Crazy cute
Rick Davis' 1971 Car Model at Parma Raceway TQ Pro car
#51
Posted 20 May 2020 - 03:34 PM
#52
Posted 20 May 2020 - 05:30 PM
Thank you. I'm glad you guys like it too. I think Rick got the proportions of everything just right.
I had forgotten/didn't know that Parma made 1/32 scale bat pans back in the day. I now wonder whatever happened to the tooling for that part and if there would be a demand for such parts from a retro point of view.
Steve, Parma made a 1" wide drop arm too:
- Steve Deiters likes this
Posted 20 May 2020 - 06:51 PM
I finally figured out how Rick does it. He has a time machine like Stewie on Family Guy
He dials in 1969, goes back to SOCAL or East Coast, walks into a raceway and buys what he needs. "I'll take three of those, a dozen of those, some of those Muras, and some Jet Flags". Spends a couple hundred dollars, walks out with his treasures, goes behind the building, dials in the machine to 2020 and "Zoom" back to Oregon
Seriously, this 1/32 build blows me away. If anything ever tops this it's going to be something ………..
- Rotorranch and Jaeger Team like this
Posted 20 May 2020 - 08:09 PM
good thing it's a cartoon- the power switch is in the middle between On and Off.
Steve Lang
#56
Posted 22 May 2020 - 09:31 AM
Very nice workmanship on that chassis Martin. Get it in the tumbler and see it come back to life............
- SpeedyNH likes this
Posted 22 May 2020 - 09:35 AM
Its a Schrodinger switch.
Cheers
Faster then, wiser now.
#58
Posted 22 May 2020 - 10:25 AM
Time to get my "jig motor" turned into a race motor. First up is a coat of period black "wrinkle" paint;
My favorite look for a motor can:
I waited until the chassis was finished to bend up and install the buss bar to make sure it would clear the rear tire and fit inside the body.
The endbell is all taped up to protect it from the acid flux:
The endbell ready to go:
I'm using vintage 36D brushes, Camen brush springs (it takes 2 pair of double overhead to get 1 pair for this application), Camen purple brush spring insulation and 2 strands of TQ lead wire twisted together for shunt wires:
The slot in the end of the brushes needs to be opened up and deepened for the shunt wires and insulation. I use a screw slot file from Brownell's Inc.:
Assembly time.........
- MarcusPHagen, Pablo, Tex and 2 others like this
Posted 22 May 2020 - 06:49 PM
Okie dokie, here's the mighty mini beast:
I couldn't resist adding the comm cooler and highlighting it with Camen purple:
It sounds great on the Koford power supply and is super smooth,
I think it just makes the rolling chassis. Time to get it wired up.
- MarcusPHagen, slotbaker, Pablo and 2 others like this
Posted 24 May 2020 - 05:01 PM
I wired the car with REHco multi-nimble lead wire and used Faas 64P gears 9T-42T:
Here she is all put together..........
........and thankfully surviving it's first track test:
The motor is absolutely ballistic in this little car. On it's first test lap with the urethane tires I punched it coming out of the lead on. The tires spun, the motor screamed and both rear tires flew off the rims. The little car careened out of the slot spinning wildly down the straight but safely came to a stop in the bank.
OK, that's a no go. I had the tires glued to the rims with the recommended flexible ZAP glue too.
The freshly cut vintage Riggen orange tires on an open car need glue.......and not just a light spray glue.
The orange tires are for displaying the car. I narrowed up some modern wheels/tires..............
..............and I'm going to add lead. This should be enough for the next track test
- MarcusPHagen, slotbaker, Pablo and 10 others like this
Posted 24 May 2020 - 05:31 PM
that's excellent. i just hope that the right rear tire doesn't fod the comm.
- Half Fast and Rotorranch like this
Steve Lang
#63
Posted 24 May 2020 - 06:58 PM
I hope nobody got hurt, my lord that's a lot of punch for a little car
Is the cat OK?
