You over geared it. We had to drop 2 teeth 64p with our cars ......
Spur or pinion, or both?
Posted 01 October 2022 - 08:10 PM
Posted 01 October 2022 - 08:52 PM
You over geared it. We had to drop 2 teeth 64p with our cars and the motors still layed down after heat 5 and 6.
did i mention we were racing wing cars?
Posted 01 October 2022 - 10:56 PM
Posted 04 October 2022 - 12:59 PM
100' Hillclimb
light sprayglue
.700 tires
PS-9000 motor
Koford wing car chassis
3 minute heats
Will start testing at 12/38 64p
The fastest car ran 13/39 72P last month
Scott Salzberg
PCH Parts Express
Posted 04 October 2022 - 07:43 PM
,700" tires? what's the rear ground clearance?
Posted 05 October 2022 - 02:46 PM
Maybe .047. Many start the race with .690 tires. What do you think about 12/38 64p?
Scott Salzberg
PCH Parts Express
Posted 05 October 2022 - 07:36 PM
try 12/36 64p - it worked for me.
Posted 17 October 2022 - 12:29 AM
Steve Meadows
Posted 17 October 2022 - 12:58 PM
I built a 4.5" stock car with one yesterday. Geared it 12/37 64p with .790 tires and it runs really well on our 155' Hillclimb. It is fast, has good punch, but brakes were soft. Going to try an 11/36 next, but it is very easy to drive as is.
Matt Sheldon
Posted 21 October 2022 - 08:54 AM
What gears are people running with this motor in something as heavy as a 4" Flexi? At the local track we've been struggling a bit trying to find a ratio that the motors consistently survive a race. We're also noticing significantly more brush wear than the 4002fk that we've been running. (Please don't take that as trash talking ProSlot, just looking for some answers.)
The track is a G4 Gerding King, and we're running 4" Flexis with various bodies. (LMP, DTM, Nascar, etc.) Tires are Wonder rubber, up to .760 diameter, and we're running 64 pitch gears.
Posted 21 October 2022 - 10:43 AM
Posted 21 October 2022 - 01:45 PM
Posted 21 October 2022 - 03:10 PM
Posted 27 October 2022 - 10:25 PM
G4 Gerding King, 13.6 volts, running 4" Flexi with DTM bodies. Tires are Wonder rubber, .760 diameter, 64 pitch gears (10/36), 2 minute segments.
My new Speedball almost made it thru 2 whole races before it went up in smoke. 3 other racers had the same thing happen tonight.
I'm DONE with the Speedball!
Posted 27 October 2022 - 11:17 PM
Why did they go up in smoke?
Had they been prepped in any way before racing?
Posted 28 October 2022 - 12:10 PM
You will have to ask Pro Slot.
We have had a much higher failure rate with the Speedball vs the discontinued Pro Slot FK4002.
As far as motor prep, some run as is, some change springs & brushes.
When I pulled mine down, the brushes & comm looked OK; the arm was cooked.
Posted 28 October 2022 - 12:28 PM
Posted 28 October 2022 - 07:16 PM
Bobby,
Was the 9000 motor, at 10-36, faster than the 4002FK at whatever ratio you ran it at?
If so, I suggest trying 9-36 and let it sing.
We've only had 2 on my King, but they have run well.
As mentioned, my King is 13.6V, and I am fortunate enough to have real high end, well filtered, power supplies, which seem to be easy on motors for 13.6V and 10-10AWG, staggered, positive and negative taps.(IOW, 20 total)
Yes the Speedball was .1-.2 tenths faster than the 4002.
One of my fellow racers geared his brand new Speedball at 9-37 and only got 7 segments out of it before it burned. He tried another at 9-37 and got 10 segments before it burned.
I can't speak to the power set-up on our local track, but we can see a real difference in the longevity between the two different motors, running on the same track power set up.
Posted 28 October 2022 - 07:21 PM
Posted 28 October 2022 - 07:26 PM
Ok, 4-1+.
You guys are trying. Lol
I bet you guys would be happy with my STAGE 4 motors.
I might add that some racers are still running leftover 4002FK's in the same races as the Speedballs, without issues...
Posted 29 October 2022 - 03:28 PM
Could be a less than ideal epoxying job at the manufacturing facility.
Posted 29 October 2022 - 03:45 PM
Man I don’t think over ever seen one quite smoked like thatTore down my smoked 10-36 Speedball. I'm no expert, but it looks like it threw a wind...
Steve Meadows
Posted 29 October 2022 - 04:26 PM
The epoxy is destroyed by high heatCould be a less than ideal epoxying job at the manufacturing facility.
Steve Meadows
Posted 29 October 2022 - 09:54 PM
There has been poor oriental epoxying in the past.
