36D H-Power 1934 Ford
100 replies to this topic
#76 Pablo
  • 18,467 posts
Posted 16 February 2018 - 10:03 AM
Oilites soldered home in perfect alignment and jig motor screwed into position for rough planning.
The main chassis sits way high - my plan is to make rails and ISO setup at ground zero for front wheels.
I needed some sort of gizmo to temorarily jack the chassis up to it's intended height.
Math says height of motor shaft center is .440, main plate rail bottoms are .250 above axle center,
.44 - .25 = .190.  Two 3/16 tubing pieces will work fine :)
Now I can remove the stock motor and start jigging it all up.
Title of the thread has been changed to reflect the firing of the American Line brass paperweight chassis.
She promptly found a new home and a good job up in Canada :D
  • Jencar17, Samiam and Geary Carrier like this
#77 Samiam
  • 4,774 posts
Posted 16 February 2018 - 10:28 AM
Pablo doing his part for NAFTA. :good:
#78 Pablo
  • 18,467 posts
Posted 16 February 2018 - 09:43 PM
:)  I found the perfect flag: Cox "pre-quick change" style.
The flag deck height is about .060 but there is a raised part that makes it .130.
I added a .125 nut and a 10 thou spacer to the jig bolt to elevate the Cobra tongue accordingly.
Now I need to fabricate a tongue to chassis connector gizmo......
  • Jencar17 likes this
#79 Pablo
  • 18,467 posts
Posted 17 February 2018 - 12:09 AM
Made a pattern for the .032 gizmo out of cardboard.
It will be soldered under the front end and rest atop the Cobra tongue
No, Bunky, not the cardboard, the brass gizmo. Geez, do I have to explain everything to you? :laugh2:
  • Jencar17 and MSwiss like this
#80 Pablo
  • 18,467 posts
Posted 17 February 2018 - 09:29 PM
Tongue assembly complete
  • Jencar17 and Bud Greene like this
#81 Bill from NH
  • 14,859 posts
Posted 17 February 2018 - 10:41 PM
I can see where the "Pablo" name tag is going now! :laugh2:
  • Horsepower likes this
#82 Pablo
  • 18,467 posts
Posted 19 February 2018 - 07:09 PM
No shortage of real estate to place the "Pablo" engraving, Sir :laugh2:
The WB and GL on the modified Monogram chassis will be the same - 4.5".
Front wheels are .860 OD and Cox 33T crown gears at about .800 OD will serve as jig wheels
#83 Pablo
  • 18,467 posts
Posted 20 February 2018 - 07:00 PM
I'll be using .055 "ISO-Torsion Tuning fork" wires to control the front axle tube.
Time for a quickie tinning party :dance3:
This batch of 36" lengths is very straight :good:
And what's the best tool for the job, kids? Weller Gun, that's right.
Once you do it this way you'll never go back....
#84 Pablo
  • 18,467 posts
Posted 20 February 2018 - 10:23 PM
ISO-Torsion wires do triple duty - manage front wheel lift, buttress oilites, and strengthen main chassis.
From there on, they are free to allow the front axle tube to droop a hair and lift as needed:
Since there is a country mile of empty space under the chassis, the engraving sits down low :laugh2:
Bill, how do you like me now? :D
  • C. J. Bupgoo likes this
#85 Bill from NH
  • 14,859 posts
Posted 20 February 2018 - 10:47 PM
They can see who built it without taking the body off. Hooray! :laugh2:
#86 Pablo
  • 18,467 posts
Posted 25 February 2018 - 12:41 AM
:laugh2: Maybe I should jack all my chassis up this way  :laugh2:
But Jungle Pam wasn't too impressed
Telepathic steering technology has not reached 100% reliability, so I braced the rear end with a "U" wire
Tilting .063 X 1/4" body mount pans at ground zero lower the overall center of gravity.
