Latest brushless motor news
83 replies to this topic
#1 bbr
bbr
  • 2,420 posts
Posted 29 November 2021 - 03:44 PM
From the uk
https://www.slotcarr...5LDHiim6s-iw8EY
  • Alchemist likes this
Mike Low
#2 Alchemist
  • 2,694 posts
Posted 29 November 2021 - 04:58 PM
That's great to see that other slot car enthusiasts are looking into making the brushless motors work.
Thanks for sharing Mike!
#3 Phil Smith
Phil Smith
  • 3,582 posts
Posted 30 November 2021 - 10:34 AM
This setup seems to be a big advance in the design. I guess it didn't work that well as they raced a different setup.
  • NY Nick and NSwanberg like this
Phil Smith
???-2/31/23
#4 Eddie Fleming
  • 2,908 posts
Posted 30 November 2021 - 11:23 AM
At this point it is no news.
when someone comes up with a package that you can put in your car for X#$, or at least detailed instructions that the average individual can follow then it will be something.
Until then it is just some guys playing around with some different tech. Cool but so far it has no real effect.
#5 bbr
bbr
  • 2,420 posts
Posted 30 November 2021 - 06:48 PM
it did not take me that much effort to get one running... and I never had any experience with brushless motors.
destroyed a couple of motors figuring how to replaced the shafts, but sourced the right tools and it is a snap now.
the only caution is to wire the polarity correctly, or you blow the esc!
sort of fun to be hot rodding this thing...
it will be more accessible when more esc for slot cars becomes available
  • team burrito, NSwanberg, Alchemist and 2 others like this
Mike Low
#6 rmjlmartin
rmjlmartin
  • 317 posts
Posted 30 November 2021 - 07:57 PM
Where can I get a brushless motor setup like you have, MIke? I've seen some of the other threads on it, and it looks interesting. And what kind of performance do you get with it?
Jason Martin
#7 bbr
bbr
  • 2,420 posts
Posted 30 November 2021 - 09:00 PM
motors are available from any drone vendor. 110x series motors. they are about 4000 - 8000kv specs.
xxxxkv x track volts = rpm
I am using Emax, check their website -- https://emax-usa.com...06&type=product
that's the easy part...
the hard part -- esc must be tweaked or designed for slot cars application.
Mack and company are using an esc designed for slot car, not available for the general public as of yet.
Tom "Bags" has a tweaked esc ( I have been using it )
the Mack esc turns on at 2v I believe, which make it very usable for flat tracks ( the chips turns on at 2v )
the Tom esc turns on at 5v (pretty much standard drone/rc car ), a bit difficult for flat track ( but he is still playing with it to make it more friendly ), very usable for high downforce high speed tracks
as for racing them... eurosport and G7 are the only classes they are legal in as of now
Mack and Budge has shown they are competitive in eurosport
theoretically, I worked out G7 times are possible and have a motor that is strong enough to do it, but I have no G7 experience... but will try to put together a G7 package
  • Half Fast, Alchemist, Samiam and 2 others like this
Mike Low
#8 W. J. Dougherty
W. J. Dougherty
  • 1,305 posts
Posted 01 December 2021 - 02:31 AM
I didnt understand your comment about doing something to the shaft. Could you please explain, maybe with some pics if necessary? What about installing in the chassis? Thanks
Yortuk & Georg Festrunk
#9 bbr
bbr
  • 2,420 posts
Posted 01 December 2021 - 04:45 AM
The motor has 2mm bbs. The shaft is 2mm, but the portion that sticks out is reduced to 1.5mm, you could use 1.5mm pinons, but it relatively easy to just replace it with 2mm shaft, I used koford 2mm axles.
The motor "base" with the mounting holes is aluminum, I made a brass bracket that the motor screws to and soldered that to the chassis.
Mack is a chassis designer/manufacturer and he made chassis specifically for brushless motors.
  • Bags likes this
Mike Low
#10 Bags
Bags
  • 567 posts
Posted 01 December 2021 - 07:10 AM
Hope this helps…..
