Oil, or no oil?
11 replies to this topic
#1 Pablo
  • 18,597 posts
Posted 30 April 2026 - 04:58 AM
I did a (Slotblog) search and found an old thread on this subject.
Didn't really see a clear cut consensus, so I'd like to ask it again, please.
Brushless handout race coming up locally here in TN this summer, using Parma #1304 4500KV.
Are the savvy guys oiling, or not?
Thanks,
#2 John Luongo
John Luongo
  • 783 posts
Posted 30 April 2026 - 12:14 PM
i use allison approved trans synd fluid for all bearings. i only need to oil once before the race with no issues. sometimes i will heat up an oil lite bushing a bit, then apply lube oil to it so the bushing can "draw" the lube in.
#3 Pablo
  • 18,597 posts
Posted 01 May 2026 - 04:33 AM
And that's on brushless motors, John?
Thanks for the reply.
#4 John Luongo
John Luongo
  • 783 posts
Posted 01 May 2026 - 06:58 AM
no. i dont own one, yet. it works for me on gears, axles, axle bearings and guide tongues. for sealed bearings, one can only hope that the provided lube is a good match for the demands of the application. one hint would be if replacement bearings for brushless motors are not available or upgradeable. best regards
#5 Larry Horner
Larry Horner
  • 570 posts
Posted 01 May 2026 - 10:05 AM
Pablo, since these motors were originally developed for drones, I googled if drone motors need to be lubricated. The general consensus is no as most have sealed bearings. But in drone usage, the prop is pulling directly along the axis of motor rotation which is different than in a slot car where the resistance is perpendicular to the motor's rotation. So do the same rules apply ... I have no idea. My suggestion would be not lube the motor and see what happens and luckily these motors are fairly cheap if that doesn't work out.
  • John Luongo likes this
#6 John Luongo
John Luongo
  • 783 posts
Posted 01 May 2026 - 10:52 AM
as more brushless racing gains popularity, measuring bearing temps may prove interesting. working in transportation years ago, we had particular blower motor bearings that seemed to be failing frequently. i upgraded the sealed bearing with an aircraft grade replacement and was able to increase the service life of the blower motor.
#7 Bill Breck
Bill Breck
  • 184 posts
Posted 01 May 2026 - 12:55 PM
The direct approach never hurts - ask Roger at Mid America. He's always answered my questions about his products.
  • Pablo, Tim Neja and John Luongo like this
#8 Pablo
  • 18,597 posts
Posted 01 May 2026 - 01:54 PM
Thanks Bill, I may do that  :)
#9 Bill Seitz
    always in last place
  • 750 posts
Posted 01 May 2026 - 06:09 PM
A couple things you may consider about bearings. Whether sealed or shielded, rubber seals or metal shields cause extra drag on the bearing particularly until the bearing breaks in and wears a groove in the seal or shield. Sealed or shielded bearings are often lubricated from the factory with grease. Grease being more viscous than oil, especially a light oil, causes more drag on the bearing than one lubed with oil. An oiled, open bearing will have less rotational friction and therefore require less effort or attain a higher speed with equal effort. Synthetic ATF is an excellent lube for small bearings due to extreme film strength and low viscosity. There are other low viscosity, high film strength lubes that also work well, and always better for speed performance than grease.
Seals and shields work well to keep lube in the bearings for longer periods and keep dirt/contamination out in harsh environments. They're great for extended life and reduced maintenance. Grease is great for when lubrication needs to last for an extended period and not wash out in extreme environments. Seals, shields, and grease do cause extra friction loss, so not great where max performance/minimum resistance is important.
#10 MSwiss
  • 26,236 posts
Posted 01 May 2026 - 08:55 PM
Pablo,
There's a brushless Facebook page.
#11 bbr
bbr
  • 2,493 posts
Posted 01 May 2026 - 09:00 PM
most BL motors we use in slot cars are 2mm BBs. easy to replaced and about the only thing that wears out.
Mike Low
#12 Ken Lenz
Ken Lenz
  • 32 posts
Posted 05 May 2026 - 03:06 PM
Pablo,
Really as if we didn’t know.
Isn’t this the Brushless sub-group for motor building?!?
Pioneering Brushless Technology for Slot Cars
