1/24 brass and wire chassis help
60 replies to this topic
#1 FastRichard
FastRichard
  • 80 posts
Posted 02 March 2022 - 05:59 PM
What would be the correct motor and body for this frame?
Thanks.
Richard
Richard Sylvester
  • 14,755 posts
Posted 02 March 2022 - 06:45 PM
The motor box looks like a C-can. The arm could be anything from Int 15 to opens. When monorail chassis first came out in the mid 70s, they were used for open class wing racing. If you go that route, any wing body would work. A couple that you might have seen in rhe 70s. include the Outasight Ferrari coupe, the Lucas Matra, the Lancer Porsche coupe, & any of the 3 or 4 Associated bodies. You could include the MAC bodies too.
#3 FastRichard
FastRichard
  • 80 posts
Posted 02 March 2022 - 07:05 PM
Thank you. I knew someone here on Slotblog would have the answer.
Richard Sylvester
#4 Isaac S.
Isaac S.
  • 1,507 posts
Posted 02 March 2022 - 07:14 PM
Yeah, I would probably do a Int-15 C-can. A MAC Ferrari is what I would use. A TI22 would also look good. Electric dreams has both.
Isaac Santonastaso
#5 Bill Seitz
  • 581 posts
Posted 02 March 2022 - 07:48 PM
Parma sold this chassis into the early 90's and used it for their Group 15 and 20 ready to runs through the 80's until they introduced the Patriot shuttle chassis. This chassis has plumber hinge only. The G27/G7 chassis I've seen had double hinged pans. About any Mura or Champion C-can would be correct for this chassis, particularly G15 and G20. Since Parma sold the chassis ready to run, Parma wing bodies would also be correct, and I'm sure plenty of O/S bodies were also used.
#6 Jairus
  • 10,174 posts
Posted 02 March 2022 - 08:20 PM
Here's mine.
It was an RTR in 1979.
  • Jencar17, Pete L., Phil Smith and 4 others like this
#7 FastRichard
FastRichard
  • 80 posts
Posted 02 March 2022 - 08:37 PM
I really appreciate all the info.
Thanks
Richard
Richard Sylvester
#8 Mark Onofri
  • 2,453 posts
Posted 02 March 2022 - 10:14 PM
Ah, the 80's. A very fuzzy , blurry and, out of focus time. I was trying hard contact lenses. 😆.
At Miniature Grand Prix of Westvall, that chassis wasn't available. That didn't stop me from buying the parts & building one. Funny thing is, don't remember racing it.
Anyway, it was instantly superseded by there tripod. Same snout, umm , noze piece but triangaly.
That was obsolete instantly by.....
  • 917-30 likes this
#9 Mark Onofri
  • 2,453 posts
Posted 02 March 2022 - 10:16 PM
several species of Lazer cut steel.
It's fine with a 12x.
Just make sure it's square. I've had variants that were off by a 1/8"
#10 Bill from NH
  • 14,755 posts
Posted 02 March 2022 - 10:21 PM
The first monorails I saw in the 70s were built by Tony P. Pros did not use them for long. Not a pro, but I have a half built one from '73 or 74.
Mark, the steel chassis that replaced them were not laser in the Northeast. They were hand cut. I cut one, then went back to using piano wire.
  • Pete L. likes this
#11 team burrito
team burrito
  • 2,202 posts
Posted 03 March 2022 - 01:17 AM
a hawk 6 motor would be perfect for this chassis. not too powerful & handles great with the right body.
Russ Toy (not Troy)
#12 FastRichard
FastRichard
  • 80 posts
Posted 03 March 2022 - 11:18 AM
Thanks guys
Richard Sylvester
#13 mreibman
mreibman
  • 633 posts
Posted 03 March 2022 - 11:28 AM
Ok, late to the party.... I agree with a lot of the above comments.
My 2 cents: the back end / tube has been tinkered with. These were orgiinally set for 13/16 rear tires using that tube. I recently refurbed one of these, and jigged it to use .790 tires instead. But whatever is going on with the mount of that tube isn't stock and looks like it needs some attention.
