Dynamic Bandit/Super Bandit repop Thingie body
25 replies to this topic
#1 Tim Wilkins
Tim Wilkins
  • 1,497 posts
Posted 18 February 2018 - 11:06 PM
Who currently manufactures and sells a good repop of the Dynamic Bandit/Super Bandit thingie body? Any info would be helpful.
Thanks.
#2 Pablo
  • 18,447 posts
Posted 19 February 2018 - 09:33 AM
I got one from Ray Fellows. If have another, you want it?
#3 Jairus
  • 10,174 posts
Posted 19 February 2018 - 11:47 AM
TrueScale has one.
When his web site is up.
#4 Tim Wilkins
Tim Wilkins
  • 1,497 posts
Posted 19 February 2018 - 11:59 AM
Jarius, the TrueScale website was the first place I checked. They have a limited number of bodies showing
but no Bandit repops. In fact, the Bandit on their website seemed to disappear even while TrueScale was in full scale operation.
#5 Tim Wilkins
Tim Wilkins
  • 1,497 posts
Posted 19 February 2018 - 02:00 PM
Clear bandit body located.  Thanks everyone  :good:
#6 Tim Wilkins
Tim Wilkins
  • 1,497 posts
Posted 12 April 2018 - 04:51 PM
Special thanks to Jairus Watson locating a TrueScale reproduction Super Bandit  body and a superb paint job! Also to Pablo for providing the front decal.
  • Jairus, Jencar17, Maximo and 2 others like this
#7 Jencar17
Jencar17
    JenCar17
  • 325 posts
Posted 12 April 2018 - 05:26 PM
:good: :victory: :clapping: :good: :victory: :clapping: :good: :victory: :clapping: :)
Jens Graf
#8 Pablo
  • 18,447 posts
Posted 12 April 2018 - 06:43 PM
Verrrry sexy :good:
#9 Martin
  • 4,207 posts
Posted 04 May 2020 - 04:56 PM
I have my Super Bandit chassis front and center and I am wanting to paint my repop body made by Gene the correct black.
By correct I mean when I was doing my original black Dynamic Mirage save I noticed the blacks I had were brown-ish when in the light hit it a certain way.
I want that blue black in a rattle can if possible. Example below.
Any help would be appreciated.
  • Lou E likes this
#10 Lou E
Lou E
  • 78 posts
Posted 04 May 2020 - 08:33 PM
Cool car, can you share some more pictures please?
Lou Esteves
#11 Martin
  • 4,207 posts
Posted 04 May 2020 - 10:31 PM
Thanks Lou, here is a link for that car.http://slotblog.net/...4-dynamic-save/
My intention was to get some help with the Super Bandit paint . It just happens to be the same black.
#12 Martin
  • 4,207 posts
Posted 07 May 2020 - 03:37 PM
I have my super Bandit roller done and sitting on the test block.
Question,
              If you use the stock front wheels from the standard Bandit it lifts the guide out of the slot.
My conclusion is the Super Bandit had smaller tires.
Request,
Anybody out there got a Super Bandit they can put a caliper on and if possible take a pic of that front wheel and tire?
Thanks for your help.
Trying to get this correct.
#13 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 07 May 2020 - 04:29 PM
Maybe they used a guide spacer?
Rotor
Jeff Chambers
                                         "Kinky Kar"
#14 Martin
  • 4,207 posts
Posted 07 May 2020 - 04:45 PM
Jeff I thought of that, and I did do that. You have to add so many that the collar would be higher than the post.
Yes, you could put spacers under the axle blocks too. But I do not think Dynamic did any of that.
The center of axel to the bottom of the frame is .350" so add the ground clearance lets say .06" +.41" double that and you get .820" for the tire diameter.
The standard Bandits wheels are .880" so way to large.
#15 MattD
MattD
  • 3,561 posts
Posted 07 May 2020 - 06:41 PM
Martin, what  is a caliper?       Inside joke, because I am such a hack.
#16 Martin
  • 4,207 posts
Posted 07 May 2020 - 06:54 PM
"we don't need no stinking calipers", we can eye ball  .005'' :good:
At least you didn't think I was putting front brakes on the Bandit. :laugh2:
#17 Martin
  • 4,207 posts
Posted 07 May 2020 - 09:09 PM
Is this the stock tire ? (.810''D) it dose not fit width wise but it came with the car and the diameter is perfect.
Standard Bandit on the right.
#18 MattD
MattD
  • 3,561 posts
Posted 07 May 2020 - 09:54 PM
I was going to ask you what kind of calipers you used.   I am familiar with the Pinto which  is common to so  many street rods and customs.    68 and up Camaro is a pretty common conversion, too.    .I know a little about those calipers.
#19 Martin
  • 4,207 posts
Posted 13 May 2020 - 12:48 AM
 I was concerned I would mess this operation up, a slip of the knife or getting the slots in the wrong place. But I am happy with the way it turned out.
Did make a template and modify two blades to make it easier. Really need to make a hand punch for next time :crazy:
  • Pete L., MattD and Tim Wilkins like this
#20 MattD
MattD
  • 3,561 posts
Posted 13 May 2020 - 10:17 AM
I tried modifying one of those punches they make for scrap booking.   You  can take the tool apart and grind the male part to the right size, but the female side is then much bigger and you can't get a clean cut.   The only solution,  I see is to weld up the female side and re cut the slot to tightly fit the now smaller male side.    I guess you would do this on a milling machine,     Outside of welding the slot shut, the rest is not within my capabilities.     They do make a 1/16 round punch that I found could be used to make each end of the slot and then you can cut from one to the other.   That leaves a rounded end on the slot, but with a blade cut to the right length as Martin showed, you can get a pretty nice cut.   I figure I'll do another 10-20 and be able to get that nice cut!!!
#21 Martin
  • 4,207 posts
Posted 13 May 2020 - 10:43 AM
I have one of those slot punches. Mine is 1/8'' by 1/2''.
The slot we want for the Bandits and Renegade is .040'' by .250'' ish.
If there is a need I will make a hand punch?
#22 MattD
MattD
  • 3,561 posts
Posted 13 May 2020 - 02:07 PM
Martin, I doubt  if we need a tool.    Probably not that many guys slotting those bodies.   Using the  wide blade like you showed is all you really need and you would have a lot of time in making a tool when  you should  be working on some of your projects!!!!
#23 Larry Horner
Larry Horner
  • 461 posts
Posted 15 May 2020 - 09:13 PM
Wow Martin, you did a great job cutting the mount holes. I was so stressed about it that I finally punted the job off to Pablo (he too did great job). That motor looks like a real veteran ... can't wait to see the finished car!
#24 Martin
  • 4,207 posts
Posted 15 May 2020 - 10:25 PM
Thanks Larry, can you post a link to your Bandit build?
Was yours a Super Bandit and what were the size of your front tires?
#25 Larry Horner
Larry Horner
  • 461 posts
Posted 17 May 2020 - 01:27 PM
Mine was just a regular Banding ... here is the link: http://slotblog.net/...of-two-bandits/. Pablo discusses the front tires on page three but to cut to the chase, they too were originally .880 and he cut them down to .815 to give my car a 1/16" ride height. But since the SB has a different front end, those measurements might not apply.
Here is a link from the LASCM website where Philippe mentions the tires on the SB were smaller diameter than those on the original Bandit (http://lascm.com/Slo...roducts_id=6419). Philippe if you're following along, do you happen to know the actual diameter?
