Thank you, Gentlemen
I haven't put any extra effort into my photography, but I'll take the kudos any way I can ![:dance3:](http://slotblog.net/public/style_emoticons/default/dance3.gif)
JK MB (Mini-Brute LOL) out of the package. There are a million ways to break in a toothbrush motor. Brush hardness and quality from China is a moving target. Lately it seems like a dry break in on low volts is fine.
I swiped the factory Chinese grease away from the can end bushing, oiled it with thin slot car oil, fed it 3V. Runs slightly better CW at can end, red positive. Draws .20 amps. After 2 minutes, amps had dropped slightly to .18 amps. Dead cool, zero vibration. That tells me the alignments and brushes are happy. Further break in would serve no purpose. So I gave her a 10 second Ohren splash and stopped. The JK MB motor is perfect for this type car, smooth, tame, and will last a long time.
8T straight steel pinion soldered on. 2mm screws with allen wrench size heads (courtesy of Jeff Chambers). They both get a microdot of Loctite red 271.
