Offset gear mesh – how much? Help!?
34 replies to this topic
#26 Ramcatlarry
  • 2,949 posts
Posted 10 May 2018 - 07:32 AM
I have always tried to match the motor/axle angle for the gear angles with a combination of pinion and spur angles. The C-can angle is about 16-20 deg and the smaller cobalt motors end around the 2-5 deg range.
What racing series allows a 26 ga armature in a C-can other than bracket drag racing? Any motor can be used as a play toy for the rush of it. Might be a new class: C-can group 7.
  • Slot-Racer likes this
#27 Slot-Racer
Slot-Racer
  • 267 posts
Posted 10 May 2018 - 10:27 AM
This is not for any series or class.
Mario Damis
#28 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 10 May 2018 - 12:55 PM
Larry.
It's for fun.
jason
#29 Zippity
Zippity
  • 5,278 posts
Posted 10 May 2018 - 03:44 PM
At a first glance of the photographs, it appears that the wrong-sized motor has been placed in the chassis, or that the wrong chassis is being used for the motor.  :(
Ron Thornton
#30 Slot-Racer
Slot-Racer
  • 267 posts
Posted 10 May 2018 - 09:58 PM
I'm not following any rules, it fits, just need to find the right gear mesh angle. 9/39 is a perfect mesh but ratio wise it is low.
Mario Damis
#31 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 10 May 2018 - 10:46 PM
If it's not a Box chassis it maybe a INT 15 chassis Motor Fits Play on Guys calm down help don't Hammer
jason
#32 Ramcatlarry
  • 2,949 posts
Posted 11 May 2018 - 09:52 AM
Use the pinion and spur that runs right, THEN put the motor into the frame.  The motor does not always line up perfectly.  I usually use a short bit of brass tubing to bridge the gap from motor to frame in the rear.
  • Jason Holmes and Slot-Racer like this
#33 Slot-Racer
Slot-Racer
  • 267 posts
Posted 15 May 2018 - 01:37 PM
I would use 8/38 or 39 5deg pinion 16deg spur 64P
jason
Hi Jason,
You were absolutely right! Thank you. That is the right gear ratio and a 16 deg. spur was right also, you have excellent eyes! I re-did it all and now it's obviously right. I did a 16 deg. pinion in 72 pitch and a 9 tooth 5 deg. and it's way way better with the ratio of 6.43 with 7.60's.
Thank you all for your help!
Mario Damis
#34 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 15 May 2018 - 09:51 PM
Mario
That looks Sweet Have Fun
jason
#35 Slot-Racer
Slot-Racer
  • 267 posts
Posted 16 May 2018 - 10:14 AM
Thank you Jason!  :D  I'm still curious how much angle you can put to have minimal contact patch between the two and get away with it? I guess it's trial and error.  :o
  • Jason Holmes likes this
Mario Damis
