I have a 6 lane gantry converted to 4 lane and it has worked fine. A few weeks ago one of the counters started flashing random times and counting sometimes when other cars came thru the other lanes. I did about all I know to do, checked connections, turned off and back on and it didn't fix the issue. I though that since it was counting when other cars went under, maybe it was sensing light from the next lane. I put a piece of tape next to the sensor in the gantry and that seemed to fix it and all was well. I assumed it blocked any light coming from the next lane. It did work correctly again.
At last nights racing we had the same issue with another lane. I tried taping, as before to make sure the only light the sensor could see was the light in it's slot. I didn't have any success.
I checked for dirt and obvious issues, but couldn't see anything wrong. My next step is to take it all apart and move to a work table and check each sensor and be sure each is working as it should.
Before I do that I wanted to check if anybody has had a similar issue with lights and light sensors.
