Pinning a motor endbell oilite
44 replies to this topic
#1 MSwiss
  • 25,939 posts
Posted 04 April 2018 - 05:43 PM
While pinning some guide shoes, I tried this and was surprised that it was relatively easy to do.
It has a piece of .045" wire keyed into a hole that is not quite drilled through the body of the oilite
  • Tex, havlicek, bbr and 1 other like this
#2 Pablo
  • 18,466 posts
Posted 04 April 2018 - 05:54 PM
Nice. I'm going to need that trick sooner or later :good:
The PS EB I adapted onto a 13uo motor yesterday had a loose bushing.
Question, is that red stuff Loctite, and does it adhere well to the EB material?
#3 gotboostedvr6
  • 2,321 posts
Posted 04 April 2018 - 05:58 PM
Mikes solution looks great for a sealed fk.
If your not running sealed motors it's best to shoot the endbell and oilite with brake clean or your choice of acetone and use JB weld or other super strong, slow curing epoxy to set the bushing.
JB has never failed me
David Parrotta
#4 swodem
swodem
  • 1,176 posts
Posted 04 April 2018 - 06:05 PM
Why do you need something so strong to stop an oilite spinning?
It’s not like the arm shaft can really grab it...
In my mind, I can only really see vibration making the thing turn, but surely it will stop at the point of least resistance, which is ideal.
If it’s turning it can only be because it’s binding due to poor alignment, so why pin it bound up?
Steve Meadows
#5 bbr
bbr
  • 2,434 posts
Posted 04 April 2018 - 06:10 PM
the endbell gets hot and then soft ... losing grip on the bushing
  • Tim Neja, NSwanberg and Dave_12 like this
Mike Low
#6 havlicek
Posted 04 April 2018 - 06:46 PM
This is a problem for both the ProSlot and the JK Hawk motors, although maybe a "little" less so for the Hawk.  Having said that, here's the reason(s) it should be fixed.
*the oilite is loose and can spin in place...no...it doesn;t just stop at some point, it will spin more and more with time.
*as the oilite is spinning in the now-warm and softer end bell plastic, the pocket it sits in gets slightly larger, meaning more spinning and a continually looser pocket.
*as the oilite spins and the pocket gets a little sloppier, the commutator end of the armature that rides in that oilite is now riding less true and can also move around, even vibrate a bit.
*all the above keeps happening and current draw can go up, along with heat and the motor is running less efficiently.
This doesn't necessarily happen with every motor, and variances from motor-to-motor in terms of end play might make any motor more or less prone to the problem.  Any motor with a loose end bell bushing/bearing should be fixed.
  • Slot-Racer likes this
#7 Pablo
  • 18,466 posts
Posted 04 April 2018 - 07:09 PM
I don't see the problem as being the bushing "spinning", but I agree a spinning bushing isn't good.
The way I see it, the problem is the bushing backing out and riding against the comm.
All racing motors should have a certain amount of "play", or "slop" while being centered in the magnetic field.
When that "play" or "slop" is not present, or lost, it creates friction, which turns to heat, lost power, etc.
If and when that bushing slides free of it's factory press fit and migrates to the comm, removing the arm "play",
performance goes right down the drain. Arm gets hot, motor slows down, ending in an eventual "cookoff" :bomb:
Mike's idea would preclude that. As John H. points out, any bushing movement isn't good.
swodem, I think if Swiss told you the sky is blue on cloudless days, you'd argue with it.
The problem is, this is a public forum. :sarcastic_hand: "Don't be a wanker". Your words, not mine.
You have enough experience with racing motors to understand all this.
But you just love to argue.
See your post #90 here:
http://slotblog.net/...e-4#entry684321
  • Zippity likes this
#8 Jason Holmes
Jason Holmes
  • 1,264 posts
Posted 04 April 2018 - 09:22 PM
If you think this can't happen check the motor I ran in our Outlaw Can-am race 2 week ago worst case scenario is what you will see about 30 sec into the 6 heat of the race last lap turned was a 3.03  then boom on the back straight
jason
at least use some super glue before you oil and break it in but not much
  • havlicek likes this
#9 MSwiss
  • 25,939 posts
Posted 04 April 2018 - 10:21 PM
Probably any rule set that requires a sticker, wouldn't allow it.
