What are some of the techniques you guys use to flatten retro chassis ?
Flat chassis
Posted 20 September 2019 - 03:41 PM
Kevin Myhaver
Bad Dog Racing
Color Me Gone
Posted 20 September 2019 - 04:57 PM
If used, get a chassis jig, see where it is bent and the start replacing bent pieces.
Or return to builder and ask for a rebuild.
If your a newbie return to builder.
If its a flexi or wing car throw away and buy a new chassis.
Other than retro, slot racing has become disposable chassis and motors, kind of like society in general.
Unless you dont think a perfectly flat chassis matters. In that case race it.
- Pappy likes this
Posted 20 September 2019 - 05:24 PM
For minor tweaks, we hand our cars to Duran Trujillo. He wiggles the front tires and axle back and forth and presto - flat again
Posted 20 September 2019 - 06:42 PM
when a chassis gets tweeked. if the construction of the design lets you, you can refloat the front axle. manhandling the chassis by twisting or bending puts in stresses and tension.
if its really bad, refloat all the major solder connections in a jig.
the actually chassis doesn't need to be really flat, the tire contacts and guide flag do.
- tonyp, Bryan Warmack and Phil Smith like this
Cry like a baby, drive like a girl, walk like a man.
Posted 21 September 2019 - 02:34 AM
large Hammer!
- Samiam likes this
Posted 21 September 2019 - 05:23 AM
50 ton hydraulic press.
Posted 21 September 2019 - 06:11 AM
Posted 21 September 2019 - 03:25 PM
If there is major damage like a bent front axle assembly or crunched rear end I remove the damaged section and prepare replacement parts.
Reload it in a jig with no jig wheels so it is laying flat on the surface of the jig. Clean up the solder joints where the replacement parts are going. Straighten pans and nose piece as needed.
All joints where chassis main rails to the front and rear are fluxed and re-soldered as needed. Sometimes you can hear slight "pop" when the joints become released and the solder then re-solidifies. I usually do this step a couple times on the given joint just to make sure.
I've found in retro chassis with some brass main rails they are typically stressed their entire length and need to just be replaced. I always replace with piano wire.
Once the joints have stress relieved reload in the jig with jig wheels and install the new parts.
Posted 23 September 2019 - 11:29 PM
“And then....?”
- Rob Voska, Racer36 and Samiam like this
Steve Meadows
Posted 24 September 2019 - 09:26 AM
I have three steps for bent or otherwise damaged retro chassis.
Step 1: Find Bud.
Step 2: Give to Bud.
Step 3: Pay Bud.
- Steve Deiters, Tim Neja and Shooter7mustang like this
