A small but enthusiastic crew of five slot-heads gathered at Electron Raceway for a no-holds-barred contest featuring two of our fastest and most popular classes: GT1 and Sports Car. At Electron, we don’t do “fun runs” or hand out participation trophies. This is a no-sandbagging zone—if you win here; you’ve earned it the hard way. That’s what real slot car racing is all about.
Observations:
It was a real pleasure to welcome back a couple of familiar faces to the track. James, a former regular, rejoined the group after a multi-year hiatus. We had reconnected during some long drives to Pelican Park Raceway, and now—as they say—he’s back! James is a fierce competitor known for bringing well-prepared machines, and this race night was no exception. After just a bit of warm-up, he quickly returned to form and immediately challenged for the top spot in both GT1 and Sports Car.
Joe, another longtime racer, also made a welcome return. Having spent the past year or so enjoying retirement and traveling, he decided it was finally time to dip his toe back into slot car racing. True to form, Joe wasted no time finding his rhythm and was once again a serious contender. Rounding out the field were Ken and Scott. Ken had a solid night, picking up a few qualifying heat wins, while Scott battled some setup issues—but knowing him, he’ll have things dialed in by the next event.
Sports Cars have been a staple at Electron Raceway for quite some time. The class allows both production and prototype vehicles, provided they are closed-top designs—no convertibles or spyders permitted.
The main distinctions between the Sports Car and GT1 classes are:
- Body Width: Sports Car bodies are limited to a maximum width of 3.25 inches at both the front and rear wheel wells. GT1 cars have no such restriction.
- Motors: Sports Cars are powered exclusively by Deathstar or ProSlot 16D motors. In contrast, GT1 cars use higher-revving Falcon or Hawk 7 motors.
As with other classes, any H-bracket chassis may be used. Since many Sports Car bodies fit on the same chassis used in other categories, switching classes often requires nothing more than a simple body swap. Popular body choices for the Sports Car class include the Ferrari Modena, Ferrari F-430, Ferrari 458, and Ford GT.
The Ferrari 458 is a personal favorite due to its generous wheel openings, which allow for a wider track. The Ford GT, while narrower in front, benefits from a low-profile body that aids performance. Notably, the rear wheel openings of both the Ferrari 458 and Ford GT provide sufficient clearance for large rear tires and may not be modified. However, to expand body options for this class, the rear openings of other models may be enlarged to accommodate the same large tires.
GT1 – Prototype Powerhouses
GT1 is our fastest class, featuring ultra-low, wide-body cars powered by high-revving Falcon or Hawk 7 motors. While both motors are legal, most racers have migrated to the Hawk 7 for its superior punch and lap times that typically beat the Falcon by a tenth or two. Standard gearing for these machines is 10x54.
Legal bodies include Group C prototypes from the 1980s and GT1 machines from the 1990s and beyond—radical, high-tech race cars that were decades ahead of their time. Where Can-Am cars once relied on big-block brute force, Group C and GT1 cars were more refined, built around screaming high-rev engines and sophisticated aero. Each car had its own character: different wing setups, diffusers, and body shapes. Manufacturers like Porsche, Nissan, Jaguar, Toyota, and Mercedes fielded works teams backed by serious resources. Interestingly, Porsche also made its race cars available to privateers, giving independents a real shot at glory.
In 1/24 scale, these bodies are mostly made by Tamiya and similar manufacturers. While highly detailed and beautiful, they can be expensive and somewhat scarce. To keep things affordable and accessible, we also allow wide-bodied modern sports cars such as the Ferrari Enzo and LaFerrari. These bodies drop right onto a GT1 chassis with little or no wheelbase adjustment, making them an easy substitute that still fits the class profile.
Although the Enzo has become the most popular body in this class, the field remains diverse. Other competitive choices include the Porsche 962, Porsche GT1, Nissan R390, Jaguar XJR8, Toyota 88C, Mercedes CLK, and Toyota GT-One and more.
As with all “True Scale” classes run at Electron Raceway, chassis must be production H-bracket types with custom front and side pans. Approved makes include 2NASTE, Slotting Plus, Schöler, Scaleauto, Plafit, and others. These chassis are all very similar bolt together designs with very little variation in performance—no single brand dominates.
