"Rods and Rails" discussion and car show
1321 replies to this topic
#751 hiline2
hiline2
  • 468 posts
Posted 03 April 2015 - 09:17 PM
The Russkit/K&B style chassis.
Paul Bass
#752 boxerdog
boxerdog
  • 877 posts
Posted 04 April 2015 - 10:36 AM
I just remove the front section of the chassis and maybe the motor brushes, then put the magnet between the plates of the zapper and buzz away!!
David Cummerow
#753 don.siegel
  • 5,862 posts
Posted 04 April 2015 - 11:47 AM
Here's the Ramcharger assembled, with all decals applied; still not sure if I'm going to add an interior.
MPC%20Ramcharger%20chassis_zpsr3otbevl.j
#754 Lone Wolf
Lone Wolf
  • 2,739 posts
Posted 04 April 2015 - 12:03 PM
Looks great, if you have not done so yet may I suggest a coat of clear over the decals. Half of them would probably be gone when you got the car back :)
Joe Lupo
#755 Gator Bob
  • 13,391 posts
Posted 04 April 2015 - 12:09 PM
Very cool super clean car, Don. :good:
Should go pretty good, looks very lightweight. Maybe space the guide flag so it doesn't run on the fronts ... or just barely touch.
 "'Lodex' is in the house" ... :crazy:  :laugh2:
#756 Gator Bob
  • 13,391 posts
Posted 04 April 2015 - 12:26 PM
Joe, please note that great care is taken in handling of the cars. Some really fragile model body cars and trucks were entered last year.
Clear over decals looks great and never hurts ... unless it causes the paint to wrinkle :o  ... I just 'totaled' a finished body paint job yesterday doing that ... :dash2:  :dash2:
#757 don.siegel
  • 5,862 posts
Posted 04 April 2015 - 02:01 PM
Yep, I was definitely planning a clear coat Joe, but hesitated because 1) I've never actually done that! and 2) what Bob said... on the other hand, the body isn't painted, but hope it doesn't wrinkle the decals!
#758 boxerdog
boxerdog
  • 877 posts
Posted 04 April 2015 - 10:00 PM
First, I have a question for Mr. PittMan...Bob, what did you make those great looking lead wires out of??
And then, this has been Kemtron Week for me, and I only finished one.Hope y'all like it, and thanks again to John.
  • hiline2, havlicek and Gator Bob like this
David Cummerow
#759 SlotStox#53
  • 4,084 posts
Posted 04 April 2015 - 10:12 PM
David do I spy some custom endplates on that Kemtron ? Especially the comm end with the Pittman brushes and possible comm timing adjustment :ph34r:
Very Kool! !
#760 boxerdog
boxerdog
  • 877 posts
Posted 04 April 2015 - 10:21 PM
Paul, I wish I had more of those. That is the only set I have ever seen, they were part of a Kemtron "kit" and I got them on Ebay somewhere many years ago...so I was determined to try them. I think the brushes are Ram 196-size.  I probably should have used ball bearings, but I didn't. The motor seems very sensitive to timing and is getting gradually broken in, maybe back in the roadster tomorrow if I can fit a suitable gear.
  • havlicek likes this
David Cummerow
#761 SlotStox#53
  • 4,084 posts
Posted 04 April 2015 - 10:26 PM
Even cooler being actual Kemtron kit, found a few kemtron cast Pittman style endbells for the 36D like the RAM & Simco ones but never those! ! :shok:
The bottom plate almost looks like the one from either the Mustang or Bronco X503 based motors without the branding/casting marks...
Sure looks one quality motor David, great job :good:
#762 Pitt Man
Pitt Man
  • 287 posts
Posted 04 April 2015 - 10:46 PM
What a cool looking Kemtron, David!
I've been using Marklin wire.
This wire is used by the model railroading crowd for wiring tracks. Many colors are available
I believe this is the same stuff used in the 60's, comes in 33 foot boxes and 24.3 AWG, readily available on eBay and from RR suppliers.
  • hiline2 likes this
Bob Steere
#763 boxerdog
boxerdog
  • 877 posts
Posted 05 April 2015 - 09:50 AM
Thanks, Bob.
  • Pitt Man likes this
David Cummerow
#764 havlicek
Posted 05 April 2015 - 12:10 PM
Yikes, that really is a lovely Kemtron!  VERY nice work David!
