BP is opening an hour earlier, which means leaving home an hour earlier. That makes it worth the trip IF I can run two classes on Saturday. I think visitors from out of the area will agree. Attendance isn't what it used to be and it seems 5 or 6 mains total can fill up a day. 3 for CanAm and 2 or 3 for F-1. Western States worked out perf. Coupes and Can Am ran the same day.
Mark, you're correct.
Our F1/Can Am races on the King for the last 3 or 4 times has been 3 Can Am mains and 2 or 3 F1 mains.
It takes about 1 hour to run each main (this is the total time from the end of one main to the end of the next main). Tech inspection and qualifying adds another hour to the total time for each race (that's a total of 2 hours for both F1 and Can Am). Past race results shows that the time from the end of tech to the end of the last main in each event is fairly consistent. There is not a lot of wasted time here. The area in which we do waste time is usually the start of and end of tech inspection. Late start/end of F1 tech is usually due to late arriving racers. Also, a lunch break between the F1 and Can Am races adds additional time to the race day.
Based on the estimates (actual times recorded) above, a typical F1/Can Am race day (5 or 6 mains total) will take 7 or 8 hours not including "wasted" or extra time between events.
A strict racing time schedule (very similar to what John Sinz proposed) would yield the following: track opens at 8 am, F1 tech opens at 9:30, ends at 10:00am. F1 qualifying ends at 10:30 am.
First F1 race starts at 10:40 am and last F1 Main ends at 1:40 pm (3 mains) or 12:40 (2 mains). Can Am tech starts at 3 pm (or sooner if only 2 F1 mains) and ends at 3:30 pm. Can Am qualifying ends at 4 pm. 3rd Can Am Main ends at 7 pm. If there are only 5 mains, the finish time would be 6 pm.
You cannot finish F1 and Can Am racing by 3 to 4 pm. Perhaps having F1 on another race day would be better. Also, it saves time if the first race of each event (F1 or Can Am) is a round robin with up to 3 sitouts. This reduces the number of mains which reduces the total racing time. If we decide to no longer use the handout motor rule for the Can Am race, it would require less time for the racers to prepare their cars and thus reduce time. Our racing schedule could be revised to provide a reasonable finish time for each racing day, but F1 and Can Am together will always end up with a 6 to 7 pm finish time.
Keith
