Revisiting the Buehler motor
5 replies to this topic
#1 havlicek
Posted 28 April 2018 - 11:28 AM
I haven't done one of these in a while, but I remember being impressed with these motors. I don't think the Buehler was distributed here in the States, but the historians can make the correction.
Basically, the Buehler is a 16D-sized motor that superficially resembles the Mabuchi, but with some important distinctions:
 The can is formed out of a much thicker metal, probably around the same thickness as modern C and D motors, but is still a one-piece design with very nice crisp edges, a durable paint finish, and an outer can bushing holder made from aluminum with the same "circlip" type mounting as the Mabuchi, but lacking the last outer "bump" that the Mabuchi has, because the can bushing is fixed in this motor.
The magnets here are thick, long, and very strong, about as strong as say those in two-hole Mura B and C-cans, but with an additional groove in their back angle cuts (most likely to make sure they sit well with the inner slight radius of the can). I don't know/remember if these are indeed the stock magnets, but they are a huge step up from anything that came in the Mabuchis, and slightly stronger than the Arcos.
The endbell looks at first something like a Mabuchi (without the standard molded-in markings), but the hardware is unique. The hardware looks at least like it's machined from fairly thick metal, and sits in a molded recess in the endbell. Also the leadwire tabs and spring tabs are of a second piece that screws down over the hoods. It's all still a "one-screw" type hardware like the Mabuchi, but the way the hoods are located and what they're made from makes them virtually immovable. The brushes are very small, as small (maybe smaller?) than those in the Mabuchi FJ13UO, but the endbell itself is molded out of a material that seems noticeably harder/more durable than that of the Mabuchi motors. Unfortunately, the endbell oilite is small and similar, and the bushing strap is too narrow to fit a replacement unless one is turned-down from a larger oilite.
The armature that came in this one seems to be a home-brewed rewind that was "gash-balanced" within a micron of the coil windings. The stack looks a lot like earlier Chinese 16D arms had, but with a different comm that somewhat resembles an old Tradeship 16D comm.
So, a very cool motor, but still one that has some things that could/should be improved. The magnets alone, as well as the endbell plastic make this motor a real "potential" race winner.
  • B.C., C. J. Bupgoo and Geary Carrier like this
#2 Lone Wolf
Lone Wolf
  • 2,739 posts
Posted 28 April 2018 - 12:00 PM
  • Samiam likes this
Joe Lupo
#3 mark1
mark1
  • 160 posts
Posted 28 April 2018 - 12:24 PM
Those brush hoods are impressive!
  • havlicek likes this
Mark Anderson
#4 Cheater
  • 25,711 posts
Posted 28 April 2018 - 01:37 PM
Just based on your pic, those hoods look like they might have been made via powder metallurgy.
#5 havlicek
Posted 28 April 2018 - 02:02 PM
They sure are, Mark! Very precisely done however they were made.
I had thought that also, Greg. Just coming up with those square brush holes alone impressed me! I cleaned one of the hoods with a wire brush and found no visible tooling marks, but the "surface finish" looked to me as though the tubes are brass extrusions that are cut to length and then finished by slitting them for brushes.
Either way, pretty cool stuff!
#6 havlicek
Posted 29 April 2018 - 10:28 AM
Okey dokey then...I got the word that this motor needs to go as fast as possible.  That doesn't mean a #23 single :) , but it does mean the end bell will be returned unscathed with the finished motor, and I'll fit a modern D motor end bell with some Mura hardware.  With this very "closed" can design and surprisingly hefty magnets, there's plenty of room to move into the passing lane (*as long as there are no radar guns up ahead).
  • olescratch and Geary Carrier like this
