Motor care
4 replies to this topic
#1 J Patrick
J Patrick
  • 32 posts
Posted 14 February 2026 - 06:48 PM
I've read that you should not oil the endbell side of your motors... Any thoughts?
Joe Patrick
#2 Kim Lander
Kim Lander
  • 628 posts
Posted 14 February 2026 - 07:46 PM
Very very little,just don't put enough that will run down on the comutator.
  • olescratch likes this
#3 Bill from NH
  • 15,383 posts
Posted 14 February 2026 - 07:49 PM
Use a pinpoint oiler & carefully place a drop or two. Some will say no because sloppy oiling & over-oiling can get onto motor comm & foul the motor brushes. If you're careful & take your time placing the oil, you won't have any problems.
  • Fergy, John Luongo and Tim Wood like this
#4 John Luongo
John Luongo
  • 783 posts
Posted 15 February 2026 - 03:12 AM
with motor designs that can be serviced, i always added a phenolic armature spacer next to the comm to act as an oil slinger. also useful at the drive gear position when soldering to keep solder and flux away from the can bearing.
  • Bill from NH and Tim Wood like this
#5 J Patrick
J Patrick
  • 32 posts
Posted 16 February 2026 - 02:39 PM
thanks guys
Joe Patrick