Especially if they make a point of penalizing the racer by not allowing cut brushes.
Yes, Loctite 271.
It works well when I pin Red Fox guides, so I assume it work well for this.
So anyway, after reading these followup posts, at Boston Market, having a chicken pot pie, I walk back into the raceway and one my racers says "Bad news, I broke the toilet flusher'.
I go take a look at it and reply "No problem, I'll pin it".
You can't make this stuff up.
Pinned with a worn out 1/8" axle, I just replaced on a rental car, with a steel axle spacer soldered on, as a keeper.
  • JimF, Jason Holmes, B.C. and 4 others like this
#10 NSwanberg
NSwanberg
  • 2,041 posts
Posted 05 April 2018 - 03:07 AM
Livin the dream!
  • MSwiss and C. J. Bupgoo like this
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg 5618
#11 havlicek
Posted 05 April 2018 - 05:52 AM
Yeah...except I've actually seen them spin Pablo. :)  What I *think* may happen is that, the bushing does back out (*why I mentioned end play being a possible factor), and the fit between the bushing and it's bushing pocket becomes even looser at that point.  I don't know if friction between the back end of the bushing and the top end of the com (*or actually the com spacers) is the main problem, but it's probably a significant one.  I think of it this way; if the com bushing was loose enough to back out, it's probably also able to ride back-in.  No matter what though, a loose end bell bushing is not a good thing, as Jason pointed out above.
#12 Eddie Fleming
  • 2,950 posts
Posted 05 April 2018 - 07:18 AM
I am not questioning the need for or the effectiveness of the pinning.
In a class requiring sealed cheep motors would a fix requiring this much skill and effort be within the spirit of the rules? A little CA or epoxy seams more fitting even if not as effective.
#13 Pablo
  • 18,466 posts
Posted 05 April 2018 - 08:22 AM
Of course not. Probably why the OP put the thread in "Motors & Motor Building" vice "Retro Racing".
Lots of guys are using those type motors for "other than sealed motor racing", like my Go-kart.
H arm in a Puppy Dog PS 4002B
  • JimF likes this
#14 Fast Freddie
Fast Freddie
  • 723 posts
Posted 05 April 2018 - 10:15 AM
The Proslot endbell bushings have been a problem for a very long time.  When I blueprint a motor I always epoxy the bushing in place.  The problem on the PS 4002FK is the bushings are glassy smooth and so is the endbell bore.  If the bushing was rough it would hold it's place better.  Since this is a sealed motor I've gone to just super gluing the bushing.  You need to use a brand new tube of the glue so it seeps between the bushing and the endbell bore.  If the glue is thick it just won't do the job.  I just push the bushing down until it contacts the comm. then rough up what I can on the endbell bore.  Very carefully apply the glue around the very edge of the bore and quickly push the bushing back in place.  I have also tried just applying the glue to the bushing and endbell without moving it but it didn't work as well.
Fred Younkin
#15 olescratch
olescratch
    olescratch
  • 978 posts
Posted 05 April 2018 - 10:49 AM
Swiss!  A little food for thought!  Using Loctite on your guides is not the same as using it on your bushings.  The "MAJOR" difference is the amount of heat that develops in the two cases.  You should never obtain the amount of heat at the guide that is developed at the bushings, and we know what heat does to Loctite!  Please excuse my drift, but I feel that caution should be taken when using this method to pin an endbell!
John Stewart
#16 MSwiss
  • 25,939 posts
Posted 05 April 2018 - 11:09 AM
I used Blue Loctite, successfully, to keep screws from backing out, in aluminum endbells, for 20 years, in G7 open motors.
The type of heat required, to loosen that Loctite, would of already melted the endbell.
IOW, I wouldn't be touching the pin directly with the tip of a soldering iron, from a 800-1000 degree iron.
  • olescratch likes this
#17 MSwiss
  • 25,939 posts
Posted 05 April 2018 - 11:17 AM
I'm not telling anyone to do this.
I'm just making the technique aware to guys like John H. who make motors that are not governed by exact rules.
