First test! What is going on?
#51
Posted 13 February 2011 - 06:50 PM
#52
Posted 13 February 2011 - 06:52 PM
#53
Posted 13 February 2011 - 06:56 PM
BTW there is no prob with using a 9T pinion on that King Cobra with the Falcons. 100-105 gr car is a good place to start. The one I gave you is heavier and better suited for where I race.
?/?/1950-3/8/22
Posted 13 February 2011 - 07:05 PM
#55
#56
Posted 13 February 2011 - 07:20 PM
#57
Posted 13 February 2011 - 07:21 PM
So the front tires should touch the track? If so what should I do to make them hard.
You need to add or remove shims from between the chassis and guide flag, depending on the depth the track braid is recessed below the surface of the track. A lot of people pre-set their chassis using a set-up block with different recesses cut in them, if they know ahead of time the depth (if you always race at the same track, it's probably a one-time thing. I race in the Retro-East series where we have about 6 different tracks so many times we have to change this).
A quick and dirty way to check this is to put the chassis on the track without the body, then press down on the guide flag. The rear tires just just barely lift up. If the front tires are off the track surface, you need to remove shims. If the wheels lift quite a lot, add shims. Make sure you do this on a section of the track that is as flat as possible.
#58
Posted 13 February 2011 - 08:47 PM
#60
Posted 13 February 2011 - 09:13 PM
Thats a nice tool I am going to pick one up, But my problem is when I put the guide nut on it goes on crooked.
#61
Posted 13 February 2011 - 09:26 PM
What a coincidence ! You live in Oxnard, CA !! What a lucky guy !!
Posted 13 February 2011 - 09:35 PM
Do you have a guide flag threader? If not, buy 3-4 guide flags at one time and have a friend cut the threads for you. I know the flags are usually partially threaded from the manufacturer, but the hand held threader will chase the threads and insure they are straight. Since I have a couple threaders, I usually by mine un-threaded and prefer to do it myself. I also know if I didn't have a threader, my local track will thread them for their cutomers if needed.
#63
Posted 13 February 2011 - 09:40 PM
Cahoza guide threader. Scott at PCH Parts express in Oxnard, CA should be able to help you.
The Cahoza was the first threader I ever purchased and I still have it. I prefer to use my GT-1 threader. I know some say they like their Spray by Mac threaders. Baxter can probably do a search and read more than he ever wanted to about threaders and which ones are the best
#64
Posted 13 February 2011 - 09:48 PM
#65
Posted 13 February 2011 - 09:53 PM
Your guide goes on crooked and I become a rider more then I want to?
Hang in there and you will get the answers.
Nesta
Nesta Szabo
#66
Posted 13 February 2011 - 09:57 PM
#68
Posted 14 February 2011 - 03:11 PM
#69
Posted 14 February 2011 - 03:41 PM
Great to hear you're making progress!
#70
Posted 14 February 2011 - 06:27 PM
#71
Posted 15 February 2011 - 01:24 AM
#72
Posted 15 February 2011 - 10:17 AM
Posted 15 February 2011 - 10:24 AM
#74
Posted 15 February 2011 - 10:39 AM
Next try to mount the hardest tire in your box FIRST. Soft tires bit too much and take much more power to turn.
Then...I noticed the F1 car in the picture had JK Plastic Hubs. Those wheels will have too much glue at times and vibrate. Try the Aluminum Hub or whatever that is not plastic. Listen and fel your car when you run it on a power supply. Is it vibrating? Is it noisy?
Parma gears are all we have and they are great. But the more worn in they are the better. At a race you will see the top guys with 10 to 20 gears in tow. Find the quit gear and the horspower will follow. Vibration kills a Falcons speed. Start with the 8 tooth and 28 axle.
When I ran my first Retro race I qualified over 1.3 seconds off the pole. I was totally frustrated. With a lot of learning...reading -watching - listening I qualified straight to the B-Main last race only 3-10ths.
Hope this helps....anyone..
Rick "Rapid" Raducha
106 Pierremount Avenue
New Britain - Connecticut
1636 King Arthur's Court
Lakeland - Florida
#75
Posted 15 February 2011 - 11:19 AM