Hinges are 3/32 square tubing. Looks a little like Kon-Tiki, eh? :)
  • C. J. Bupgoo, mike1972chev and Tom Katsanis like this
#87 Bill from NH
  • 14,859 posts
Posted 25 February 2018 - 09:08 AM
If you run big wheels like those shown in you first photo, you could also run colored lights underneath the chassis like some of the lowrider guys use. :laugh2:
You gotta like that retro photo of Jungle Pam. :clapping:
#88 Pablo
  • 18,467 posts
Posted 27 February 2018 - 01:30 AM
Yep.
My bastardized Monogram Kon-Tiki chassis got a 1/16 wire bite bar with .047 downstops
Ready for tumbling
  • Samiam, Geary Carrier and Tom Katsanis like this
#89 Pablo
  • 18,467 posts
Posted 27 February 2018 - 04:27 PM
One more permanent addition before tumbling - a pair of 1/4 X .025 wraps for the can-end bushing holder.
They will be soldered inside of the main rails
#90 Pablo
  • 18,467 posts
Posted 28 February 2018 - 10:37 AM
Monogram Kon-Tiki chassis is done
  • miko, Tim Wilkins, C. J. Bupgoo and 2 others like this
#91 Bill from NH
  • 14,859 posts
Posted 28 February 2018 - 01:18 PM
Nice looking 75% scratchbuilt chassis. :)  I'm sure you know these Monogram chassis show up frequently on eBay. If they're not complete, they're usually priced quite reasonably.
#92 Pablo
  • 18,467 posts
Posted 28 February 2018 - 05:02 PM
Thanks but I don't plan to go into production with this fun car :laugh2:
Cox flag secured with Classic weight.
I changed my mind on the fronts - threaded Cragar style vintage wheels with hard tires.
Old skool nuts n plastic spacers, Professor Motor threaded 2 1/2" axle
Rears are set screw Ergal-type.
Old skool plastic spacers sandwiched between modern Slick 7 steel spacers.
  • Samiam, C. J. Bupgoo and Tom Katsanis like this
#93 Pablo
  • 18,467 posts
Posted 28 February 2018 - 07:48 PM
Took some fiddlin' but I managed to make the flag self-centering
H Power motor secured both fore
and aft
She passed the drivetrain test (again) no problem and is ready for the combat Lego driver and '34 Ford body
  • miko, Samiam, olescratch and 2 others like this
#94 Bill from NH
  • 14,859 posts
Posted 28 February 2018 - 09:26 PM
Is that '34 Ford coupe a 1/24 scale body? I ask because in your last photo, the chassis looks long enough to fit a 4.5 " car. It'll be fun running it around the track at Billy's once his knee heals.
#95 Pablo
  • 18,467 posts
Posted 01 March 2018 - 10:00 AM
It's a 1/24, 4 1/2" wheelbase body.
#96 Bill from NH
  • 14,859 posts
Posted 01 March 2018 - 11:59 AM
I think I saw a '34 coupe body like it last night. The seller indicated it was by International.
#97 Pablo
  • 18,467 posts
Posted 01 March 2018 - 08:03 PM
Driver is anxious to return to the combat zone
#98 Steve Okeefe
Steve Okeefe
  • 1,139 posts
Posted 01 March 2018 - 08:36 PM
Nice freestyle build!  Clever use of parts and materials.  :good:
I really like the driver figure.  :laugh2:
Two questions:
Is that a Parma pink crown dyed blue?
What did the dimension across the rear tires end up being?  2-1/2", 2-3/4"?
Steve Okeefe
#99 Pablo
  • 18,467 posts
Posted 01 March 2018 - 08:40 PM
Thanks Steve :)
1. Yes
2. 2 1/2" front and rear
#100 Pablo
  • 18,467 posts
Posted 02 March 2018 - 04:45 PM
Ready for next track test 7 April.
Weight is now 156 grams
  • bluecars and olescratch like this
