Part 1 of this saga began with a quest to recreate my first Dynamic Bandit (http://slotblog.net/...of-two-bandits/). And with the huge help of a number of members and Pablo’s craftsmanship to take it over the finish line, I now have a very sweet handling Bandit indeed! And it’s just like something one might have encountered back in the day. But since I had an extra Bandit body (thanks Gene!), I wanted to see about making the most performant Bandit I could with my own meager build skills and modern parts and design concepts. And so begins part 2 of this saga…
For the basic design, I choose to go with a contemporary IRRA F1 layout sans the outriggers as there just isn’t the room under a Bandit body. So basically it will be a standard 3/4” stainless steel loop flanked by a pair of brass rods. It will also have the defacto floating inner pan although in this case it will be a plumber design (sorry Dennis). Finally I’ll be using modern hardware as well, namely an offset RGEO motor bracket and MSwiss 2 degree guide tongue.
I realized a sticky point in this design would be the ultra narrow Bandit front end so I decided to start there first. My idea was to build it as a 3/4” subsection that I could later drop into the main loop. This ended up being a 1” strip of 1/2” by 1/16” brass flanked by 1/16”” SS axel risers. I’m also concerned with the front end being fairly fragile so I’m not going to have a solid axel but rather solder in some 3/32” tubing between the risers. My thinking here is that I can use hollow axels which are easy to replace and hopefully will bend in a major impact leaving the main frame undamaged … that’s the theory anyway!
Below are some construction shots of front subassembly construction:
