Fuel Injection Special... kinda
35 replies to this topic
#26 strummer
strummer
  • 405 posts
Posted 25 March 2020 - 02:55 PM
Mark, there are screws thru the ends of the front radius rods that go thru the body into the side rails of the frame to hold the body on.
I'm not clear as to exactly which "screws" you're referring to: photo, perhaps?  :)
Here is how it's (more or less) gonna look:
I was able to salvage the dashboard (steering wheel was missing) and had to cut off the actual "seat" part of that casting and shorten the back of the seat to clear the motor.
I'm not sure how I'm gonna integrate those rear axle "braces" (or whatever they are) into the final assembly; will probably ream out those currently square holes to allow the axle to pass through. Won't mess with that until longer axles show up...
Mark in Oregon
  • Samiam likes this
Mark Mugnai
#27 strummer
strummer
  • 405 posts
Posted 04 April 2020 - 07:45 AM
Quick update.
I've got people staying here during this "COVIS-19" thing, so hobby stuff time is at a minimum.
I did manage to get some paint on this project this morning:
Not quite as dark a blue as I'd hoped, but I think it'll be okay once the decals are on and the wheels are painted...
Take care, everyone.
Mark in Oregon
  • slotbaker likes this
Mark Mugnai
#28 MattD
MattD
  • 3,561 posts
Posted 04 April 2020 - 08:39 AM
Mark follow the front radius rod to it's back mounting point.   There is a piece of tubing soldered to it there.   A screw goes thru that tubing and thru the body into the upturned side of the brass frame.   That holds the body on.
  • strummer likes this
#29 strummer
strummer
  • 405 posts
Posted 04 April 2020 - 10:38 AM
Thanks Matt
Mark in Oregon
Mark Mugnai
#30 strummer
strummer
  • 405 posts
Posted 16 April 2020 - 10:15 AM
A question of aesthetics; your opinions are needed.
Which wheel/tire set looks better on this?
#1:
#2:
I personally like the thinner tires in #1, but like the "taller" option in #2...
Thank you; hope everyone here is doing okay.
Mark in Oregon
Mark Mugnai
#31 don.siegel
  • 5,849 posts
Posted 16 April 2020 - 10:31 AM
Yep, agree with you Mark - try to find a rear set that matches the bigger fronts...
#32 Dave Crevie
  • 4,523 posts
Posted 16 April 2020 - 11:39 AM
Bigger is better. And don't forget to use inserts.
#33 Pablo
  • 18,448 posts
Posted 16 April 2020 - 03:57 PM
1 looks too skinny.
2 is too much rubber.
I vote for a 1.5  :)
  • Rotorranch and strummer like this
#34 strummer
strummer
  • 405 posts
Posted 16 April 2020 - 06:29 PM
Thanks guys.
I think you may be right Paul; I will look for some slightly thinner rears. I believe Strombecker made some...
Mark in Oregon
Mark Mugnai
#35 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 16 April 2020 - 08:46 PM
I'm not sure how the Strombecker tires handle, but these are the ones for their Lotus open wheeler;
Fronts
Rears
The Lotus is a 60s car, so might be a bit under scale for your Roadster.
Steve King
#36 strummer
strummer
  • 405 posts
Posted 16 April 2020 - 10:21 PM
Thanks Steve
The Strombeckers on the rear of my car are #8348, and are 11mm or 7/16" wide.
I think maybe 8mm (+/-) would look better...
Mark in Oregon
Mark Mugnai
