Using Rit dye
39 replies to this topic
#26 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 2,242 posts
Posted 15 June 2015 - 11:41 PM
Mixing colors and not over doing it is the key to getting the results you are looking for. Also as a last tip, make sure you thoroughly wipe your pots between colors or you will develop a black almost burnt looking effect.
  • C. J. Bupgoo likes this
Matt Sheldon
#27 Gator Bob
  • 13,391 posts
Posted 15 June 2015 - 11:44 PM
Wow Matt .... You make it look so easy and ....t hose came out great.
I'll find a pot and get a thermometer ....  or .... send stuff to you.
Un-believable.... all the colors. :good:  :good:
#28 Matt Sheldon
Matt Sheldon
  • 2,242 posts
Posted 15 June 2015 - 11:46 PM
Pot and strainer from Walmart, I think I paid about $9 total for the pair.
Bob you are welcome to send me parts any time! I did everything above this evening in about 40 minutes for this thread. Once you get the system down it is not hard. The hardest part is not making a mess.
Matt Sheldon
#29 Matt Sheldon
Matt Sheldon
  • 2,242 posts
Posted 16 June 2015 - 12:14 AM
Rick, on 16 Jun 2015 - 04:18 AM, said:
Why is it all clumpy? Never saw that happen before.......
I am going to take a wild guess and say it is starting to gel from the super thick concentrate, extended heat which has caused the H20 to steam evaporate, leaving the sludge behind.
Matt Sheldon
#30 Gator Bob
  • 13,391 posts
Posted 16 June 2015 - 11:58 PM
When it cools it mixes right back to dissolved with a quick stir..
Correction above - Not a Champion flag. That is the color I wanted the endbell to come out.
Jairus, didn't you dye orange that kind of endbell for a motor build?
Matt, bring to a bubbling caldron boil - then let cool to 140 and then dunk holding a steady 140 w/ stove on?
#31 Matt Sheldon
Matt Sheldon
  • 2,242 posts
Posted 17 June 2015 - 08:51 AM
Yes. I also want to try the vinegar trick as Jairus had mentioned.
Matt Sheldon
#32 Jairus
  • 10,174 posts
Posted 17 June 2015 - 09:21 AM
I dyed this Champion endbell after the mounting holes on the original "Orange Picker" became too reamed out.  The color is pretty close to the original.... maybe just a bit too reddish if I were to be picky.
Pic is dated July of 2011.
#33 Gator Bob
  • 13,391 posts
Posted 17 June 2015 - 09:44 AM
Thanks Matt. !
Jairus, Yes that's the one ... did you use any different procedure with that type of higher heat material. Looks great.
#34 Jairus
  • 10,174 posts
Posted 17 June 2015 - 11:38 AM
Bob, as I have explained many times before.  Powder Rit dye mixed with a bit more than a cup of water full strength in a small sauce pan with a glug of vinegar brought to a slow boil. No idea of the temp... just don't let the stuff splash on the stove top or you will need acid to clean it.
Then suspend the part in the liquid for 5 to 10 and check.  Never takes longer than that and the part is dyed for all time and the color goes deep.  Takes a lot of wear to reveal any white or pink.
I don't hope to explain the physics behind it or the reason. I just know it works.
The Dye can be stored after cooling and used many times. But it's corrosive so use a glass bottle with a non-metallic cap.
Or toss... cause it's too damn cheap to worry about anyway.
  • Rick likes this
#35 Gator Bob
  • 13,391 posts
Posted 17 June 2015 - 11:57 AM
Thanks Jairus, I was wondering if you found and difference in doing the Champ endbell vs. something like a Jet Flag.
Now you know why my gears come out pink. :dash2:  :laugh2:
#36 Jairus
  • 10,174 posts
Posted 17 June 2015 - 12:06 PM
I found no difference from guide to endbell to gear.  Follow that formula and 10 minutes is all you should need.
  • Gator Bob likes this
#37 HarV Wallbanger III
HarV Wallbanger III
    Racing inta OLD age!
  • 6,165 posts
Posted 17 June 2015 - 12:35 PM
"Why is it all clumpy? Never saw that happen before......."
Holy Smokes Bob 'wad'ya got in 'dat water down there! Never seen this before!!!!!!!!!!! Maybe its the "Orange Sunshine".... Remember take 2 tabs and call me in the morn'in..... Yes Rit dye for the plastic parts!
Barney Poynor
12/26/51-1/31/22
#38 Gator Bob
  • 13,391 posts
Posted 17 June 2015 - 12:50 PM
LOL ... Two ??? Don't expect any phone calls in the morning Doctor Bronco.
There shouldn't be anything other than H2O in there ... it's RO.
Wonder if there is a coating in the beans can effecting the mixture.
#39 Ramcatlarry
  • 2,956 posts
Posted 17 June 2015 - 02:37 PM
I used to make wiring harness in an industrial shop.  Nylon dyes with ease, DELRIN not so easy.  I recall setting the color with cold salt water quench.   Oil can also be infused as a hot dip.(gear tip)    I guess my black dyed flags were not black enough, Bob had to tape them for the drags.
I recall using the salt in tie-dye t-shirts as well.
#40 Gator Bob
  • 13,391 posts
Posted 17 June 2015 - 02:48 PM
Yup ... The in-track slot LASER timing LEDs go right through dyed nylon at The Raceway.