  • team burrito and Isaac S. like this
Mike Reibman
Alleged amateur racer.
Faster than a speeding Womp.
More powerful than a 36D.
#14 Bill from NH
  • 14,755 posts
Posted 03 March 2022 - 05:53 PM
Yes, the rear tube has been messed with.
#15 Mark Onofri
  • 2,453 posts
Posted 04 March 2022 - 02:32 PM
Team Burrito, I think he is going for period correctness.
I unearthed the part's of one I had built during the reddeath quality. I converted it to a 4.5" IRRA stock car. Didn't get to race it last year 😭. I'll post it tomorrow or later today. The hinges are copied from a Slick-7 sr-55 kit.
  • team burrito likes this
#16 Bill from NH
  • 14,755 posts
Posted 04 March 2022 - 07:38 PM
What's reddeath quality?
#17 Bill Seitz
  • 581 posts
Posted 05 March 2022 - 07:13 PM
I wasn't active in the 70's, so I've only seen this chassis as the Parma Monorail and in their RTRs in the 80's. This chassis wasn't well soldered, and I've seen several come apart at the joints. If you had one very long, it ended up being completely re-soldered. The rear axle tube looks like there's been an attempt to beef it up to prevent broken axle tube joints. It's pretty straight-forward with some jig wheels to un-solder the axle tube and reposition it for different size rear tires. As mentioned, the first one I had was set up for 13/16" tires, but I believe the later ones used .760. I've built some axle tube chassis of similar rear layout since switching to 96/4 (tin/silver) solder without any broken joints, but this design in 60/40 (tin/lead) solder needed some additional bracing of the axle tube to main rails to prevent broken joints.
#18 Bill from NH
  • 14,755 posts
Posted 05 March 2022 - 10:48 PM
Silver soldered joints are stiffer than those made with 60/40. I built a number of "all silver soldered" chassis & it always took 3 or 4 races before their optimum handling showed up. Dennis "Foamy" Hill from CA agrees with me on this.
#19 John Luongo
John Luongo
  • 652 posts
Posted 06 March 2022 - 06:43 AM
we use to use 95/5 solder for repairing/replacing ac components. never had separation or other issues even on the high pressure side (450psi).
#20 team burrito
team burrito
  • 2,202 posts
Posted 07 March 2022 - 12:41 AM
if you need a period correct motor, i've got a 70's style mura gp15 motor with over/under springs & buss bars. let me know if you're interested.
Russ Toy (not Troy)
#21 Mark Onofri
  • 2,453 posts
Posted 07 March 2022 - 01:08 AM
It was 75°F today so, I'm a little late posting.
BillNH: as I've said before, this phone wants to die.
It's supposed to say:
The red death quarantine .
Even if I proof read it, I can't be sure if it will come out that way.
I blame Boris Badnekov.
  • Alchemist likes this
#22 Mark Onofri
  • 2,453 posts
Posted 07 March 2022 - 01:24 AM
Bill Seitz, solder comes in many flavors. The higher the tin content, the stronger the joint. However, the more brittle the joint. I used to have it memorized but, no one asks anymore due to the PEX revolution. Some at better in shear,some in tension,some resist vibration. All the ones that contain lead are toxic especially when Molton.
#23 Mark Onofri
  • 2,453 posts
Posted 07 March 2022 - 01:25 AM
John L. You don't use phosphorus bronze ?
#24 Mark Onofri
  • 2,453 posts
Posted 07 March 2022 - 01:33 AM
Mreibman, did you mean that the axel tube looked as if it had been chewed on by crocodiles?
  • mreibman likes this
#25 John Luongo
John Luongo
  • 652 posts
Posted 07 March 2022 - 04:46 AM
not back then. this would be in automotive service and refer units. if the 95/5 wasnt the best solution, then we brazed. usually brazed valve bodies and hard fittings that may have to hold up to a lot of twisting torque by a technician with gorilla arms, or to support heavy piping. the brazed components seldom gave any trouble even after years of service.
