Flexi chassis with adjustable body mounts
Posted 04 December 2019 - 08:41 AM
- Phil Beukema likes this
Posted 04 December 2019 - 10:07 AM
That would be fine if every chassis had the same mounting holes. Start a one chassis spec series and get someone to punch the holes on a body mounting fixture.
Posted 15 December 2019 - 06:12 PM
I want a car body made of super elastic bubble plastic, that bounces off the wall back into my slot
- MG Brown likes this
Posted 15 December 2019 - 08:26 PM
Hi Dale, I understand your frustration with trying to get the body mounted exactly the way you want.
Please check out post #175 here:
http://slotblog.net/...-fixture/page-7
- Racer36 likes this
Mark Horne
SERG - www.slotcarenduro.club
Posted 15 December 2019 - 09:11 PM
I already knew about that thread but thanks for the suggestion.
Actually, I made a fixture along the same lines but mine is narrow enough that I don't have to make final cuts until after I've punched the holes. My narrow fixture allows me take a body that's just been roughed off and slide it forward and back and also up and down, so I can adjust how close the body will be to the guide and motor and how high or low I want the body to be (don't always want it on the cut line, if there even is a cut line).
I probably just need to refine my fixture until I get the accuracy that I want.
Thanks again.
Posted 23 December 2019 - 07:47 AM
Perhaps just buy yourself a decent body mounting fixture and then there is no need to re-invent the wheel.
Posted 23 December 2019 - 07:50 AM
Posted 23 December 2019 - 09:59 AM
My attitude is that the problem has always been that of using a body mounting system which started with screws and just devolved into more complexity with the "improvements" of tubes/pins and clips.
Body positioning would be infinitely more adjustable if chassis were designed to use this stuff instead:
https://www.3m.com/3...294857497&rt=r3
And, it allows mounting elsewhere besides the sides...
But, "Que sera, sera", we've been stuck in a time warp since the Sixties. YOMV.
Jim Honeycutt
Posted 23 December 2019 - 10:57 AM
It would be great if it worked well, but we've done a bunch of hardbody racing, and it really doesn't.
It didn't hold as well you would think.
Maybe because of the weight of hard bodies, or that the sides are curved.
Guys who tried to use it, always wound up also using tape in the race.
And even with a built-in ledge,, like on an FCR, getting fore-aft movement , the same, each time, is a bit tricky.
Bottom line, that system doesn't have referencing.
- team burrito likes this
Posted 23 December 2019 - 12:54 PM
Someone correct me if I'm wrong but I think a problem with using Mark Horne's Lateral-G Slot Sport Body Pro fixture is that it's designed for chassis that have pin tube mounts rather than body clips. When clips are used, the holes in the body have to be closer to each other by roughly .015". Even though that might not sound like much, just take a body that mounts properly with pin tubes and put a clip on the body and see how wavy the body becomes between the mounting holes.
This problem occurs with my JK chassis and is even more pronounced on my Mossetti chassis because the holes in the body mount tabs are bigger in diameter than JK holes. In other words, the clips that snap properly into JK chassis have to be shortened a few thou to properly snap into Mossetti chassis.
I will gladly correct you Dale. The Lateral G body mounting fixture works equally well for clips or pin tubes. In fact, I think it is a superior way to mount bodies for clips. The slightly larger hole you get lets the body move around just a touch more.
Posted 23 December 2019 - 01:44 PM
"It would be great if it worked well, but we've done a bunch of hardbody racing, and it really doesn't."
Actually, I didn't say anything about hardbodies.
OTOH, works well for me on both hardbody and Lexan rental cars...go figure. Maybe I kept hammering at it until the problems went away...
Jim Honeycutt
Posted 23 December 2019 - 01:55 PM
IOW, something like a Group F?
Posted 23 December 2019 - 03:15 PM
Sticks the body to the car about as well as tape, clips, pins or screws and could be used in conjunction with any of those options, but that's not actually the issue that the thread is concerned with, eh?
The OP was looking for an easier way to mount the body correctly on the car. Dual Lock makes positioning the body really easy.
Jim Honeycutt
#15
Posted 23 December 2019 - 03:21 PM
Can you show a picture of the amount of surface area needed for good locking?
As far as solving his problem now, it's not going to work with an existing legal flexi car, so I guess you're really not helping the OP.
#16
Posted 23 December 2019 - 03:42 PM
Jim Honeycutt
#17
Posted 23 December 2019 - 03:56 PM
- Mikedg likes this
#18
Posted 23 December 2019 - 04:15 PM
Rear crash structure, sort of like the attenuator on an Indy Car.
Or a mobile "soft wall".
Rotor
"Kinky Kar"
#19
Posted 23 December 2019 - 04:51 PM
"Rear crash structure, sort of like the attenuator on an Indy Car.
Or a mobile "soft wall"."
Good one but no: just lightweight support for the rear of the body for ham-handed kids that pound the car back into the slot.
- NSwanberg likes this
Jim Honeycutt
#20
Posted 23 December 2019 - 05:14 PM
Even if it didn't need that, say if you had all delicate turn marshal's, or racers who didn't need quick reslotting, the extra weight, high CG, and diminished body flex, would be a non-starter, for performance minded racers.
I whole heartedly agree it's fine for rental cars.
I personally think the OP is posing a non-problem.
Stick on a new piece of bullet proofing, and repoke, if you missed by a lot, on the first effort.
Seems much simpler than adding something to the chassis that would probably increase the price by $10 and require a rule change to allow "holy bodies".
- Danny Zona likes this
#21
Posted 23 December 2019 - 06:31 PM
You win, Mike.
The OP hasn't got a clue.
Jim Honeycutt
#22
Posted 23 December 2019 - 07:06 PM
He writes very detailed race reports, has made charts to help with ghost drivers, in round-robins, etc.
But raising the nose, up and down, on a current flexi style chassis, isn't a super-easy design, to come up with.
With the current designs, I don't see how you could do it, without effecting the body movement.
But I'll give it some thought.
I have figured out how not to have your car destroyed, when it gets ridered into the wall, at full speed.
#23
Posted 23 December 2019 - 11:55 PM
You miss the obvious solution which is to have more talented friends mount your bodies. I used to trade motor building and/or painting for body mounting. Those darn toothbrush motors have pretty much killed motor building.
Mike Boemker
#24
Posted 24 December 2019 - 08:45 AM
#25
Posted 24 December 2019 - 08:53 AM
What I really want is to refine cutting and mounting bodies in order to get the precision that I prefer, and not requiring an unreasonable amount of time to do it. So I'm going to search Slotblog for threads that pertain to body mounting and go from there. Thanks for all of the replies.
Check Ralph Thorn's body mounting hole punch jig.
Whatever he calls it.
Try this link http://ralphthornera...are_c_22-2.html
It is called the "body master" and is the last thing on the tools list.