  • NSwanberg and Alchemist like this
Tom Bagley
#11 Bags
Bags
  • 567 posts
Posted 01 December 2021 - 07:14 AM
Tom Bagley
#12 Bags
Bags
  • 567 posts
Posted 01 December 2021 - 07:51 AM
Mounted in a bracket…..note the end of the shaft sticking out of the bottom.
Tom Bagley
#13 rmjlmartin
rmjlmartin
  • 317 posts
Posted 01 December 2021 - 08:26 AM
Thanks Mike, that looks interesting. At this point, I'm not as interested in racing it as in having a very low-maintenance play car.
Tom, I assume that you're the Bags that Mike mentioned? Where do you have the ESC available to buy, and what is the cost?
Jason Martin
#14 Pappy
Pappy
  • 14,109 posts
Posted 01 December 2021 - 09:21 AM
So if you come out of your slot and go into another slot going the wrong way you blow the esc?
If so you might want to install  (I think they call it)  a bridge relay or something like that. It will only allow electrical current to go one way. I'm not much on electronics so don't chastise me unto death if I'm wrong about this.
Jim "Butch" Dunaway
#15 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,628 posts
Posted 01 December 2021 - 10:05 AM
In life and in technical advances:
"First they ignore you, then they laugh at you, then they fight you, then you win”
Cheers
  • Pappy, kvanpelt, Samiam and 1 other like this
Faster then, wiser now.
#16 HarV Wallbanger III
HarV Wallbanger III
    Racing inta OLD age!
  • 6,165 posts
Posted 01 December 2021 - 12:35 PM
Thanks for the info Mike
Barney Poynor
12/26/51-1/31/22
#17 bbr
bbr
  • 2,420 posts
Posted 01 December 2021 - 03:09 PM
A diode can provide protection, planning to install on power lead.
All this is a learning process and will get refined.
As with neo HO cars, when Nick Toma drop one of the first ones in the slot,,, it was fast, but hit the wall it became a kit. Now they are missiles and bulletproof
Mike Low
#18 Don Weaver
Don Weaver
  • 1,855 posts
Posted 01 December 2021 - 03:26 PM
Or a newbie track marshall  :crazy: !
Don Weaver
L.H. Lapham
it will starve to death...
#19 NSwanberg
NSwanberg
  • 2,033 posts
Posted 02 December 2021 - 03:59 AM
Seems like there ought to be an opportunity to use the dynamic braking voltage to keep the ESC powered longer while in race conditions or has somebody already thought of that?
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg 5618
#20 Half Fast
Half Fast
  • 2,628 posts
Posted 02 December 2021 - 01:51 PM
Do these motors/ESC's permit electronic braking?
Cheers
#21 Bags
Bags
  • 567 posts
Posted 03 December 2021 - 08:22 AM
Cheers
Yes plenty of brakes just like a brushed motor.
Tom Bagley
#22 Eddie Fleming
  • 2,908 posts
Posted 03 December 2021 - 09:04 AM
Would the diode in the power lead effect the breaking?
#23 bbr
bbr
  • 2,420 posts
Posted 03 December 2021 - 04:32 PM
Hmm... Maybe a thermal fuse? MOSFET?
Mike Low
#24 dickytenkids
dickytenkids
  • 17 posts
Posted 07 December 2021 - 04:33 PM
raced rhe car in UK ISRA  eurosport race at the weekend ,finished 6th which is a good start
about where i would have finished if id run my regular euro car .did everything i wanted ,mainly it was a reliability test .
ive probably done well over 1000laps ,no loss of speed just keeps going
whole car is 5 grams lighter than brushed car .
Tom
ill have a chat when im not working next
need to build a drag car for friday
  • Chris Stemman, team burrito, Phil Smith and 1 other like this
Richard Mack
#25 Bags
Bags
  • 567 posts
Posted 09 December 2021 - 08:40 AM
If a mosfet can be used, will it be normally open or closed ? Which side would it be put on, positive or negative?
Tom Bagley
