Motor winding/rewinding
#51
Posted 07 November 2007 - 08:24 PM
Posted 07 November 2007 - 09:44 PM
... are you kidding me, that's the best part!Endbells, unfortunately, often melt first. Just something to keep in mind...
From my post above:
... anyone?I also got a Parma D-can setup to use for testing out some of arms Ron is sending, never messed with one before. Can anyone tell me what's up with the weird springs on these things?
#53
Posted 07 November 2007 - 10:01 PM
On a serious note, since nobody responded to your question about "weird springs", I think we need a photo to understand the question.
Posted 08 November 2007 - 06:17 AM
I understand I've been away for a long time but... my how things have changed!
#55
Posted 08 November 2007 - 06:36 AM
Sounds like you're using some stock 16D springs. The idea is for the end of the vee on the short leg to push the brush in toward the comm rather than to the sides of the brush hood.
Most people change to a quality aftermarket spring such as the Champion lights (red) which have conventional straight legs. Those 16D springs can be made to work but require a lot of tweeking. Sometimes clipping about 1/32" off the short leg helps.
#56
Posted 08 November 2007 - 06:46 AM
Thanks, Bill.
#57
Posted 09 November 2007 - 03:06 PM
Now I'm just waiting on the arms to get here.
#58
Posted 09 November 2007 - 07:24 PM
What are you rewinding, an alternator for a John Deere?
Posted 09 November 2007 - 07:45 PM
#60
Posted 09 November 2007 - 08:11 PM
The base, while nice, is WAY too big for my desk though, I'd take me a week to clean off a spot that size!
Something to watch for, check that the new comms will fit if using a vintage endbell. Trying to remember, seems maybe the Chinese comms mostly fit, the American arm comms I believe are too big unless you radius the Mabuchi endbells? If using vintage cans and bells, it's probably good to trial fit the whole setup before winding. Some of the new arms as per rules are a fair amount longer than the Mabuchi arms were.
11/6/54-2/13/18
Posted 11 November 2007 - 07:26 AM
Ron... if you're looking in here, I got those arms... they will be a great help, much appreciated!
#62
Posted 12 November 2007 - 06:43 AM
BTW... the winder worked great and made this much easier for me... especially with such heavy wire (#24).
#63
Posted 12 November 2007 - 08:00 AM
#64
Posted 12 November 2007 - 11:43 AM
... sure Bill, I don't have one of those protractor timing-degrees thingies but the comm tab for the pole you're working on is lined-up with the leading edge of the next pole. Just eyeballing this, you should be within a couple of degrees of consistency if you use that as a guide. I got that from one of the helpful folks here that have contributed to this thread and it seems to work really well.John, do you recall how much timing you put on that arm?
#65
Posted 15 November 2007 - 02:43 PM
I don't know yet how it will actually run, but it sounds pretty impressive anyway,
#66
Posted 15 November 2007 - 03:12 PM
The winds look nice!
Posted 15 November 2007 - 03:23 PM
I balanced it on razor blades; the arm was an unbalanced 16D I got from Ron. I made a block with slots for razor blades and spent some time trying/marking/drilling and it came out fine. The thing sounds like a dentist's drill on steroids and really dims the light on my homemade power supply
#68
Posted 15 November 2007 - 10:18 PM
#69
Posted 16 November 2007 - 06:52 AM
The arms you sent have been just the ticket for me to try to figure out what was going on here and to get my feet wet again. I'm still waiting on the blank C-can arms and comms from Mura to arrive (?), but in the meantime I've been able to re-learn some about winding and balancing.
The D can setups from Parma are... interesting. The air gap is large enough to drive a Jeep through, the springs make no sense at all (I tossed them as per suggestion here), and the design of the whole endbell (brush hoods, spring posts, etc.) probably could benefit greatly from insulating the springs and going with shunts. The magnets don't seem particularly muscular either, but I have no way of measuring that. All-in-all, I'm happy that these arms spin-up as well as they seem to and they'd probably do significantly better in a well set-up can with beefy magnets.
Right now... the arms seem to prefer heavier springs, but track-testing would be the real proof of that. I'm sure that ball bearings would also make a big difference over the oilites. Thanks again for the arms!
#70
Posted 16 November 2007 - 09:15 AM
The springs are again Chinese specials. Just brass and good enough to do the job for a "toy" motor. Use a good three or five coil spring with insulation and shunts and you will be fine.
The magnets in the D-can are quite strong and as strong as most C-can magnets. The C-can mags have more energy than the D-can mags, but the D-can mags are better than any '60s vintage magnet. Shimming the magnets to a tighter air gap will make the motor even run better.
#71
Posted 16 November 2007 - 05:10 PM
I'm definitely thinking this one deserves to be treated right, so I want to set up the can. If anyone knows before I destroy a perfectly good can... are the magnets glued in on the Parma D-can... or are they just held in place by the metal "fingers" that seem to be crimped at the edge of the magnets? I'd like to remove them and shim them up, but they don't budge.
#72
Posted 16 November 2007 - 05:39 PM
The magnets are held in the Parma Deathstar can by the two "shim" looking retainers on the top and bottom of the magnets.
Just sit the can on your bench with the oilite sticking up in the air and using a small screwdriver, a small hammer, and some light tapping and the magnets will slide down.
The Rotor can has the can fingers bent over holding the magnets in place. They may have put a bit of super glue on at the factory in China. Just soak the can in some acetone for a hour or two and then try tapping them out as above.
#73
Posted 16 November 2007 - 10:04 PM
I did a little bit of a setup and put in a bearing in the can end of the motor, some better springs, and it really sounds nice! With this one... I'm afraid to let it wind all the way up, in a good way! Mura emailed me to say the C-can arms are on the way... perfect timing.
Thanks again for all your help.
#74
Posted 21 November 2007 - 07:06 AM
Jairus... if you see this, I'll send you one of the newer ones to replace that "puppy-dog" I sent you. If you don't have any use for it, you can always use it for a sinker.
#75
Posted 21 November 2007 - 12:10 PM
"Screaming" isn't the issue. For "scream", you could try 12/22!
But on the track, depending on the track and car, you will likely find that your "screamer" isn't the hot motor.
Fate
3/6/48-1/1/12
