36D H-Power 1934 Ford
100 replies to this topic
#26 Bruce Wayne
Bruce Wayne
  • 197 posts
Posted 29 November 2017 - 02:35 PM
-Please clarify "GTP" hardbody?? They make those?
GTP starting grid from BPR's most recent monthly race series
These are all based on 1/24 Tamiya, Hasagawa or Fujimi model kits. Most are typically 3.25" wide with flat rockers, so easy to convert to slot cars.
Check out Keith Tanaka's SoCal D3 website and race reports in the 1/24 Racing forum for more examples and links to rules etc.
Bruce W. Frye
#27 Bruce Wayne
Bruce Wayne
  • 197 posts
Posted 29 November 2017 - 02:36 PM
Bruce W. Frye
#28 Pablo
  • 18,465 posts
Posted 29 November 2017 - 05:40 PM
My plan has changed somewhat. The center section is extremely heavy, but the body is lightweight.
I doubt adding pans on this car will provide any benefit, but I can add some later if needed.
Front wheels are torsioned via .055" wires soldered to the center section 1/4" amidships
Body mounts are .063 tubes installed and held with retainers through .078 holes in the chassis - little bit of wiggle and slop
  • miko, Bud Greene, Geary Carrier and 1 other like this
#29 olescratch
olescratch
    olescratch
  • 977 posts
Posted 30 November 2017 - 02:00 AM
Always filled with interesting examples of craftsmanship!  Nice!
John Stewart
#30 Pablo
  • 18,465 posts
Posted 30 November 2017 - 08:46 PM
Thanks, John :)
Rear body tubes cut and keepered to make room for the motor.
Wires installed and motor secured front and rear.
As a precaution to ensure nothing got bound up tightening 'er down, I gave the motor a test.
She sounds fine and draws exactly the same amps at 3 volts she did during breakin :)
  • miko likes this
#31 Pablo
  • 18,465 posts
Posted 30 November 2017 - 10:21 PM
Assembly is "roughly" complete and ready for track test Saturday.
Rear wheel inserts, body paint, tuning changes, etc. will come later.
Drivetrain test with the vintage gears was OK, not great - I can see the Cox crown distort as I apply power.
It was never designed for this much power. It may be just fine on the track - we shall see.
If it's noisy, I'll make changes until it's perfect.
My front wheel torsion assembly seems to do exactly what I wanted -
as I give the car a slight twist, the wheels lift yet apply some resistance.
Jet Flag is secured via a (genuine) Cobra Phase III weight.
TQ 20 gauge lead wires, old school clips, and JK soft braids
  • slotbaker, miko, Samiam and 5 others like this
#32 Pablo
  • 18,465 posts
Posted 02 December 2017 - 10:45 PM
Track test results -
the good:
-handling is amazingly good; no doubt the tonnage helps, along with the torsion fronts and floating body mounts
-motor ran sweet and it scoots pretty good for a brick
-zero deslots after about 20 laps
-had fun chasing Billy Watson's Kemtron '34 Ford around
the bad:
-I missed the gearing somewhat - and the Cox is noisy - so I will be changing to a (dyed) 35T Parma Pink
-Billy made me a thicker body with 20 thou - the current one is too flimsy for such a heavy car
  • Samiam, grooverunner, mike1972chev and 1 other like this
#33 havlicek
Posted 03 December 2017 - 10:43 AM
and the Cox is noisy - so I will be changing to a (dyed) 35T Parma Pink  :)
Hey Pablo.  Have you ever tried the "putting a flame to the gear while it's turning" thing?  I've never done it, but I saw it posted here some years back and it's supposed to turn noisy gears into unobtanium-silkey-smooth beauties...er something like that.  :pardon:
#34 Pablo
  • 18,465 posts
Posted 03 December 2017 - 11:42 AM
Do it all the time, John  :)
See drivetrain test results in my post #31.
I heated this Cox but it isn't a gear mesh issue - as I apply power I can see the Cox distort.
A mass produced 50 year old gear designed for a stock 36D simply isn't capable of handling a motor and a car like this.
