X-Drive chassis project
34 replies to this topic
#26 Revtor
Revtor
  • 191 posts
Posted 27 November 2019 - 03:13 PM
Alchemist, I love these one-off chassis/ motor experiments!! Keep em comin!
As far as the pancake motor design, of course you have to take a look at the classic Aurora Thunderjet!
https://en.m.wikiped...cake_(slot_car)
Steve
  • Alchemist likes this
~ Steve Maietta
#27 MSwiss
  • 25,919 posts
Posted 30 November 2019 - 12:44 AM
https://pin.it/kbocr2nyh4ey33
  • Geary Carrier likes this
#28 MSwiss
  • 25,919 posts
Posted 30 November 2019 - 12:47 AM
There is a picture of a rolling chassis, that is making the rounds of the 'net, recently, that has 2 angled motors.
I'm not sure if I spotted it on FB or Pinterest.
I came across it again.
  • NSwanberg and Alchemist like this
#29 Revtor
Revtor
  • 191 posts
Posted 01 December 2019 - 08:23 AM
Now if he could just get the guide flag angle to vary the resistance to the two motors somehow ....
~ Steve Maietta
#30 Martin
  • 4,226 posts
Posted 01 December 2019 - 12:38 PM
A mercury switches come to mind
G force would send power to the outside wheel. If that is what you were after?
We are amusing the axle is split.
  • Courtney S and Revtor like this
#31 Alchemist
  • 2,703 posts
Posted 05 December 2019 - 03:52 PM
As an update:
I switched to ARP angle pinions for both SS and LS prototypes.
It lowered the gear noise, BUT, in a dozen laps or so, both crown gears wore out significantly!
Interesting that this occurred, because running the straight cut brass pinion - though noisy - both prototypes ran well over a 5 minute run, with no indication of wear.
The cars currently have a Hypoid gear setup, and neither pinion or crown gear are designed for Hypoid use.
Do they make slot car gears for hypoid use?
The crown gears that wore out, were Cox and Mid America Crown gear.
So, I need to see how I will retrofit the gear planes to be Non--Hypoid.
Thanks for looking!
#32 Revtor
Revtor
  • 191 posts
Posted 06 December 2019 - 05:14 PM
Martin, thats an innovative idea!!
~ Steve Maietta
#33 Eddie Fleming
  • 2,935 posts
Posted 06 December 2019 - 06:02 PM
 With regard to your gear mesh see post #3 in this topic.
Reversing the gear will give more gear contact than the straight pinion and much more contact than the angled put on in the normal direction.
#34 Alchemist
  • 2,703 posts
Posted 06 December 2019 - 11:27 PM
Hi Eddie,
Your suggestion had already been in my plan, prior to you mentioning it.
I had installed the angle pinion backwards,   but I could not get a smooth mesh, which left me baffled.
So, I put the pinion on in the correct direction.
I've changed the gear axis to be non-hypoid and will be testing the cars to see if this will make a difference.
I presume it will - testing will tell!
Thanks again for the suggestion Eddie - I appreciate the support!
#35 mickey thumbs
mickey thumbs
  • 175 posts
Posted 06 December 2019 - 11:28 PM
Slot.it makes crown gears for a 0.5mm offset for their 1/32nd scale offset inline motor mount system.
Mike Vernon
