Offset gear mesh – how much? Help!?
34 replies to this topic
#1 Slot-Racer
Slot-Racer
  • 267 posts
Posted 07 May 2018 - 01:57 PM
Greetings,
In setting up a new open motor, was curious how much of an offset gear mesh is too little to get away with? Should I go for a larger pinion or does this look appropriate? The spur is -2 deg and the pinion is straight. What do you think?
Thank you.
Mario Damis
#2 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 07 May 2018 - 03:17 PM
I would be looking for a 16deg spur gear. Is that a C can open motor?? 64P
jason
#3 Slot-Racer
Slot-Racer
  • 267 posts
Posted 07 May 2018 - 03:23 PM
Thank you for your reply Jason, it's appreciated. Yes it's a C can with an Proslot Infinity armature in a Mega III can using 64 pitch gears. So a 16 deg. is better? Ok. I will see if I can find any on PCH. I happen to have a 9 tooth 2 deg pinion, would either be a better idea? The issue is that I can't move the motor in (back) anymore but I'm fearing with this open motor the gear mesh is not enough and may strip? At this time it was advised to run a 8/39 64 pitch by Proslot. What do you think?
Mario Damis
#4 Slot-Racer
Slot-Racer
  • 267 posts
Posted 07 May 2018 - 05:09 PM
Ok. Well I removed the pinion and tried different combination. An 8 pinion (2 deg.) didn't help anymore than the straight 8 pinion with either a 38 or 39 2 deg or straight spur. What I tried is a 9 pinion (2 deg.) with a 39 (2 deg.) spur and now it's SO much better! But is this ratio too crazy? This better ratio/mesh is going to be 5.70 where as Proslot advised a 6.41 ratio initially? Is this a bad idea?
The motor is a 30 Turn of 26 gauge wind.
Thank you.
Mario Damis
#5 Zippity
Zippity
  • 5,278 posts
Posted 07 May 2018 - 10:43 PM
30 turns of 26 is not a C-can wind.  :(
  • gotboostedvr6 likes this
Ron Thornton
#6 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 08 May 2018 - 10:25 AM
I would use 8/38 or 39 5deg pinion 16deg spur 64P
jason
  • Ramcatlarry likes this
#7 MSwiss
  • 25,920 posts
Posted 08 May 2018 - 10:48 AM
S-707 Infinity replacement armature for PS-315 RTR 30 turns 26.
  • Slot-Racer likes this
#8 Slot-Racer
Slot-Racer
  • 267 posts
Posted 08 May 2018 - 11:42 AM
Well, I got 9/39 to mesh way better. But it this too hot to run?
Mario Damis
#9 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 08 May 2018 - 11:46 AM
Yep, that's why you need an 8 or go to 72p. Try 9/43-44 angle on both gears.
jason
#10 Slot-Racer
Slot-Racer
  • 267 posts
Posted 08 May 2018 - 11:50 AM
So a 9/39 is too hot?
Mario Damis
#11 zipper
zipper
  • 1,095 posts
Posted 08 May 2018 - 12:00 PM
Maybe, depends on track and grip. Done it sometimes on our King, Gr 12. Faster than 8/39 but tends to run hot. And timing must be considered, too.
Pekka Sippola
#12 Slot-Racer
Slot-Racer
  • 267 posts
Posted 08 May 2018 - 12:10 PM
Ugh... OK. I don't know what the timing is if any. It's not specified by Pro Slot. Would then a 9/43 in 72 pitch be the right gearing and would not have to move the motor as Jason recommends? For 9/44 I find in 72 pitch, but the pinion is 5 -deg and the spur is -2 deg. Will this work? There is also a -16 deg spur.
Mario Damis
#13 Zippity
Zippity
  • 5,278 posts
Posted 08 May 2018 - 02:20 PM
I read somewhere recently that a straight pinion with a 16° spur makes for an ideal mesh.
Just sayin'.  :)
Ron Thornton
#14 Slot-Racer
Slot-Racer
  • 267 posts
Posted 08 May 2018 - 02:47 PM
Just sayin'.  :)
Ok thank you! I'll get the 16° and the 2° deg  (just in case) to see which fits better. I'm assuming dimensional they will be like the 9/39 and I won't have to move the motor as it's in as far as it can go in there.  :laugh2:
Mario Damis
#15 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 08 May 2018 - 03:12 PM
That will work the 16 will will cover more of the Pinion
jason
#16 Slot-Racer
Slot-Racer
  • 267 posts
Posted 08 May 2018 - 03:26 PM
jason
Awesome! Thank you for your help!
Mario Damis
#17 Samiam
  • 4,773 posts
Posted 08 May 2018 - 07:07 PM
Is the magnet up against the axle? A small notch in the magnet usually has no affect on performance.
#18 Slot-Racer
Slot-Racer
  • 267 posts
Posted 08 May 2018 - 07:09 PM
No not at all. What is, is the back of the can. It's completely flat against the motor box rear frame. I'll take a pic and post in a few min.
Mario Damis
#19 gotboostedvr6
  • 2,321 posts
Posted 09 May 2018 - 06:29 AM
Just get a *16 angled spur.
David Parrotta
#20 gotboostedvr6
  • 2,321 posts
Posted 09 May 2018 - 06:36 AM
30 of 26? You need to shunt that motor. It's prob gonna blow up regardless. Ceramic mags and a wind that hot are not a good idea.
David Parrotta
#21 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 09 May 2018 - 10:18 AM
David that is Mild back when I started we ran 20/25 most of the time in C cans and Yes they did run Hot and we shunted also 24 and Double winds and the cars weighted a ton but were Fun
jason
  • JimF and Slot-Racer like this
#22 Slot-Racer
Slot-Racer
  • 267 posts
Posted 09 May 2018 - 11:55 AM
So is this motor going to blow up?  :shok:
Mario Damis
#23 B.C.
B.C.
  • 309 posts
Posted 09 May 2018 - 12:02 PM
I have several of these arms in c cans running at 13.8 unshunted
I have never smoked one. I believe all are at 8/39.
it is a nice milder wind for a c can. there was one of these on epay
in a pro slot rtr a month or so ago--someone scored a good buy.
Brian C. Bays
#24 Slot-Racer
Slot-Racer
  • 267 posts
Posted 09 May 2018 - 12:03 PM
Awesome post! Thank you!
Mario Damis
#25 gotboostedvr6
  • 2,321 posts
Posted 09 May 2018 - 08:50 PM
We may have different ideas.
Ill assume that motor has mega 3 mags in it. They are one of the weaker mags on the market. If you have quads that improves your odds of not killing it.
I bet it will need a rebuild after 10 min of tracktime.
David Parrotta
