Pro Slot PS9000 Speedball motor
#126
Posted 29 November 2022 - 01:37 PM
- crazyphysicsteacher likes this
#127
Posted 30 November 2022 - 06:42 AM
The angle of the spring hoods can change and the sides tweeked. This will change the alighment of the brush to the comm. I have seen it on brand new and old motors, bending the tabs will cause changes in brush angle enough to effect both rpm and wear.Here is an (old) 4002 that I have grabbed the hardware tabs and wenched them way out of alignment with a pair of pliers
The hood ‘housing’ hasn’t moved
It won’t because it’s clamped in place by the screws and spring posts, which are located by nipples
So trust me, a tug on the lead wire won’t end up in your timing going off
I understand that you may use a vise grip to tighten the hoods but the rest of us don't.
And for others, this is also the reason why you may have different rpm readings based on if the motor is sitting on a bench or hanging from the bench by the wires while running.
- Zippity likes this
Chris Wendel
Silver Side Down Racing
Silver Side Down Graphics
The Race Place Retro Crew member
"Failure teaches way more than success. It shows what does not work and what to never do again, again..." 🙊🙈🙉
#128
Posted 30 November 2022 - 11:40 PM
you could tighten the brush hoods & solder the bottom plate for better conductivity.
#129
Posted 01 December 2022 - 12:26 AM
I’ve heard of this being done.
I guess if you had an endbell set up as a jig this would be an effective way of ensuring perfect alignment and shape.
I must try it.
Steve Meadows
#130
Posted 07 December 2022 - 07:58 PM
- team burrito likes this
Steve Meadows
#131
Posted 07 December 2022 - 08:09 PM
Look at the F1 times!
#132
Posted 08 December 2022 - 01:13 PM
Allan Tucker is much faster than the rest of those racers it’s not a field of fair comparison
Steve Meadows
#133
Posted 08 December 2022 - 02:45 PM
They're currently in 5 or 6 cars.
No question they are faster than 4002FK's.
I would say .1 faster than an exceptional one.
.2-.25 faster than an average one.
Whenever I pick up a car that stops by me, at the end of a heat, they are running cool.
I will say, last night, the racer who had one in his car first, wasn't quite as fast as the guys with fresher ones.
I'd say he has at least 5 races on it, though.
#134
Posted 08 December 2022 - 11:14 PM
#135
Posted 08 December 2022 - 11:39 PM
#136
Posted 09 December 2022 - 12:17 AM
Mike Swiss- do you allow your guys to rebuild their FKs and 9000 motors?
No.
Why not? if you stick with the stock armatures, it shouldn't be a problem.
#137
Posted 09 December 2022 - 12:22 AM
why not? if you stick with the stock armatures, it shouldn't be a problem.
Because he has a raceway and sells motors for a living.
Steve Meadows
#138
Posted 09 December 2022 - 12:54 AM
- NSwanberg and swodem like this
???-2/31/23
Posted 09 December 2022 - 01:20 AM
- NSwanberg likes this
Steve Meadows
#140
Posted 09 December 2022 - 01:57 AM
If he sells the armatures, is that enough? It's a shame to throw out the whole motor when it can be repaired.
- Egil Aksnes likes this
#141
Posted 09 December 2022 - 02:04 AM
I think the issue is deeper with competitive racers wanting seals intact.
Personally I’d love it if we could race unsealed minicans, but many here don’t want this.
Steve Meadows
#142
Posted 09 December 2022 - 09:40 AM
Rebuilding motors is not necessary in order to have fun racing and running slot cars.
While it can be an educational and interesting experience for the devotee, for most it is akin to making your own socks.
- Cheater, Zippity, Tim Neja and 2 others like this
Jim Honeycutt
#143
Posted 09 December 2022 - 10:16 AM
Right, it's a class for those that don't want to rebuild motors, which is most racers now days.
- Zippity and Tim Neja like this
???-2/31/23
Posted 09 December 2022 - 11:43 AM
Why are those Pro Slot motors built to be rebuildable? Why not just another sardine can?
- Zippity and W. J. Dougherty like this
#145
Posted 09 December 2022 - 12:41 PM
If you guys that want to rebuild motors, race in a class that allows that. No reason to try and change classes that don't allow that and are doing well. It makes no sense.
- Zippity, Tim Neja and NSwanberg like this
???-2/31/23
Posted 09 December 2022 - 01:11 PM
I don't ever remember anyone uttering "I wish we could rebuild these." If that was the case, one guy would be doing all or most of the work.
Michael Iga, who wrenches on almost all the cars, to make them competitive, so we have clean, close racing.
Most guys don't touch their cars between races.
A few weeks back, after the race, I asked one of the guys if I could borrow his car for an experiment. He said "Sure, it just sits in my truck between races."
if he sells the armatures, is that enough? it's a shame to throw out the whole motor when it can be repaired.
There isn't enough racing, or guys interested in just running around, to use anywhere near the available Pro Slot setups.
Why are those Proslot motors built to be rebuildable? Why not just another sardine can?
I'm pretty sure you are aware Pro Slot uses this platform for a bevy of non-sealed, mostly drag motors.
#147
Posted 09 December 2022 - 01:41 PM
We're still having good luck with ours, in wing cars, on 13.5V.
Mike, we are seeing similar results at Downriver Speedway's King on the same voltage.
So far I haven't had any motor failures (one motor with close to 2,000 race laps, another with approx. 1,000 laps and couple more that I'm testing with). The only other thing I'd like to mention is that the 9000 motors seem to be a little more sensitive to gearing changes than the 4002 is, but once the motor is in it's happy place it's definitely faster (I ended up adding three teeth to the spur over what I was gearing my FKs).
- MSwiss likes this
Steve Grider
#148
Posted 09 December 2022 - 03:28 PM
What are you gearing your 9000s? Whats the tire diameter? Thanks.
#149
Posted 10 December 2022 - 01:04 PM
10/36, .650".
Steve Meadows
#150
Posted 11 December 2022 - 03:50 AM
I was halfway through writing this the last time the thread was locked - I was late by about a minute! But I had posted elsewhere and will copy here now. This is what we found at our local flat track and in our case we are making comparisons based on looking for performance parity rather than just a new product to replace a superseded one. i.e. speed is important to us in that we want to run as near the same as we do now:
- Zippity, gotboostedvr6 and rmjlmartin like this
Ivan Bailey