Keep in mind the H 36D is spinning a pretty big, heavy pinion here, also.
The Parma pink will be fine. Only question is, blue or black Rit dye? :dance3:
  • havlicek and miko like this
#35 havlicek
Posted 03 December 2017 - 03:57 PM
Only question is, blue or black Rit dye :dance3:
...anything but Pepto-Bismol pink!  :D
  • Pablo likes this
#36 Pablo
  • 18,465 posts
Posted 04 December 2017 - 05:46 PM
Parma pink 35T dyed really dark blue, and a new thicker Billy Watson body (ready for paint)
  • Geary Carrier and Tom Katsanis like this
#37 Pablo
  • 18,465 posts
Posted 04 December 2017 - 06:13 PM
This one is for John H. I took the Cox and secured it to a dummy axle.
Pried it right off the hub with just my strong meaty fingers
Then tried to fold it into a taco shell for fun
Don't try this with a Parma, you'll only hurt yourself :laugh2:
Note to self, do not even attempt to use any of the big vintage crown gears with H Power motors.
  • havlicek and olescratch like this
#38 havlicek
Posted 05 December 2017 - 06:16 AM
Those are some serious gear-pullin' fingers you got there Pablo!  :D
PS:  I AM surprised that the gear is that easy to mangle!
#39 Pablo
  • 18,465 posts
Posted 05 December 2017 - 03:06 PM
The bigger they are, the more leverage you have :laugh2:
My friend Bud Greene has been known to fold a complete car into a taco when he's not pleased with it :aggressive: :P
#40 Pablo
  • 18,465 posts
Posted 05 December 2017 - 06:55 PM
I hated to disassemble the car to make minor improvement modifications to the pin tubes, but it had to be done.
Front tube received a strengthener wire in the middle
Rear tubes are soldered solid now; no more wiggle.
I realize this goes against traditional thinking of more movement rear and less front, but "it is what it is" :search:
#41 Pablo
  • 18,465 posts
Posted 05 December 2017 - 07:14 PM
Help! Where can I find "American Mag" style inserts, approx. .568" (14.44 mm) OD?
#42 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 06 December 2017 - 06:33 AM
I have 4 @ around .576.
  • Gary Pershall likes this
Gary Stelter
#43 Pablo
  • 18,465 posts
Posted 06 December 2017 - 10:18 AM
PM sent, thanks Gary!
#44 Pablo
  • 18,465 posts
Posted 06 December 2017 - 07:54 PM
Re-assembled with the dyed Parma 35T crown.
Drivetrain test #2: much better :dance3:
  • miko, Jaeger Team and Tom Katsanis like this
#45 Pablo
  • 18,465 posts
Posted 07 December 2017 - 05:24 PM
What do you think about this Lego warrior as a driver? Bad to the Bone, or, stupid?
When I found him he had a grenade, a pistol, and a flak jacket :)
  • Samiam and Tom Katsanis like this
#46 bluecars
bluecars
  • 1,273 posts
Posted 07 December 2017 - 05:30 PM
COOL!
Robert 'Red' Valantine
9/18/51-8/30/24
#47 Pablo
  • 18,465 posts
Posted 07 December 2017 - 08:28 PM
Thanks Red. We both like him, so he stays :)
A piece of tape to secure him atop the motor and a steering wheel is all he needs :ok:
#48 Samiam
  • 4,773 posts
Posted 07 December 2017 - 08:50 PM
Perfect driver. But give him his gun back. He's got 2nd Amendment rights too.
  • olescratch and mike1972chev like this
#49 olescratch
olescratch
    olescratch
  • 977 posts
Posted 07 December 2017 - 11:36 PM
Give him all his armament, he may need it soon to deal with the competition.  May even give the build a theme, not that it doesn't have one.
John Stewart
#50 Pablo
  • 18,465 posts
Posted 08 December 2017 - 10:51 AM
OK how about the MP-5 in one hand and the wheel in the other? :D :aggressive:
  • Samiam and olescratch like this