On FB, when the new 4007 was announced, a lot of racers complained about endbell bushings coming loose, as an issue, with this style motor.
Top racers chimed in that they still had them come loose, despite gluing them.
A minor aside, most orgs who use this motor, in the sealed form, allow soldering the can bushing in.
Has anyone ever spun a can bushing in one of these motors?
I've never seen it and we use this motor extensively.
It seems like soldering in the bushing would be like walking in MacDonalds, and purchasing insurance from getting hit with a meteor.
I went ahead and put a top pin in.
I'll take the motor apart tomorrow or Saturday and see what kind of effort it takes to move that bushing.
#18 havlicek
Posted 05 April 2018 - 01:05 PM
Yeah, this issue isn't exactly some sort of "top secret", and the reason for fixing it (when the rules...or lack of rules allows) should be pretty obvious.  Personally, I think a bushing with a splined outside and a slightly tighter fit *might* have solved the problem, but that would not be an easy/cheap thing considering how many of these things get produced, and how many are sitting there waiting to be purchased from the last production run.
It's a good idea, and one I haven't tried, but I have been doing something about it for a while.  Slightly (not much) more involved, but not at all applicable for motors that need to have their seals unbroken.  I *think* being able to take care of it with a pin should be OK with the rules (?), but that's not my thing.
#19 jimht
jimht
  • 1,624 posts
Posted 05 April 2018 - 01:57 PM
Tiresome.
Used to be there were serrated bushings in plastic endbells.
Then there weren't.
Needless complicated Rube Goldberg  hassle to fix something that was unfixed long ago for whatever reason.
....never mind.
  • Bob Kurkowski, NSwanberg and old & gray like this
Jim Honeycutt
#20 Markomatic
Markomatic
  • 101 posts
Posted 05 April 2018 - 03:04 PM
Using nylon rod would work just as well. Steel pin seems like overkill
Mark Miller
#21 MSwiss
  • 25,939 posts
Posted 05 April 2018 - 03:50 PM
Even if I had .045" nylon rod, I would still use the music wire.
It's less than a penny of wire, and the extra strength is important, especially with having to test fit it numerous times, to make sure I drilled deep enough.
#22 NSwanberg
NSwanberg
  • 2,041 posts
Posted 06 April 2018 - 03:39 AM
"Has anyone ever spun a can bushing in one of these motors?"
I have spun can bearings in two of them. :dash2:  :bomb:
#23 Bob Kurkowski
Bob Kurkowski
  • 300 posts
Posted 06 April 2018 - 06:13 AM
The 'flusher fix' pin probably is not needed. Drill the hole and fill with red loctitie should be sufficient. Do 180 dregree opposed if need be.
Bob K.
#24 havlicek
Posted 06 April 2018 - 06:30 AM
I'd be surprised if you *could* move it short of doing damage to the end bell itself.  It should be about as strong as you could make it.  I've tested my way and it seems very strong.  Yours seems way stronger.
Nylon rod that small (whatever hole you drill needs to be small enough not to weaken the entire end bell) would be more fiddly than using piano wire...may as well use use monofilament fishing line.  Steel wire may be stronger than is necessary, but it's ridgidity makes it a really good choice.
Then there weren't.
Exactly right.  Some sort of a "knurled" or grooved OD on a bearing meant to be installed in plastic seems like it *should* be the norm...and it was!
Bob
Huh?  End-bonding plastic that probably doesn't do well with any adhesive...even with drilling...in an application where the plastic is a long-arm "actuator" (lots of leverage) is bound to fail, probably after a few flushes at best.  I'm not sure that even the heavy steel pin would last for long, but it doesn't have to since a flush arm costs around $2-3 and the replacement takes minutes.  Still, the pin gets you a working toilet until the replacement can be done.
Yikes...that's one I HAVEN'T seen!  Bummer!  I've wondered why people solder them in myself...until now!
#25 Bob Kurkowski
Bob Kurkowski
  • 300 posts
Posted 06 April 2018 - 06:35 AM
John,
My suggestion was for the endbell not the toilet flusher. Basically same drilling technique but do away with the 'pin' and let the loctitie alone do the work. Drill and loctitie in 2 places for added security.
Bob K.
