Building some Jail Door chassis
#126
Posted 14 August 2010 - 11:12 AM
Before I moved to Downers Grove, I lived a block
away from Vesecky's.
FWIW, Vesecky's (round) kolacky are totally scratchbulit
while Weber's uses some mass-production.
Thus, while Weber's are more concentric with less run-out,
IMHO, Vesecky's kolacky taste 1.478% better.
Now if you were going to make a rolling hoska,
using 4 of Weber's would probably be a better choice.
Slam, the sound of Mike leaving to go to Five Guys in Naperville
before the parking lot gets too crowded.
#127
Posted 14 August 2010 - 01:01 PM
I agree with Dennis, a little slop in the arm won't be the end of the world some say it is.
A piece of rod soldered up against the hinge eliminates some of the slop, also you might try smallparts.com for some hypodermic SS tube in slightly bigger OD for a tighter fit.
Is that legal ? I can send you a sample if you want.
Thanks for the cutter tip, Dennis...if my Elva car chatters, I'll get kinky
Posted 14 August 2010 - 01:12 PM
also you might try smallparts.com for some hypodermic SS tube in slightly bigger OD for a tighter fit. Is that legal ? I can send you a sample if you want.
I don't believe it's legal? only Piano wire, brass rod or brass tubing for the drop arm hinge from my understanding
#129
Posted 14 August 2010 - 01:15 PM
Posted 14 August 2010 - 01:18 PM
Posted 14 August 2010 - 01:20 PM
The irascible knowalot who's mentoring me says that these brass-tube axle carriers have a half-life of one race, then swap 'em out. A swaged-and-reamed tube like this is not starting out with the .003" disadvantage, and so may last nearly as long as Oilites (3 races), but they're gonna wear eventually & get swapped.
I never had a brass tube bearing to wear to the point it hurt the proformance of a chassis. Our races used to be 200 laps or about 30 minute races where the tubes would be oiled one time. I'm sure I had a frame or two that stayed competitive 10 or so races.
I have a Turbo frame that never had the oilites changed. I remember that frame going through 26 16 minute races as we were closely watching a new ProSlot/Kelly motor when they were first released. The same oilites also were in two 2-hour enduros and a 4-hour enduro.
Oilites or 5/32nds tubing as a rule are not a trouble spot.
11/6/54-2/13/18
Posted 14 August 2010 - 06:41 PM
Everybody has a different take on "This is / Isn't a big deal, my cars need / run fine without this Blivet / that Quazer......"and like so many things, it comes down to how you drive what's in your box. I figure, if some idea makes sense to me I'll try it. Maybe it'll help, or maybe I'll learn something.
Duffy
1950-2016
And I am awaiting
perpetually and forever
a renaissance of wonder
#133
Posted 14 August 2010 - 07:41 PM
Posted 15 August 2010 - 11:39 AM
Just yesterday at the local I32 race, an old ex-checkpoint guy was looking at some of my stuff...including my surviving '66 F1 which is illegal under the current rules! Pianowire main rails, 2x47, Dubro Hemi/16d bracket with a 16d, sheet "drop arm" with no hinge. The first race the car was in was in August 66 at the Cottonwood Mall's "orange" track. Broke the hinge at the end of the first heat, and hurriedly repair it. And blew the work the hinge no longer worked. But the car was both faster and easier to drive, which means that no following car I built had a working drop arm hinge!
And pianowire!
Anyway, the "old timer" said "what about humps". I offered that there isn't any way in basic physics to have JUST the chassis respond to the hump and NOT have the drop arm follow. He grinned and we went back to talking about his old Friend Warmack.
Now, I think it was "Mark Twain" who said, "a difference of opinion is what makes for a race".
Fate
3/6/48-1/1/12
#136
Posted 17 November 2010 - 06:43 PM
My experiences so far with Jaildoor frames:
8. Bracing the bracket to the rails to the limit of the rules is good to get rid of chatter. Use every bit of brass rod the rules allow you around the motor bracket area.
Dennis:
I took your advice and attempted to do that for my chassis. Also discovered what a pain it is to make the .300 braces allowed per the rules. Figured out a pretty good method for making them all the same, too bad I didn't take photos.
same specs as the 4 rail chassis, but this one weighs 59.2 grams
Anyway it's done.
#137
Posted 18 November 2010 - 12:52 PM
11/4/49-1/23/15
Posted 18 November 2010 - 01:05 PM
Going to work on making it a slot car tonight. Maybe I'll put a thingie body one it?
#139
Posted 18 November 2010 - 10:39 PM
#140
Posted 27 November 2010 - 07:44 PM
Truly beautiful work, great job!
-Richie
- Richie Austin
#141
Posted 26 February 2014 - 03:05 PM
Very nice piece of work, for sure. More than I feel up to with my failing eyesight and spasmodic left thumb.
In the day I used a Champion jig. Two pieces of aluminum with a bunch of holes for different wheelbases and tire sizes. That was the last use of threaded axles around my place.
Pete Varlan
60 years a slot racer
#142
Posted 26 February 2014 - 03:14 PM
Pete, that would have been one of Champion's Align-O-Jigs.
