp draw at 12 volts.
  • Phil Smith, Rob Voska, Samiam and 1 other like this
#21 Tampabay racer
Tampabay racer
  • 740 posts
Posted 06 August 2017 - 02:59 PM
Very interesting Dale.
Brian Ambrose
#22 gotboostedvr6
  • 2,321 posts
Posted 06 August 2017 - 05:51 PM
Are you using eagle tree?
David Parrotta
#23 dalek
dalek
  • 892 posts
Posted 07 August 2017 - 07:14 AM
I didn't know what eagle tree was so I searched for it.
I assume you are wondering if I use one of their sensors, such as airspeed or what not.
What you see in the pictures is all that I use.
The tachometer tells me when one motor is more powerful than another.
#24 gotboostedvr6
  • 2,321 posts
Posted 07 August 2017 - 07:32 AM
Does the tachometer use a optical sensor?
David Parrotta
#25 gotboostedvr6
  • 2,321 posts
Posted 07 August 2017 - 07:34 AM
Edit. I see the sensor in the pic :)
David Parrotta
