Motor brushes
28 replies to this topic
#26 Bill from NH
  • 15,389 posts
Posted 25 September 2025 - 06:50 AM
Teflon washers are available to use with aluminum endbells. A NY company that made a lineup of aluminum endbells for different C-cans in the late 90s & early 2000s anodized those for each brand a different color & then applied a clear anodizing to insulate the endbell hardware & screws. Their use was popular when this area had a lot of scale racing.
  • SpeedyNH likes this
#27 zipper
zipper
  • 1,140 posts
Posted 25 September 2025 - 11:43 AM
And lots of shorting problems with Koford - didn't try other brands. But little by little they got better.
Pekka Sippola
#28 Mark Onofri
  • 3,026 posts
Posted 25 September 2025 - 12:01 PM
I tried every phenolic arm spacer that I had. None fit the spring post.
Dave, believe it or not, all of this has to do with brushes, kinda.
#29 Bill from NH
  • 15,389 posts
Posted 25 September 2025 - 07:50 PM
Mak, we used a phenolic "oil slinging washer", slightly enlarged the 2 mm hole with a hobby knife, placed a screw through the spring cup & washer, then screwed it to the endbell. You may need to shorten or remove the plastic nub molded on the endbell & replace it with a piece of brass or aluminum tubing, depending on the spring cups you use.
You mentioned elsewhere you liked Proslot's "Gold Dust" brushes. I don't believe they've sold them for several years. I'm not sure what they replaced them with for a premium brush. You could check on proslot.com.