Posted 25 May 2020 - 05:58 AM
He was already from the future, went back in time, kicked *** at the races & then zoomed back into 2020! He was a time traveler FROM the future!
#65
Posted 25 May 2020 - 10:34 AM
Pablo, the scream of the little beast is too much for our cats. Their turn marshal position at the lead on sits vacant when it hits the track:
Modern tires and 1/16" thick lead at the corners of the pans:
I found that turning the power supply down slightly from 12V to 10V makes the car simply very fast instead of crazy fast on my home track:
I could put a milder armature in to slow the car down a bit. But I didn't build it for my home track. I built it for a BIG track...........someday
I will start working on a body on and a bit of air control next............
- MarcusPHagen, slotbaker, Pablo and 5 others like this
Posted 27 May 2020 - 01:23 PM
I have only collected a few Kirby bodies over the years and just 2 of them are 1/32 scale. Luckily one of them is this:
A Kirby Autocoast Ti-22. Just what the Doctor ordered for this project:
Now if I don't screw it up mounting and trimming it.......
Posted 27 May 2020 - 02:31 PM
Nice and easy does it.
You got this.
#68
Posted 27 May 2020 - 04:52 PM
Don Weaver
L.H. Lapham
it will starve to death...
#69
Posted 27 May 2020 - 05:36 PM
dc-65 invented "clean"
Posted 27 May 2020 - 07:57 PM
no braid juice or track glue, i guess.
the Captain sure did build an excellent track.
Steve Lang
#71
Posted 27 May 2020 - 08:30 PM
Thanks Martin
Yup, no braid juice and very little glue on my track. Most of the time I'm testing earlier era cars from the 1966 Rod & Custom series and older on urethane tires.
Gery Gerding did build me a very nice track Steve. I can't think of a better use for a living room/dining room in your home. It's been my dream for a long time...I'm very lucky:
Okie Dokie
The Arrivial:
The Man his own self, Gary Gerding:
Semi organized chaos begins:
Some assembly required:
All the supports standing at the ready:
Gary hard at work.....or sleeping![]()
Getting close.....
One more section to go as Charlie the 18 pound lap cat wanders by:
DONE!
The big bank means I'm not wasting precious main straight length for a braking zone:
Drivers station with temporary supports for the power supply and "compter screen":
Gary used poker chips to designate controller hookup colors:
Not sure where the "compter screen" will end up. Maybe wall mounted:
WEEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!
- MarcusPHagen, slotbaker, tonyp and 2 others like this
Posted 28 May 2020 - 01:46 AM
just dream
#73
Posted 28 May 2020 - 05:28 PM
I dolled up the wheels a bit with some BWA Autohobbies Cobra Daytona Coupe repop wheel inserts:
I usually have bad experiences with paper thin Lexan bodies. But this time it worked out great:
I think it sits nice on the chassis:
Now I'll open up the cockpit, velocity stack openings and work on the air control:
- MarcusPHagen, slotbaker, Tex and 2 others like this
Posted 01 June 2020 - 06:00 PM
For my air control I used a Slick 7 wing car air control kit:
I made a card stock template patterned after the 1970 NCC style rear spoiler and traced it onto the .005" Slick 7 Lexan wing car side dam:
The Mylar Slick 7 front air dam was trimmed down and a PdL style "anti-lanching device" for the radiator air vent hole is another piece of .005" Lexan. The velocity stacks are 2mm K&S aluminum tube and the interior is from the Kirby body kit:
Everything is ready for paint..........except I don't have any yet. I'll be using Pactra's RC spray lacquer and it supposed to arrive in about a week.
- MarcusPHagen, Tex and Tom Katsanis like this
Posted 10 June 2020 - 04:36 PM
Hobbylinc finally got around to shipping my RC paint.
Here's one version of the real Ti-22 as raced:
This build obviously isn't a scale version but I am painting mine white like the real car..............
..............the numbers will be 22 and, hopefully, silver lower body panels. They're not painted yet. I'm trying to save a screw up before I attempt painting them:
- Pablo, Tex, Greg VanPeenen and 1 other like this
