Cutting straight lines on bodies with no cut lines
6 replies to this topic
#1 Mad Mexican
Mad Mexican
    Safer Barrier Tester!
  • 1,275 posts
Posted 04 November 2025 - 12:31 PM
Hello fellow racers
This has been an issue for me for some time now.
I was checking if there was any tutorials or hacks on
cutting bodies evenly on both sides without  reducing the body in to a test piece
Thank you all in advance!!!
Javier Zavala
In loving memory of my mother Francisca Escalante Zavala
March 24, 1927 - April 5, 2011
Vaya Con Dios
#2 Fergy
Fergy
  • 50 posts
Posted 04 November 2025 - 02:43 PM
Hey, Javier - I use a small strip of Dymo label tape as a guide - it's flexible, but gives you a hard edge to guide the blade. Also a great method for doing panel lines w/a permanent pen.
  • MSwiss, Bill from NH and NSwanberg like this
Dave Ferguson
#3 Roy Lievanos
Roy Lievanos
  • 303 posts
Posted 04 November 2025 - 04:15 PM
I like the JK body trimming tool.
  • Tim Wood likes this
#4 Dave Crevie
  • 5,178 posts
Posted 04 November 2025 - 04:17 PM
Run a piece of 2 inch wide masking tape on one side of the body. With a sharpie, trace the lower cut line and wheel openings on that tape. Now run another piece inside the body on the same side as the other one. You should be able to see the sharpie lines through both layers of tape. If not hold the body up to a light. You should be able to copy the sharpie lines. Carefully peel the tape from the inside of the body, and re-apply it to the outside of opposite side of the body. Try to find a feature that is on both sides of the body that you can use to line up the tape. If you need a perfectly straight lower body line, use a metal scale rule to mark that.
A well known West Coast racer taught me this back in the '60s.
  • Fergy likes this
#5 Wink Hackman
Wink Hackman
  • 68 posts
Posted 05 November 2025 - 04:50 PM
+1 for the JK trimming tool. Set the correct rear wing height at the back, and at the front set the jig to give about 1.5 - 2mm lip, then run a scalpel along the jig. Repeat for the other side and you have a nice level bodyshell.
#6 Dean L
Dean L
  • 4 posts
Posted 09 February 2026 - 02:50 PM
Is this the tool? How do you use this to trim a wide body Indy car shell?
https://shop.jkracew...1304112146.html
  • Roy Lievanos and Tim Wood like this
Dean Leavitt
#7 glueside
glueside
  • 440 posts
Posted 10 February 2026 - 07:07 AM
Used it before.
I have taken an extra body, gotten it exactly where I want it, then put on top of the new body and drawn the markings and cut it.
Jeff Strause