Yeah, that's what I've seen also.  I imagine that's because each com segment is only 1/5 (72 degrees) of the total.  Are the brushes the same or close to the same size as the originals?  Wider brushes mean more overlap.
#765 SlotStox#53
  • 4,084 posts
Posted 05 April 2015 - 12:19 PM
Much wider brushes John :good:
David's using wide RAM square brushes whereas the originals are narrow cylindrical ones..
#766 Ramcatlarry
  • 2,949 posts
Posted 05 April 2015 - 12:53 PM
Too much overlap can lead to stalled starts and overheating.  May need to take a corner off the trailing edge to reduce the problem without reducing the timing - something we have found on the newer FK proslot motors.
#767 BillB
BillB
  • 62 posts
Posted 05 April 2015 - 02:19 PM
Hello to All,
Thought it was time for me to get my butt in gear and get ready for the up coming race.
Bob, Include my entries into the following classes.
1 - Altered
1 - Gasser
1 - Comp Coupe
1 - Rail
1 or 2 - Unlimited
Don, I've had good success using Minwax fast drying Polyurethane clear gloss over decals. Spray on a lite tack coat wait 15 minutes +or- and then spray a wet gloss coat. Of course with anything untested try it on a sample piece first.
Bill
Bill Bilancio
#768 boxerdog
boxerdog
  • 877 posts
Posted 05 April 2015 - 04:08 PM
The motor runs ice-cube cold and has no starting issues, so I doubt that overlap is an issue, it is a pretty large comm. I think John hit it on the head in that the comm dwell is less due to being a 5-pole. I just want to make sure that it is somewhat directional and running in that direction. Also, I always thought that maybe the weakness of the KTM design was the pencil-lead brushes and fragile springs. The brushes would seem to wear fast, carry little current and are a bitch to find when they shoot across the room, However, the motor may be the biggest sleeper ever, particularly on lower voltages.
David Cummerow
#769 SlotStox#53
  • 4,084 posts
Posted 05 April 2015 - 09:48 PM
Was wondering about trying to customize the brush gear on the Kemtron motors due to the very reasons you mention David :good: But time and parts available mean the H-Power armed Kemtrons will go into competition with the standard bits for the moment , with a view for future mods later on . Can't wait to see what that motor does down the strip :D
#770 hiline2
hiline2
  • 468 posts
Posted 06 April 2015 - 06:47 AM
Anyone needing (wanting) some Kemtrons !!
http://www.ebay.com/...=item4637e6e6cb
Paul Bass
#771 boxerdog
boxerdog
  • 877 posts
Posted 06 April 2015 - 08:33 AM
...and only a few miles away!  Why don't I ever find this stuff? Maybe if I started hitting garage sales. That looks like a vintage box, too. BTW, here is the endbell "documentation" that I had.
David Cummerow
#772 SlotStox#53
  • 4,084 posts
Posted 06 April 2015 - 09:28 AM
OMG! :shok: why don't these mother loads ever turn up when I have enough cash to bid! :(
Thanks for the Kemtron info sheet David :good:
Searches *Kemtron* on epay religiously from now on ! :laugh2:
#773 hiline2
hiline2
  • 468 posts
Posted 06 April 2015 - 11:03 AM
Im always  scouring epay, so Ill post more if you want on the oldies !   :good:  :wacko2:
Paul Bass
#774 Gator Bob
  • 13,391 posts
Posted 06 April 2015 - 01:56 PM
 Wow, that is a first for me. I did not know Kemtron made aluminum endplates. Outstanding motor :heart: ...
Hello to All,
1 - Altered
1 - Gasser
1 - Comp Coupe
1 - Rail
1 or 2 - Unlimited
Bill
That's awesome Bill, glad you're signed up. :good:
Guys have really upped their game this year. You'll have the chance to see and drive some great cars. :D  :clapping:
  • SlotStox#53 likes this
#775 Gator Bob
  • 13,391 posts
Posted 06 April 2015 - 06:10 PM
Trying to get some clearance for the brush arms .... :dash2:
Lots more cutting and fitting still to do, OMG ...these are harder to build than a brass/wire Retro scratch chassis.
Normally I put the motor IN the chassis not half of the chassis in the motor ... :wacko2:  :sarcastic_hand:
