First test! What is going on?
Posted 13 February 2011 - 01:27 AM
Posted 13 February 2011 - 01:32 AM
And if your car is a Can-Am...it sounds a bit on the heavy side for a King Cobra.
Posted 13 February 2011 - 01:42 AM
Posted 13 February 2011 - 02:00 AM
Nesta
Nesta Szabo
Posted 13 February 2011 - 08:22 AM
The F7 gets wired just like any other angle winder. So the F-7 is in your inline and a wire is going from the right side of the guide to the right side of the then yes you will have to change the wires. Depending on how banked the cobra is 115 is definitely on the heavy side.
Dominic Luongo
NERR photos from 2016 to now
Posted 13 February 2011 - 08:50 AM
The teeth on the Crown gear should be facing the drivers side of the car.
Boy, you guys have me all confused
Ron, my Can Am drivers sit on the right hand side of the cockpit. My F1 drivers sit in the center.
If your Falcon 7 is running hot, assuming all other things are correct like gear mesh, go down to an 8 pinion.
As far as which wire goes on which side, it depends on which way the motor is placed in the car
Posted 13 February 2011 - 09:30 AM
Posted 13 February 2011 - 10:02 AM
My Series Spring 2016 4" NASCAR, JK LMP State Champion, and Endurance State Champion
My Series 2015 4" NASCAR, GTP and Endurance State Champion
GRRR 2015 4 1/2" and F1 Champion
GRRR 2013 & 2014 Evil Flexi Champion
1968 Hinsdale ARCO Amateur runner-up
Posted 13 February 2011 - 10:12 AM
Posted 13 February 2011 - 10:27 AM
Posted 13 February 2011 - 10:42 AM
Posted 13 February 2011 - 10:48 AM
With the Falcon 7 moto.... the crown gear teeth should be facing the left side of the car.
The armature spins clock wise direction if the motor is in upside down or not.
Posted 13 February 2011 - 10:56 AM
Here's a couple of photos that should eliminate and right side, left side, driver's side confusion.
I hope this gets your gear on the proper side and your wiring connected properly.
1/24/48-2/18/16
Posted 13 February 2011 - 11:02 AM
Posted 13 February 2011 - 11:03 AM
Holy Mackeral, there is even an arrow showing rotation !!!
Posted 13 February 2011 - 11:04 AM
#18
Posted 13 February 2011 - 11:11 AM
Posted 13 February 2011 - 11:24 AM
#20
#21
Posted 13 February 2011 - 12:14 PM
#22
Posted 13 February 2011 - 12:21 PM
#23
Posted 13 February 2011 - 12:39 PM
#24
Posted 13 February 2011 - 12:48 PM
And I will echo the gearing change...8 x 27 or 28 would be a good starting point for an F7. Hopefully the motor has not seen too much heat.
Of course, it could just be a dog motor. I haven't had much luck with Falcons lately, and prefer the TSR D3 motor (those get geared with a 9T pinion)
#25
Posted 13 February 2011 - 12:49 PM
