Does the OHM rating matter a lot , I have a controller with 2.5 and a 3.0 , would a 2.0 OHM rating work , thanks
Brake rheostat ohm rating
Posted 07 July 2019 - 11:35 AM
Posted 07 July 2019 - 11:45 AM
Somewhat dependent on car/track combination. A 2 ohm could be OK on most commercial track uses, but would like to use 5 ohm or more for HO and homeset needs. One or two diodes in a step switch is great also, if you are building a custom or add on brake circuit.
racing around Chicago-land
Posted 07 July 2019 - 12:20 PM
Don't worry about adding resistors. You are using the ohmite potentiometer on a Choke Master, just make sure the wire wrap is clean. I use the ohmite in the range from 2 to 3 ohms. The ohmite might have a 2.04 ohm rating, read the side of the potentiometer for the rated value.
The ohmite comes in the smaller ohm rating, wire wound pots usually come in 5 ohms. That is what I use for everythnng but the HO. The HO gets a 100 ohm pot because the resistor array has a higher value in the HO controller.
John Andersen- I build the damn things
John Andersen
DR Racing Products
Posted 07 July 2019 - 12:26 PM
Thanks a lot fo rthe info John and Larry
Posted 11 July 2019 - 06:44 AM
Earl, the real answer is how much brakes do you take out of the car when running. If you only take a little bit of brakes out then the 2 ohm will be fine. It will actually spread out the range and give you finer adjustment with the 2 ohm rheostat. If you have a 3 ohm now but regularly turn the brakes down most of the way then you will not be able to reach the same brake level on a 2 ohm.
I used 2 ohm rheostats then switched to a 3 ohm the last 20 years.
25 ohm value for 1/32 and 100 ohm for H.O.
Diode braking is awful. I guarantee that on the same track you will find a lane where position 3 will be too much brakes and position 4 will not be enough.
- S.O. Watt likes this
Jim Difalco
Difalco Design
3075 NE Loquat Lane
Jensen Beach, FL 34957
(772) 334-1987
askjim@difalcoonline.com
Posted 14 July 2019 - 11:36 PM
Posted 15 July 2019 - 06:52 PM
Posted 16 July 2019 - 10:47 AM
When you compare a typical pro brake with about 30 positions and an economy brake that has 100 positions with a diode brake that has 6 positions, which would you want? The difference is substantial between diode settings so you do not have the fine tuning available for braking.
- Rotorranch likes this
Jim Difalco
Difalco Design
3075 NE Loquat Lane
(772) 334-1987