Race Format
For this event, we're trying something a little different. After racing at Pelican Park, I’ve come to appreciate the intensity and strategy of head-to-head formats—whether in the Semis, Main, or Hooligans—over the traditional full-lane rotation. When racing head-to-head, you always know where you stand. If you're trailing, you can push harder; if you're ahead, you can manage your pace. It’s a more engaging way to race.
With just five drivers, we'll race on only three of the four lanes—Red will sit empty. After qualifying, the top three drivers will advance directly to the Main, while the bottom two will be sent to the Consi (consolation race).
For qualifying, we’ll use what I like to call “Basil’s Way.” Each racer will rotate through the three active lanes in standard fashion, but instead of tallying laps, each heat will be scored as a 20 lap mini race. All qualifying heats will begin with all three cars lined up on the starting line. Points will be awarded as follows:
- 2 points for 1st,
- 1 point for 2nd,
- 0 points for 3rd.
This format, inspired by Pelican Park and Basil’s thoughtful approach to race structure, adds a layer of strategy and drama—making for a more exciting and rewarding experience on the track.
Editor’s Note: The 20 lap qualifying races coupled with a Main and Consi resulted in a late night so next time qualifying heats will be limited to 10 laps. This way, the guys can get home at a reasonable hour
Sports Car Race
The Sports Car class turned into a classic Ford vs. Ferrari showdown—though a bit one-sided in terms of numbers. James fielded the lone Ford GT, while the Ferrari camp came strong with two 458s (piloted by Rich and Joe), a Ferrari F430, and an OSCAR-based Ferrari Modena.
Originally, Rich planned to run a tried-and-true favorite, a Porsche EVO powered by a Deathstar motor. However, after watching James’ Ford GT deliver blazing lap times in practice, Rich changed his mind and opted for one of his best rides—a Ferrari 458 equipped with a strong ProSlot motor. This set the stage for an epic duel between two heavyweights.
Qualifying
Qualifying, using Basil’s signature “mini-race” format, went smoothly—though not without a few dramatic wrecks. Early on, James and Rich emerged as the front runners. The two clearly had the pace to fight for the top spots. The real suspense was which of the remaining competitors would grab the final Main Event slot.
In the end, the top three qualifiers were Rich, James, and Joe, while Ken and Scott were relegated to the Consi.
Main Event
The Main delivered the battle everyone expected—Rich and James locked in a fight for supremacy. Both cars were closely matched, but James suffered a few costly offs, which handed Rich the edge and ultimately the win. Joe’s Ferrari showed great speed and even challenged the leaders early, but a few mishaps dropped him to third.
(See the table below for detailed results, along with images of the Main Event grid and close-ups of the cars.)
Editor’s Note: A “Normalized Laps” column is included for reference. Normally, we run four 2-minute heats, but this race used three. To create a familiar benchmark, we calculated Normalized Laps by multiplying the average laps per heat by four.
Consi
As the third-place finisher in the Main, Joe joined Ken and Scott for the Consolation race. Joe took the win, while both Ken and Scott had one bad heat each that knocked them out of contention. (Detailed results and car images below.)
GT1 Race
GT1 qualifying was another tight contest between Rich and James, with both putting down near-identical fast laps. Ken and Joe tied in points for third, but instead of a run-off, Joe graciously yielded the Main Event spot to Ken.
Main Event
The first heat started with Rich grabbing the lead, but James found a way past and began to pull away—until a costly off let Rich retake the point. From that moment on, both drivers ran clean and consistent, setting nearly identical fast laps of 4.8 seconds. In the end, Rich edged out James for the win in a hard-fought battle.
Ken struggled early with multiple offs in the opening heat but regrouped in the remaining rounds, turning in 22 and 21 laps with quick times in the low 5-second range. Great recovery! (Detailed results, grid photo, and close-ups below.)
After the Main, Ken joined Scott and Joe for a single-heat Consolation—time was running late, so one round would decide it. Scott came out on top, followed by Joe and Ken. (Images of the grid and cars below.)
Final Thoughts
This was a fantastic True Scale event—competitive, fast, and a lot of fun. Hopefully, Lowell can join us next time. He’s been tied up with work this summer, but things may open up before the next Electron Raceway race.
